Converting non fuel injected 72 type 4 to fuel injection
spaine
spaine is offline
PostPosted: Sun Jan 25, 2015 9:38 pm    Post subject: Converting non fuel injected 72 type 4 to fuel injection Reply with quote
I am looking for some guidance on this topic and am not finding much through searching.
I have a 72 type 4 buss and would like to go with fuel injection. I am looking at some complete kits off of 78 busses but I know there is a displacement difference. I also know that I will need to figure in a fuel return line to the tank. Otherwise, will it work? will I have to go with smaller injectors? Any other concerns?
Thank you.
64 Beetle
72 Westfalia
72 Super with Autostick
71 Squareback
Tcash
Tcash is offline
PostPosted: Sun Jan 25, 2015 10:02 pm    Post subject: Reply with quote
Thanks to Mayor Ratwell
http://www.ratwell.com/technical/FISwap.html
This might help
Tcash
Bleyseng
Bleyseng is offline
PostPosted: Mon Jan 26, 2015 7:58 am    Post subject: Reply with quote
It will work fine but you should adjust the AFR once you are done installing it. Locate the aircleaner stand off a junk bus and weld it in to hold the AFM/aircleaner securely in place.
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
spaine
spaine is offline
PostPosted: Mon Jan 26, 2015 8:08 am    Post subject: Reply with quote
Glad to hear this is doable. I'm going to move forward with this once I have sourced all of the components.
In another thread, I saw that someone had found what looked like a reproduction of the AFM stand. I am looking around for this but not finding it yet. Has anyone seen one of these available? I do not have access to junked busses in my area to pull one from.
64 Beetle
72 Westfalia
71 Squareback
Wasted youth
Wasted youth is offline
PostPosted: Mon Jan 26, 2015 8:09 am    Post subject: Reply with quote
You will also need to cut out the rectangular slot that the ECU anchors into.
spaine
spaine is offline
PostPosted: Mon Jan 26, 2015 8:19 am    Post subject: Reply with quote
Wasted Youth: Thanks, I'll see if I can find some pictures to detail what I need to cut. And as a side note, I spent many a years in Clovis - loved that valley oven fresh air!
64 Beetle
72 Westfalia
71 Squareback
spaine
spaine is offline
PostPosted: Mon Jan 26, 2015 8:25 am    Post subject: Reply with quote
Rustbus did a similar conversion and had this picture which shows the ECU cut out:
And it is this shot that shows the aircleaner bracket that I am looking for. I PM'ed Rustbus to see where he got it:
64 Beetle
72 Westfalia
71 Squareback
Wasted youth
PostPosted: Mon Jan 26, 2015 9:25 am    Post subject: Reply with quote
That's cool! I would like to do the same thing to my 1973 bus. I was very happy with the performance of my 1977 bus when I had it.
Yeah... great air quality! Mad
Randy in Maine
Randy in Maine is offline
PostPosted: Mon Jan 26, 2015 9:38 am    Post subject: Reply with quote
I trust you already have the Temp Sensor II figured out?
Bleyseng
Bleyseng is offline
PostPosted: Mon Jan 26, 2015 9:52 am    Post subject: Reply with quote
Temp 2 sensor is easy as you just drill and tap the tin hole on #3 cylinder like stock.
[email protected] has the a used stand and other FI parts. email him
vwwestyman
vwwestyman is offline
PostPosted: Thu Mar 10, 2016 6:04 am    Post subject: Re: Converting non fuel injected 72 type 4 to fuel injection Reply with quote
I'm adding FI to my '73.
That project is alongside working on rust in the window channels, but my comments start on page 3 of my build thread.
Dave Cook
1973 Wild Westerner
My Thing
Wildthings
Wildthings is offline
PostPosted: Thu Mar 10, 2016 8:26 am    Post subject: Reply with quote
If I were going to drill out one of the tin hole screw holes, I would go with the one for the #4 cylinder. Might as well make the TSII as easy to access as possible. Wink
