Official "What oil / additives should I use" topic
Page: Previous  1, 2, 3 ... 27, 28, 29 ... 235, 236, 237  Next
udidwht
udidwht is offline
PostPosted: Wed Feb 11, 2009 12:52 am    Post subject: Reply with quote
Bruce wrote:
merlinj79 wrote:
Bruce wrote:
merlinj79 wrote:
. But I'm certain that if 20W-50 was OK in 1977, it is still OK today as far as viscosity goes...the new technology has not changed the viscosity, except that it will not break down as easily.
Part of the reason VW specified thick oil back then was because nobody knew what their oil temperature was. As a pilot, you should know the value of what your gauges are telling you. Therefore, you should use an oil temp gauge in your VW. Only after you know what temps your oil runs at, can you intelligently pick your viscosity.
Assuming you need 20W-50 when it's 90-100ºF out is just guessing. You would never do that in your airplane would you?
The owner's manual says I need 20W-50 in those temps...can anybody explain why I should disregard that?
You should disregard it because it makes the assumption that when the ambient temp is high, the oil temp will be within the proper operating range of 20W-50. Wouldn't it be smarter to find out what the actual oil temp is rather than making assumptions?
A few pages back, one poster said his new pickup's oil temp runs at 180ºF whether he's in Phoenix in the summer, or North Dakota in the winter. Since his normal operating oil temp never varies, he can use 5W-30, year round. In other words, the outside air temp has nothing to do with the oil he uses.
Any assumption would of had to be on the VW German engineers.
The said vehicle was his NEW pickup (water-cooled).
Jimmy111
Jimmy111 is offline
PostPosted: Wed Feb 11, 2009 9:39 am    Post subject: Reply with quote
Rick.
Your 77 type 4 was stuffed full of smog equipment from the factory and had oil temps is the 260-280F range. so it ran very hot. In that motor if you had the smog equipment installed I would use 20-50. But if no smog equipment I would use 5-30. The absolute minimum any motor either water or air cooled should run at is 180F. 180F is concidered severe duty by all auto manufactures and requires more frequent oil changes. Any less than that will cause ring wear and other problems. Optimum oil temp should be a minimum of 212 but 225 is better to evaporate the condensation from the oil. Most VW guys target the 212F because the extra heat can kill the engine..
The guy that said he has 180 on his new truck is FOS or he has a problem. Almost all new cars are designed for a 50F minimum higher oil temp than water temp. The rest are designed with a 75F differential.
On every combustion stroke the gasoline is turned into water vapor and you get a small amount of it into your engine oil on every stroke due to blowby. IF the oil temp does not exceed 212 your oil will turn into a white stickey mess which many people mention has happened to them. This emulsion of oil and water does nothing to lubricate your motor.
Mag cased VW's have the problem that AS-41 starts to weaken at 240F and becomes Jello at 300F. So if you have a Mag cased VW if is best to keep the oil temp as close to 212 as possible and select your oil to meet that temp. this is the main reason for using SAE 30 series oils
If you have an aluminum cased VW you can have max temps that exceed 300F and not have any structural problems.
Many people point out that Aircooled Aircraft engines use SAE 50 series oils and run in the 180 -225 degree temp range so their VW should use the same because it is basicly the same design. But they never take into acount the much larger bearing clearances in a Lycoming engine compared to a VW engine. The clearance is almost 75% larger in a Lycoming than in a VW motor. This is the reason for the higher viscosity.
merlinj79
merlinj79 is offline
PostPosted: Wed Feb 11, 2009 11:23 am    Post subject: Reply with quote
Jimmy111 wrote:
Rick.
OK, that's good info. As I said before I'm open to 10W-30 in the winter (SOCAL "winter") so I'll try that for a few months. But on the hills in the summer it get's real warm, so I'll experiment with carefully this summer.
My oil temps came down quite a bit since with 20-50 Brad Penn (partial synthetic) compared to 20-50 dino oil. So a lighter weight oil will increase oil temps to a more desirable range?
My engine is a 77' T4 GD...anyone know if that is mag or aluminum?
Rick
"Pumpkin II"
Stock 2L FI '77 Westy
CA Smog Stuff
Jimmy111
Jimmy111 is offline
PostPosted: Wed Feb 11, 2009 12:27 pm    Post subject: Reply with quote
All type 4 cases are Aluminum. Very good heat treated aluminum too.
Up to 1975 all type 1 were As-41 Magnesium, 1975 and later were AS-21.
The cooling of the oil is based on speed of flow (quantity) thru the oil cooler. A lower viscosity will flow more oil thru the oil cooler and less oil out the pressure control valve. So you will get cooler oil.
Max Welton
Max Welton is offline
PostPosted: Wed Feb 11, 2009 6:25 pm    Post subject: Reply with quote
I'm slowly talking myself into a larger pump and thinner oil setup. I've been running 30mm pumps with Berg pressure relief covers and 10w30 for years. The cover caps things at a little over 40 psi on this engine. And pressure at 220º is just about right.
So last oil change I switched to 5w30. I still have plenty of pressure when the oil is cold, so now I'm looking for a 0w30.
Max
1967 Type-3 Fastback
bugninva
bugninva is offline
PostPosted: Wed Feb 11, 2009 6:49 pm    Post subject: Reply with quote
Glenn wrote:
merlinj79 wrote:
The owner's manual says ..
It was written 40 years ago.
It also says to use 91 RON octane leaded gas.
they didn't always spec leaded gas... your 74's owner's manual would have let you know that low-lead and lead-free fuel that met the specified octane rating (located inside of fuel door) was acceptable...
[email protected] wrote:
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone?
