1966 Type 3 Squareback Build Thread
Bobnotch
Bobnotch is offline
PostPosted: Thu Feb 19, 2015 9:01 am    Post subject: Reply with quote
lakedawgs wrote:
I am guessing you mention leaving the doors and hatch on for structure.
After some comments I will likely not remove the body from the car. While I want to get the car right, I'm not looking for a 100 point car. I will decide if the body comes off down the road after most rust and rockers are repaired.
I'd leave the doors on, as I like to be able to check alignment as I go (especially when doing a body on). It helps you set the gaps, both up and down, along with end to end (see Jack's Notch, or Monte's Square for example).
On Jacks car, he needed to remove more metal up front to close the gap, along with doing the same at the rear (his gap along the bottom of the door was too large).
In Monte's case, he had to re-install the doors first, then found he had to move both ends up a little to get the rocker in the right position. Monte also found that his "replacement" rocker skins (full length) were deeper (longer in the cross section) than the stock skins were. This meant he had to add a strip of metal to tie in his outer skin to the inner part. This problem was only found after he had the inner made going off the original pieces, and not from the replacement part. Shocked This isn't normal, but does happen. The CIP skins I've used fit like the orignials.
But, before you remove the old rocker/heater channel assembly, and fenders, get the doors aligned so the gaps are consistant (a problem Clatter ran into on the left side of his Fastback). Once you're happy with that, then remove the "bolt on parts", so you can do your cutting and welding. I'd add a brace across the bottom of the opening, about 6 inches above the existing rocker assembly,before cutting the entire piece out. This way, you're aligning parts to known spots, that when you're done should re-align like they were when you started.
Now, IF you're only doing skins, you don't have to get that carried away. I say that, as everything will be sill mostly tied in, and the skin is just that, a skin.
Just my take on it, YMMV. I hope this helps.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Mike Fisher
Mike Fisher is offline
The doors/hatch usually don't need serious work. You need the doors on to be sure your gaps are good. The car is still plenty stiff without them though! Cut 80% of your bad pans out first. Leave what you can on the front/rear. You can then weld in the new rockers/inner fenders using you pans as a guide to make sure they will still bolt up correctly when you weld the pans in last.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
lakedawgs
lakedawgs is offline
PostPosted: Thu Feb 19, 2015 9:08 am    Post subject: Reply with quote
Pans will stay on, only changing the rockers. Got full length ones cut from a '66 Squareback. They need a bit of clean up but for $185 shipped for the pair I feel like a got a deal. Should get them in a couple of weeks. I am going to attack other areas of rust and some small patches to learn before I cut out my old rockers, or what little is left of them.
Like a lot of other areas of the county we are getting pounded with the cold right now, -7 tonight!! My detached, uninsulated, unheated garage is not too inviting right now except for tinkering. Hopefully in a couple of weeks I can start getting the rust flying.
Bobnotch
Bobnotch is offline
PostPosted: Thu Feb 19, 2015 9:18 am    Post subject: Reply with quote
I hear that statement a lot. But, after getting in to a certain point, most people dig deeper (like Brent, Pedro, Clatter, Monte, or Tram), and you end up with more time and money into it than planned (I'm guilty of that too). I'll be the first to tell you, it's not hard to get into a deep hole quick with these cars. I can see where Mike is coming from (he's old too Wink ), as you can get 1 apart easy enough, but putting it back together IS the hard part, and that's what takes the most time. I say that, as things that were ok, or looked good when you got it, suddenly look like crap after it's painted. That's just part of the deal.
Now, I'm not saying it has to be completely gone thru for you to enjoy it, but IF you do go thru it, it'll be that much more reliable.
Tram wrote:
Tram wrote:
Bobnotch
Bobnotch is offline
PostPosted: Thu Feb 19, 2015 9:27 am    Post subject: Reply with quote
lakedawgs wrote:
Pans will stay on, only changing the rockers. Got full length ones cut from a '66 Squareback. They need a bit of clean up...
