Almost Alive Samba Member
Posted: Wed Jan 04, 2012 7:44 pm Post subject: Make your beat VW engine case look like new. My process. |
Before and after.
Step 1: Degrease in a bath of mineral spirits and lacquer thinner.
Step 2: Seal off all oiling holes, lifter bores and distributor drive shaft bearing surface with duct tape.
Step 3: CAREFULLY walnut blast.
Step 4: I remove the tape then use a blower attachment modified with a pickup tube attached to an air compressor hose to shoot the MS and LT mix at the case making sure the mix flows through the oiling holes without issue. Then dry the case with the blower attachment.
Step 5: Prep all sealing surfaces and bearing saddles by buffing WD-40 into the case with an extra fine Scotch-Brite pad. For this case, I also did this on the area's you can see exposed in the engine compartment when all of the tin is in place.
Step 6: The buffing will cause the WD-40 to turn a dark color and get on the case, spray it down once more with the MS/LT mix or even a can of brake clean should work okay at this point and then dry.
Step 7: Use a can of brake clean or carb cleaner with a straw and blow through all of your oiling holes until it comes out clear paying close attention to any possible obstruction. After this, it is a good idea to use a white pipe cleaner through the holes. This will help see if you cleared the holes well enough.
Step 8: Spray the entire case down with Gibbs Penetrating oil to seal the magnesium then let sit overnight. After about 24 hours, go back with a clean white cloth and rub in the rest of the oil left on the case. |
thefladge Samba Member
Joined: July 25, 2005 Posts: 1294 Location: Anaheim, CA
Posted: Wed Jan 04, 2012 8:08 pm Post subject: |
Wow! Looks good. _________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Wed Jan 04, 2012 9:17 pm Post subject: |
now pull ALL the gally plugs& oil pick up plug and kleen the crap out of it,ream&tap for plugs, use special reamer&short tap for rear main gally plug so you dont effup the cooler bypass valve chanel/cylinder. then kleen off all the oil real good in your wifes dish washer,lightly etch the entire case by dunken in a barrell of water&about 10% aluminum prep, for about20-30 sec up & down to get it all then dunk in another barrell of kleen watter for 3 min up & down to rince, do it again in another kleen barrell of watter to be sure it is kleen ,hose it off real good then dunk in a barrell of alodine & water soultion,about 75% alodine, dunk up & down for about 5 min,let set about 3 more then swish it around some to be sure it is everywhere. pull it out and rince it good,(yes I know rinse is speeled rong), dry with a kleen oil free air sorce, heat to about 100 degrees to make sure all the watter is gone then use some clear engine paint & paint the thing.(the painting is optional, but you will like the looks of it)you can change the time in the alodine to taylor the color you want, from greentint to gold to blue to purple/blue,and possiably more the longer it stays in, and say good buy to crosion, you can also do all of your aluminum the same, try not to get any steel in the alodine, as it will make the stuff blue faster.I have some that are bright gold, some satin nickel, some blue,some greenish like the oe color was on my new as21 case. it is great on valve covers&intakes,I want to do my carbs but they run so good for the past 8 years I dont want to eff with them (empi hpmx 44's of corse)
or you can leave it as it is and have a dull fur ball in a few weeks. you can also sand the case before doing it.I have a set of empi vc's that look like they have the big flakes of galvinize in them with a gold tint. |
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Wed Jan 04, 2012 10:00 pm Post subject: |
Glass beads work well too. It all comes down to how well you clean it afterward. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
&Dan Samba Member
Posted: Wed Jan 04, 2012 10:15 pm Post subject: Re: Make your beat VW engine case look like new. My process. |
Dang! That looks T-Riff. |
Posted: Wed Jan 04, 2012 10:27 pm Post subject: |
Eaallred wrote: |
Glass beads work well too. It all comes down to how well you clean it afterward. |
The walnut is very tedious but it certainly does not take too much away. I'm sure glass bead would work just as well though I'd probably drop my air pressure a hair. |
JustBuggy Samba Member
Joined: August 01, 2010 Posts: 851 Location: SF Bay Area, Ca.
Posted: Wed Jan 04, 2012 11:44 pm Post subject: |
The walnut blasting does make it look clean but ,........
