droogvan Samba Member
Joined: July 29, 2005 Posts: 258 Location: Grand Rapids, MI
Posted: Mon Aug 23, 2010 6:52 pm Post subject: lt truck mirror mounting question |
Just got my a shiny new pair of lt style mirrors from VanCafe today. Love em. I'm wondering though what you guys that have installed these used for hardware to mount the upper bracket. I'm assuming stainless sheet metal screws but what size? Any tips or suggestions?
By the way Van Cafe came through with free shipping for their promo for August. I was hesitant about placing an order but that sealed the deal for me. _________________ 89 Westy zetec
Some ol bullshit |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7206 Location: Honolulu,Hawaii and France
Posted: Mon Aug 23, 2010 7:39 pm Post subject: |
I'd put some expandable nuts....I hate sheet metal screws....
BTW,how did you get free shipping??  |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12313 Location: Santa Cruz, CA
Vanderpooch Samba Member
Joined: May 30, 2008 Posts: 100 Location: Southeastern Tennessee
Posted: Mon Jan 17, 2011 8:35 pm Post subject: Re: lt truck mirror mounting question |
droogvan wrote: |
By the way Van Cafe came through with free shipping for their promo for August. I was hesitant about placing an order but that sealed the deal for me. |
Did you ever mount your mirrors? What did you end up using? Pics? |
SSWesty Samba Member
Joined: August 20, 2008 Posts: 735 Location: Bellevue
Posted: Sat May 21, 2011 10:55 am Post subject: |
I also need to install a set of doka mirrors. If I understand the installation options for the upper mount it appears to be sheet metal screws or some type of expandable nut.
Where would one find a supplier of the appropriate expandable type nut on a Saturday in the Seattle area? |
HeftySmurf Samba Member
Joined: June 15, 2008 Posts: 879 Location: Washington, USA
Posted: Sat May 21, 2011 11:01 am Post subject: |
Pretty much any local hardware or marine store will have what you need _________________ -Lorenzo
90 GL w/ Bostig |
Posted: Sat May 21, 2011 11:48 pm Post subject: |
It took some driving but I found these McMaster-Carr nuts http://www.mcmaster.com/#threaded-inserts/=cesz8k at a Seattle area hardware store called McLendons. They seemed to be the only place around that had them or anything like them. I tried two FLAPs, Lowes and West Marine.
Next question, after closer examination the upper mount doesn't line up with the door frame so they give you a plasitic spacer to fill the gap. It appears as if the designer of the upper mount was off by 15 degrees. Rather than redoing the casting for the mount it seems the manufacture decided the throw in a plasitic wedge to make it work.
Are factory mirrors like this? It seems like you could twist/bend the mirror arm to make the upper mount will fit without the spacer. However I am unsure that will mess up how they fold. What have other folks done?
Steve |
pnwkayaker Samba Member
Joined: April 01, 2008 Posts: 976 Location: Sammamish, WA
Posted: Sun May 22, 2011 6:57 am Post subject: |
SSWesty wrote: |
So Steve, which ones did you end up buying and how are you mounting them (any special tool) ? I look into that page and I see several models, and some of them seems to have two variations (wood and metal perhaps?).
Which McLendons did you buy them ? The one in Rainier Ave ?
I'm interested in seeing how you use them, since I've been toying with the idea of mounting several nuts in strategic points in the syncro to add attachment points. _________________ 87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link) |
Posted: Sun May 22, 2011 12:36 pm Post subject: |
I found them at the Renton McLendons listed as "Blind Nuts" in their speciality fastener section. The ones I got appear to be Nut Inserts and are listed in the Rivot Nut category from the http://www.mcmaster.com/#threaded-inserts/=cesz8k site. They only had aluminum so that's what I went with in the 10-24 thread size.
