Tintop to Westy pop top conversion
Page: 1, 2, 3  Next
FNGRUVN
FNGRUVN is offline
PostPosted: Thu Mar 08, 2012 10:36 pm    Post subject: Tintop to Westy pop top conversion Reply with quote
I figured a another pop top conversion thread couldn't hurt so here goes.
I scored a westy roof and pop top last summer from some gal that bailed on her project and I'm just now finding the time to start on mine. Yesterday, I pulled the headliner and the A/C stuff out and today I took the plunge and made the first cut into the roof.
I'm following in syncrogreg's footsteps here. He was good enough to post up pictures of his project. At first I couldn't figure out why he cut out the center section when he ended up attaching the westy roof to the outer edge next to the rain gutter. I'm guessing he did this so that he could set the westy roof in place and then mark around the edge so that his cut would line up perfectly with the westy roof. This would make the job of welding it in place a lot easier.
I used a center punch from inside to make two dents, about two inches apart, in the roof parallel to the inner roof frame. I used these dents to mark a line on the top of the roof so that I could use a cutoff wheel to start my cut. I made the cut just long enough for a sawzall blade to fit in. I used my sawzall from inside the van to cut along the inner roof frame. I had to use the center punch/cutoff wheel method to go around the corners and on either side of the roof braces. It went pretty quick. I had a really big sunroof in no time at all.
Tomorrow, I plan on cutting out the rear roof brace, prepping the donor roof and at least setting it in place. In the mean time, I'll be glad to take more pictures if anyone has any requests for specifics. I'd wouldn't mind any suggestions or constructive criticism.
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
westfailed
westfailed is offline
PostPosted: Fri Mar 09, 2012 4:04 am    Post subject: Reply with quote
There is no turning back now good work
Syncroincity
Syncroincity is offline
PostPosted: Fri Mar 09, 2012 4:28 am    Post subject: Reply with quote
Panoramic roof option!
Save that metal, best thing ever for patch panels. Cool
'86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight=
rubbachicken
rubbachicken is offline
PostPosted: Fri Mar 09, 2012 6:01 am    Post subject: Reply with quote
x2
lucy our westy
lucy's BIG adventure
meet 'burni'
randywebb
randywebb is offline
PostPosted: Fri Mar 09, 2012 4:59 pm    Post subject: Reply with quote
do you have the additional roof braces to weld in?
1986 2.1L Westy 2wd Auto Trans.
FNGRUVN
FNGRUVN is offline
PostPosted: Fri Mar 09, 2012 6:19 pm    Post subject: Reply with quote
Which ones are you talking about?
DLJ
DLJ is offline
PostPosted: Fri Mar 09, 2012 6:49 pm    Post subject: pop top camper conversion Reply with quote
Dont getg all hung up on roof braceing. Use the stock cross brace from the donor. Weld and your same as stock
edgood1
edgood1 is offline
PostPosted: Fri Mar 09, 2012 6:56 pm    Post subject: Reply with quote
no additional braces are required. the "C" pillar brace on a westy is different, but theres no problem keeping the one you got if you build around it.
BUT... i don't see how its possible to swap the westy brace in without tearing out the whole roof skin at the rain gutters...there are support gussets under there that are welded in.
1987 Syncro Westfalia powered by Subaru
'65 Westfalia
FNGRUVN
FNGRUVN is offline
PostPosted: Fri Mar 09, 2012 7:12 pm    Post subject: Reply with quote
I took advantage of some really nice weather we're having and got the donor roof fitted by the end of the day like I hoped.
I started this morning on the donor roof. I had to trim it down so that the new edge would be in the crease just above the rain gutter.
After figuring out where I wanted to make my cuts and marking the cut lines, I used a 4 1/2", thin cut-off wheel to cut along the line. I went through quite a few wheels today, but got it all trimmed out.
Next, I cut out the rear brace. I used a spot weld cutting bit to cut around each spot weld and an old wood chisel to pry the brace away from the body.