Is there any way to make the cases kinda shiny like semi polished looking without hand buffing? |
modok Samba Member
Joined: October 30, 2009 Posts: 27713 Location: Colorado Springs
Posted: Thu Jan 05, 2012 12:26 am Post subject: |
That's pretty cool
Ask any bearing, they'll tell you they'd rather eat a walnut than a glass bead
They are blind, but some of them can talk..... if you smoke some white rhino and listen real close  |
torsionbar Samba Member
Posted: Thu Jan 05, 2012 7:59 am Post subject: |
modok wrote: |
lmao! yeah i'd never use glass bead on an engine case. you just know there's going to be some little piece left over somewhere just waiting to do the nasty with your main bearings. _________________
Max Welton wrote: |
[air cooled vw's] are no longer suitable for the general public. The owner has to be be able to maintain the car. And that is after fixing all the deferred maintenance items and ill-conceived modifications. If you can't do those things you are pretty much screwed. |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6149 Location: CONGERS, N.Y.
Posted: Thu Jan 05, 2012 9:09 am Post subject: |
Aluminum blocks you can make look like chrome. I know some T-1 blocks are Aluminum but all the T-4 blocks are.
In my case seeing I am using all T-1 upright fanhousing parts, it don't matter because most of the case is hidden.
On a stock 914 with dual carbs Most of the upper parts of the case is visable and when you open the hood between the two carbs is a large area of very shiny alum. if you polishi it.
But doing what you did before polishing is the way to go. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20836 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Jan 05, 2012 10:24 am Post subject: |
What about "soda" blasting or "dry ice" blasting... Cool thing (pun not intended) is with dry ice blasting is all that is left over is the "crud" removed from engines.... Once dry ice "melts" there is not much left but the "dirt"...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
Posted: Thu Jan 05, 2012 10:58 am Post subject: |
hmm wonder why,nobody has said not to polist the case du to the heat retention it will have??? somebody's sleepen late.the soda blasting does look nice too. |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Thu Jan 05, 2012 11:07 am Post subject: |
torsionbar wrote: |
modok wrote: |
lmao! yeah i'd never use glass bead on an engine case. you just know there's going to be some little piece left over somewhere just waiting to do the nasty with your main bearings. |
I would never use glass bead on a case. That's just asking for trouble. After the latest PR move by Pepsi, I bet soaking the case in Mountain Dew would work......they did say it would dissolve a mouse.  |
slalombuggy Samba Member
Posted: Thu Jan 05, 2012 11:24 am Post subject: |
Wasn't there somone last year who posted pictures of his engine parts chewed to rat sht beacause he blasted the case with glass beads and didn't clean it good enough????? I's use soda or dry ice or just a good cleaning and shot of ghetto chrome in aa can......
brad |
67Callooker Samba Member
Joined: January 24, 2008 Posts: 158 Location: las vegas
Posted: Thu Jan 05, 2012 11:29 am Post subject: |
step one take case to rimco
step two pick up case from rimco  |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11086 Location: Black Forest, CO
Posted: Thu Jan 05, 2012 12:28 pm Post subject: |
Dale M. wrote: |
What about "soda" blasting or "dry ice" blasting... Cool thing (pun not intended) is with dry ice blasting is all that is left over is the "crud" removed from engines.... Once dry ice "melts" there is not much left but the "dirt"... |
i've never used dry ice, but i've seen excellent results from soda blasting aluminum and magnesium engine parts. soda is a great way to go. _________________
Max Welton wrote: |
Dangermouse Samba Member
Joined: November 23, 2005 Posts: 1320 Location: Beautiful New Zealand
Posted: Thu Jan 05, 2012 6:41 pm Post subject: |
slalombuggy wrote: |
brad |
Yup
http://www.thesamba.com/vw/forum/viewtopic.php?t=451541
I used soda on mine, very acceptable result. Not shiny but damn clean. A dunk in water and any residue is gone. Followed it up a coat of Gibbs penetrant and it's held up beautifully since. _________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
Posted: Thu Jan 05, 2012 7:24 pm Post subject: |
Back in the 70's I was a total VW Freak and did what to a normal un vw nut as freaking crazy. I stripped my T1 case down placed the two halfs in my newly moved into, recently married garden apt. shower stall and took a can of Gunk and got naked and took a shower with the case while cleaning it with a brush. Sounded like a good idea till my wife came home and smelled the Gunk. I am married 43 years and that one aways comes up. I think my left ear got blasted so loud by my wife I have hearing loss,ha. _________________ email: [email protected]
Posted: Thu Jan 05, 2012 7:26 pm Post subject: |
I think you crossed a line with that one, that beats the dishwasher hands down. _________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