They sell a tool to insert them however they it's nothing more than a coupling nut, 1.25" long allen head screw and allen wrench. I just bought the coupling nut and allen head screw separately for half the price of the "kit". |
r39o Samba Polizei
Posted: Sun May 22, 2011 1:46 pm Post subject: |
Auveco makes them too. I use their Nutserts. I have their install tool which is a lot like a pop rivet gun. I purchased a selection of metric inserts from them, too. Work good.
http://www.auveco.com/product/jack.html _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Mick Ord Samba Member
Joined: April 26, 2008 Posts: 203 Location: Vancouver, BC
Posted: Sat Jun 18, 2011 8:34 pm Post subject: |
Any further updates/ pics- i have a set to fit and would't mind a better idea on how to fit these, thxs _________________ 1991 Syncro Westy- 2.5 Suby
1989 Syncro Tristar ( sold)
1988 2wd Tristar- about to start resto/rebuild !! |
RGS Paul Samba Member
Joined: April 20, 2007 Posts: 682 Location: Los Alamos, NM
Posted: Sun Jun 19, 2011 6:35 am Post subject: |
The factory used M5 sheet metal screws, there isn't enough room in the door frame for the rivet nuts. The LT's have beefier frames and were able to use the captive nuts in the frame for mounting. You might be able to squeeze captive nuts in there but I wouldn't want to test it on nice doors.
The ETKA page shows how it all got put together from the factory.
Paul _________________ '87 Syncro 7-Pass. Adventure Touring Vehicle
"Simplicate, then add lightness." Colin Chapman |
Posted: Thu Jun 23, 2011 5:56 pm Post subject: |
trying to figure out how these truck style mirrors mount at the top ???????....any help, pic s etc, can't seem to "see" how there meant to fit with the plastic spacer etc ??????????
Thxs _________________ 1991 Syncro Westy- 2.5 Suby
Posted: Thu Jun 23, 2011 7:45 pm Post subject: |
They just screw into the door frame, Dad said the holes were a little tricky to get lined up right but once the bottom was in you could see how it went together. You sure you have the right plastic spacer?
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18761 Location: Retired South Florida
Posted: Fri Jun 24, 2011 7:33 am Post subject: |
I ended up using stainless countersunk sheet metal screws from the hardware store. I remember looking at the grommet for a while before drilling any holes. I covered the window frame area with masking tape, marked my holes and then removed the mirror to drill. I have access to riv-nuts, but as mentioned they require a pretty good size hole. There has been no indication after a few years that the sheetmetal screws were a bad decision. Measure twice drill once. With sheetmetal screws, after you drill your hole, take a center punch and dimple the area "slightly" around the hole. From experience that seems to help. A little touchup paint or silicone to keep water from rusting the bare metal. |
Posted: Fri Jun 24, 2011 7:09 pm Post subject: |
Got my mirrors mounted and all figured out...look great !!!, just need to find some suitable sheet metal screws to secure the top mount- any idea on what size etci shouls ask for at the fastener/hardware shop ??
ajdenette Samba Member
Joined: February 15, 2009 Posts: 768 Location: Hope Valley RI
Posted: Fri Jun 24, 2011 7:30 pm Post subject: |
Though I have yet to get up to my van to try and install these mirrors (they showed up Tuesday at my apartment and my van currently lives at my parents house still ) Van Cafe sent some extra hardware and I figured out how the seal goes which I think is part of the bewilderment.
The top Hardware:
Kind of screwed together
Me holding the upper gasket in place
And a picture of the mirror because they look so awesome
_________________ 1985 2wd Westy with 2000 Subaru 2.2 current driver
https://www.thesamba.com/vw/forum/viewtopic.php?t=685635
1986 Syncro Doka Project next in line
https://www.thesamba.com/vw/forum/viewtopic.php?t=732777
1990 Vanagon Syncro Base awaiting body work |
Posted: Fri Jun 24, 2011 7:37 pm Post subject: |
thanks for the pics- what about the other 2 screw holes on the top mount ???....any idea what size screw to buy for them.... _________________ 1991 Syncro Westy- 2.5 Suby
Posted: Fri Jun 24, 2011 7:54 pm Post subject: |
Well, Van Cafe sent 4 of those screws for the 2 parallel holes the perpendicular hole needs a slightly longer screw it just happened to hold the gasket in places I could get my fat fingers out of the pic and it gave a good idea of the length of the screws they sent. The other screw would need to e a little longer to go through the mirror through the gasket and have some real hold into the metal of the door. Sunday when I attempt to install the mirrors I will try to get the last screw and try to get more pictures of the actual install, unless, others report leaving that screw out without issues. _________________ 1985 2wd Westy with 2000 Subaru 2.2 current driver
