spaine Samba Member
Joined: March 30, 2009 Posts: 104 Location: Santa Rosa, CA
Posted: Sun Jan 25, 2015 9:38 pm Post subject: Converting non fuel injected 72 type 4 to fuel injection |
I am looking for some guidance on this topic and am not finding much through searching.
I have a 72 type 4 buss and would like to go with fuel injection. I am looking at some complete kits off of 78 busses but I know there is a displacement difference. I also know that I will need to figure in a fuel return line to the tank. Otherwise, will it work? will I have to go with smaller injectors? Any other concerns?
Thank you. _________________ 64 Beetle
72 Westfalia
72 Super with Autostick
71 Squareback |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
Bleyseng Samba Member
Posted: Mon Jan 26, 2015 7:58 am Post subject: |
It will work fine but you should adjust the AFR once you are done installing it. Locate the aircleaner stand off a junk bus and weld it in to hold the AFM/aircleaner securely in place. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
spaine Samba Member
Posted: Mon Jan 26, 2015 8:08 am Post subject: |
Glad to hear this is doable. I'm going to move forward with this once I have sourced all of the components.
In another thread, I saw that someone had found what looked like a reproduction of the AFM stand. I am looking around for this but not finding it yet. Has anyone seen one of these available? I do not have access to junked busses in my area to pull one from. _________________ 64 Beetle
72 Westfalia
71 Squareback |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5173 Location: California's Hot and Smoggy Central Valley
Posted: Mon Jan 26, 2015 8:09 am Post subject: |
You will also need to cut out the rectangular slot that the ECU anchors into. |
spaine Samba Member
Posted: Mon Jan 26, 2015 8:19 am Post subject: |
Wasted Youth: Thanks, I'll see if I can find some pictures to detail what I need to cut. And as a side note, I spent many a years in Clovis - loved that valley oven fresh air! _________________ 64 Beetle
72 Westfalia
71 Squareback |
spaine Samba Member
Posted: Mon Jan 26, 2015 8:25 am Post subject: |
Rustbus did a similar conversion and had this picture which shows the ECU cut out:
And it is this shot that shows the aircleaner bracket that I am looking for. I PM'ed Rustbus to see where he got it:
72 Westfalia
71 Squareback |
Posted: Mon Jan 26, 2015 9:25 am Post subject: |
That's cool! I would like to do the same thing to my 1973 bus. I was very happy with the performance of my 1977 bus when I had it.
Yeah... great air quality!  |
Randy in Maine Samba Member
Posted: Mon Jan 26, 2015 9:38 am Post subject: |
I trust you already have the Temp Sensor II figured out? |
Posted: Mon Jan 26, 2015 9:52 am Post subject: |
Temp 2 sensor is easy as you just drill and tap the tin hole on #3 cylinder like stock.
[email protected] has the a used stand and other FI parts. email him _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5828 Location: Wamego, Kansas, USA
Posted: Thu Mar 10, 2016 8:26 am Post subject: |
Bleyseng wrote: |
[email protected] has the a used stand and other FI parts. email him |
If I were going to drill out one of the tin hole screw holes, I would go with the one for the #4 cylinder. Might as well make the TSII as easy to access as possible.  |