GEX has. Just sayin
udidwht
udidwht is offline
PostPosted: Thu Feb 12, 2009 12:51 am    Post subject: Reply with quote
Jimmy111 wrote:
Rick.
I don't recall any newer vehicle owners manuals specifying any particular oil temp as 'Severe duty'. Severe duty is usually categorized by 'Driving habits' such as towing, daily stop & go driving, prolonged idling, off road use etc...
Bruce
Bruce is offline
PostPosted: Thu Feb 12, 2009 1:44 am    Post subject: Reply with quote
Jimmy111 wrote:
.... Optimum oil temp should be a minimum of 212 .....
I disagree with that set point. Water in the oil will evaporate off at temps well below 212ºF, it just happens a lot faster above 212ºF.
If my oil temps are in the 180-190ºF range, I'm quite happy.
Jimmy111
Jimmy111 is offline
PostPosted: Thu Feb 12, 2009 6:43 am    Post subject: Reply with quote
Yes, the water will evaporate at 180F but it will take 30-45 minutes for it to do so at 180F. Most people dont drive their car for that long.
There are mountains of techincal papers and indepth testing that have been written and done on the subject of minimum and maximum oil temperatures. So much that no one seems to want to do it anymore.
The SAE technical papers on The Effect of Oil Rheology on Journal Bearing Performance and cylinder bore wear of An Operating Engine clearly state that a absolute minimum oil temperture of 180F should be maintained for many reasons including evaporation of condensation.
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Thu Feb 12, 2009 4:44 pm    Post subject: Reply with quote
Acid can build up in oil if it's not up to operating temperature too, not just water. That's what eats away at bearings, after so long they start to look like a piece of wood that had worms living in it. The acid eats the soft metal away, then next thing you know you've got a knocking rod for no apparent reason. So why is it important to get the engine up to temperature again?
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
gregthomas
gregthomas is offline
PostPosted: Thu Feb 12, 2009 8:44 pm    Post subject: Reply with quote
All the more reason to run a thermostat.
Checkout my church's website: http://www.ebcky.com
We offer podcasts of Sunday Sermons, articles and more!
udidwht
udidwht is offline
PostPosted: Thu Feb 12, 2009 10:59 pm    Post subject: . Reply with quote
Anyone like to take a guess at how long it would take before damage like this would occur? On a vehicle that's driven regularly and receives oil changes at normal intervals.
miniman82
Samba Swamp Donkey
PostPosted: Fri Feb 13, 2009 3:18 am    Post subject: Reply with quote
Doesn't matter how long it takes, fact is it happens. And it doesn't matter how ofter the vehicle is driven, it's HOW LONG. If you drive regularly for 10 minutes each day to work, you're not driving long enough.
Jimmy111
Jimmy111 is offline
PostPosted: Fri Feb 13, 2009 11:30 am    Post subject: Reply with quote
I dont think that with todays oils a whole lot of Acid is generated. But Im not really sure. Havent studdied it in a while.
In the past with Dino oils which we used without purifying, they contained a lot of sulfide metals like zinc sulphide, lead sulfide and molybdeum sulfide among others. We liked these metals in the oil because they helped with shear in the oil. But when emissions came out and Cat converters were invented these metals poisoned them and had to be removed. The sulfide metals would decompose into metilic oxides and sulfuric acid when heated and in contact with water.
But magnesium and water with a little acid added to it creates a very good battery. So with just a little water and Acid you will get a lot of corrosion of your case. Many people have this problem when water collects in the sump next to the screen and corrodes away the area where the screen bolts on to.
ap_sand
ap_sand is offline
PostPosted: Fri Feb 13, 2009 12:00 pm    Post subject: Reply with quote
After the success of Mobil 1 in the automotive world, Mobil pursued certification of a full synthetic aviation oil. Extensive testing in high usage environments (i.e. training, charter, and cargo) showed significant advances in reducing wear.
After it received full approval by the FAA and was deployed with great fanfare to the entire piston GA fleet, problems started coming up. Turned out that synthetics don’t “hold” the acids that form when there is insufficient usage to significantly boil out the generated moisture and let them precipitate out. It ate up both plain (plane… ha!) bearings along with the yellow metals in the accessory drive section. Cost Mobil tens of millions in replacement costs and the oil was pulled from the market.
It was quite a while until Shell came out with a synthetic formulation for aircraft and even that is a partial synthetic blend.
The rule of thumb is that an hour of FLIGHT is needed to purge the accumulated moisture from the oil. If you can’t fly it, don’t just go to the airport and ground run it to “circulate the oil”. It’s PROVEN to do more harm than good and is documented in the manufacturers ops manuals.
bluebug79
bluebug79 is offline
PostPosted: Sat Feb 14, 2009 7:01 am    Post subject: zddp Reply with quote
which oils have significant zddp content nowadays?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Feb 14, 2009 7:57 am    Post subject: Re: zddp Reply with quote
Brad Penn
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
miniman82
Samba Swamp Donkey
PostPosted: Sat Feb 14, 2009 12:16 pm    Post subject: Reply with quote
The oil doesn't generate it, mostly the byproducts of combustion was what I was referring to.
Wilfredo R
Wilfredo R is offline
PostPosted: Mon Feb 16, 2009 11:44 am    Post subject: Reply with quote
I was told by my local vw shop that you use 10w-30/40 in the winter and 20w-50 in the summer, is that what you guys use?
Fattie
I'd roll it
Fattie is offline
PostPosted: Mon Feb 16, 2009 12:36 pm    Post subject: Reply with quote
if one isn't going to read this entire thread....and just pops in here with a question... this thread will continue to repete itself.... example.. the above question Rolling Eyes
Donate and help me get another aircooled dub to share with you guys www.paypal.me/WhosCare
Page 28 of 237