In the next picture you can see part of the brace that is sandwiched between the inner roof frame and the roof skin. I plan on welding the edge of this brace to the inner roof frame. I hope this will add a little strength.
Next, I marked and cut along the crease just above the rain gutter. I stopped a little short of both ends. I didn't want to make these cuts just yet. All I wanted to do was get the two side strips cut out so the donor roof would sit down almost where it will be when finished. In the next picture you can see that brace that I need to weld.
Once the side strips were gone I was able to set the donor roof in place. The donor roof overlapped the van's roof at the front and rear. I marked where it overlapped, removed the donor roof, and made my cuts.
I did this a couple of times until I was happy with the fit.
Tomorrow I plan on cleaning up the edges, doing some more prepping on the donor section, welding up that brace, welding in the two brackets for the topper hinges, and hopefully start tacking the donor in place. I have to hurry. Syncro Solstice is right around the corner.
ajdenette
ajdenette is offline
PostPosted: Fri Mar 09, 2012 7:37 pm    Post subject: Reply with quote
I am Glad I have just been sitting on the parts to do this and have not startedyet this is a VERY clean install method. This willmean not dealing with the front and rear brazed sectins or the top of the windshild, and if we could get our hands on the west atlantic aero piece we wouldnt have to worry about the holes for the stock westy luggage rack.
1985 2wd Westy with 2000 Subaru 2.2 current driver
https://www.thesamba.com/vw/forum/viewtopic.php?t=685635
1986 Syncro Doka Project next in line
https://www.thesamba.com/vw/forum/viewtopic.php?t=732777
1990 Vanagon Syncro Base awaiting body work
FNGRUVN
FNGRUVN is offline
PostPosted: Fri Mar 09, 2012 7:47 pm    Post subject: Reply with quote
The holes shouldn't be a problem. Today, before I made the first cut, I measured off from the front of the first hump and the rain gutters to each bolt and wrote it down. When I get to this point I'll tack the brackets in place with a tiny weld so I can make sure they're positioned correctly before I drill the holes.
freshintulsa
freshintulsa is offline
PostPosted: Fri Mar 09, 2012 8:03 pm    Post subject: Reply with quote
Looking good Rick! How are you liking the h-6? Keep posting pics of the roof swap. Looking forward to your interior too, I'm sure you have some good ideas for that.
Doug
"go slower, go lower!!!"
85 westy svx
Fresh front end rebuild
Front cab changed from brown to black with new homemade door panels, etc.
Soon to remove fridge/sink/cabinet and make custom bench seat!!!
89 wolfsburg/ bluestar.... finished the stick to automatic conversion,
tiico motor
Daily driver, 20mpgs and has enough hair in it to make a few dogs.
ajdenette
PostPosted: Fri Mar 09, 2012 8:04 pm    Post subject: Reply with quote
I did not think locating the the hole for the stockluggage rackwould be a problem, I was refering to the more aerodynamic cap.
Brickwerks wrote:
All the pop top models have the later style “aerodynamic” cap on the cab with no luggage rack (leaf catcher)
pic taken from this thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=456545&highlight=atlantic
greggearhead
greggearhead is offline
PostPosted: Fri Mar 09, 2012 8:32 pm    Post subject: Reply with quote
Nice work!
1972 Porsche 911E Hot Rod (3.4 Turbo)
1973 VW 412
1979 Audi Fox GTI
2002 Eurovan
Period Lights, VW & Porsche wheels and Recaro/Scheel Seats for sale
https://www.facebook.com/greggearhead
http://greggearhead.com/soco-swap---september-vw-swap-meet.html
shadetreetim
shadetreetim is offline
PostPosted: Fri Mar 09, 2012 10:42 pm    Post subject: Reply with quote
Nice write up. Your work is looking good. Thanks for sharing. I may have to do this myself in the future.
Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5
SL12572
SL12572 is offline
PostPosted: Fri Mar 09, 2012 10:59 pm    Post subject: Reply with quote
Looks great! I wish you lived in Washington, so we could convert our vans side by side. Id let you make the first cut though Smile.
So if I'm seeing this correctly, the front portion of the vans roof is left in place? I was under the impression that a tin top was a domed roof and the westy was a flat roof. Does the donor westy roof line right up and blend in with the forward tin top roof?
I'm also having a hard time visualising where you would make the cuts in the front and aft. Is there a measurment, body line to use, or is it just a make it up as you go?
I recently got a 82 Westy Diesel that will be used for the conversion. Im just trying to learn as much as possible before I attempt to tackle this.
Keep up the good work and thanks for documenting it!
Scott
specialev
specialev is offline
PostPosted: Fri Mar 09, 2012 11:48 pm    Post subject: Reply with quote
Top work! I'll be watching closely. Thanks for documenting your work. On my list of things to do, just gotta find the right donor van to scrap out.
FNGRUVN
FNGRUVN is offline
PostPosted: Sat Mar 10, 2012 8:45 am    Post subject: Reply with quote
Thanks for all the nice comments and moral support.
Hey Doug, the H6 is friggin' awesome! 80 mph the other day with a stiff headwind. I have plans for the interior but that might have to wait.
Scott - The front of a tin top and Westy are the same, starting at the first crossover brace. You can join them up anywhere in front of the holes for the back of the luggage rack. The rear is a little different. Your cut has to be behind the rear bolt hole for the pop top hinge. There's an indentation in the roof skin where the hinge bolts up. I made my cut 2 1/2" behind the rear bolt hole. This was far enough back to allow the skins to line up but close enough to be under the pop top to hide any signs of the weld.
jstar89crx
jstar89crx is offline
PostPosted: Tue Mar 13, 2012 7:09 am    Post subject: Reply with quote
Is there a backing plate with nuts on it or are the nuts for the poptop rear hing attached directly to the underside of the donor roof? In the picture it just looks like holes with no threads inside. Keep the pictures and notes coming! Looks great so far!
FNGRUVN
FNGRUVN is offline
PostPosted: Tue Mar 13, 2012 8:18 am    Post subject: Reply with quote
jstar - Here's some pictures to answer your question. I tried to post them up last night but ran out of time.
I worked on this all weekend but it doesn't look like I got much done. All the stupid little time consuming details.
I started by welding up that rear brace that I cut out. Not sure if this step is needed, but I figured it couldn't hurt.
Next, I prepped the pop top hinge brackets. The nuts that are on the back side are just spot welded in place from the factory. I knew with my luck one of the nuts would break loose when I got the roof welded in place so I took this time to tack weld the nuts. Belt and suspenders.
My first attempt at tacking the brackets in place came up a little short. I wasn't really happy with their alignment in relation to the roof skin. I just set the roof in place and used a sharpie to mark where the center of the nuts would be. This will allow the nuts to line up with the holes in the skin, but doesn't really tell you how high or low to set it. Set it too low and there's a gap between the bracket and the skin. This will cause the skin to dent in when you tighten the hinge bolts. Weld it in too high and the edge won't line up.
My second attempt I bolted the brackets to the roof skin and put several little blobs of that black goo (that's stuck to the roof braces) on the underside of the brackets. My plan was to set the roof in place and then unbolt the brackets from the roof and then remove the roof, leaving the brackets stuck in place. This worked like a charm. I then marked the outline of each bracket, removed the goo, and then tacked the brackets in place. Set the roof back in place and checked the alignment.
The rest of the weekend was spent prepping the donor section and the areas of the van where all the welding will be. Anywhere that would be welded that wouldn't be accessible after assembly got sanded down to bare metal and then primed with weld-thru primer. The rest of the underside of the donor got sanded, primed, and painted.
Does anyone know why there's an extra layer of sheet metal on the passenger side rail and not the driver's side. You can see what I'm talking about in these two pictures.
Page: 1, 2, 3  Next