Ok, so you're replacing the entire rocker assembly/heater channel assembly (wasn't sure which way you were going). Definitely do it on the car, and take some of the advice I gave above in my earlier post from today. Wink
I hear you, it wasn't much warmer here this morning (-6*F). Between the super cold, and the foot plus of snow on the ground, I'm not doing much of anything out in the shop (my beer is even trying to freeze sitting on the lawn mower Shocked ).
Tram wrote:
Tram wrote:
lakedawgs
PostPosted: Thu Feb 19, 2015 9:42 am    Post subject: Reply with quote
Owned a few VWs and other interesting cars when I was young and dumb. Now I am older and wanting to learn and get this one right and not get it on the road as soon as possible and drive it in to the ground. It also helps to be fortunate enough to have a two car garage dedicated to this car, with a small corner dedicated to my beer homebrew rig.
I guess it is good that it is winter when I got this car. Gives me time to educate myself and not jump in and possibly do more damage to the car by doing something stupid.
Question about the rockers. Even though I won't be doing them for a while. The heater tubes run inside the rocker panels right? How do I connect the heater tubes before I weld the rocker panels? Rubber tubing or something.
Mike Fisher
PostPosted: Thu Feb 19, 2015 10:06 am    Post subject: Reply with quote
Those propane turbine heaters & work gloves can make it comfortable inside if you want to get it finished ASAP.
lakedawgs
PostPosted: Thu Feb 19, 2015 10:20 am    Post subject: Reply with quote
Not at all, the rocker install will come much down the road but I was just wondering.
Mike Fisher
PostPosted: Thu Feb 19, 2015 10:44 am    Post subject: Reply with quote
I hope you bought 'cut to order' rockers with any front/rear inner fender you need attached to them? This one I shipped to Nova Scotia.
lakedawgs
PostPosted: Thu Feb 19, 2015 10:56 am    Post subject: Reply with quote
Mine do not have the whole pillar. The are cut down just past it.
MonT3
MonT3 is offline
PostPosted: Thu Feb 19, 2015 11:19 am    Post subject: Reply with quote
Hi Lakedawgs. Welcome to the community. There's a lot of good information, advice and examples of that you are going to facing when replacing your rockers. I did a complete replacement but rather than finding donors, as bobnotch mentioned, I got the outer skins and had the remainder fabricated. Being that you'll be doing this with the pan attached, it'll be easier for you. Study your cars lines and the corner as well as what you can work with and what you feel you want or may need to replace. Especially the area under the door hinge. If you're planning on going under the door hinge, you'll facing three pieces of formed metal there unlike the back of the door jam. There's some inner structural work that you may want to plan for. It's a tricky and tuff area to deal with. A straight across cut and weld in is only going to get the outer skin piece. If you get that chance, half-way down pg 27 on my 67 thread is what I'm trying to explain. You can go thru the remainder on the rockers and door alignment, etc.
Post more pics of your areas as a lot of people will give some great pointers on how to deal with some of the issues you may encounter. Look forward to reading up on your progress.
MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild
lakedawgs
PostPosted: Thu Feb 19, 2015 11:46 am    Post subject: Reply with quote
Thanks MonT3,
I have been studying your thread and others. That is why I want to work on some other rust spots and repair before I tackle the rockers.
Need to get some experience on the basic stuff before I move on the more difficult stuff.
lakedawgs
PostPosted: Thu Feb 19, 2015 8:19 pm    Post subject: Reply with quote
MonT3 and Bobnotch, had a bit more time to really study your build threads and I must say, with the utmost respect, you are both F'ING madmen. Between you both and about a 1000 other users on this forum, I am excited to know this car is gonna get done eventually.
Starting with easy rust repair will be....easy. I bought a crappy wire welder a few months ago and will get a good education with some scrap metal I have and the small patch rust spots I need to fill. Larger stuff, like the rockers, will take the help of a buddy with a nicer welder.
Still overwhelmed with questions but I am getting better about searching THE SAMBA before I post a question.
Mike Fisher
PostPosted: Fri Feb 20, 2015 4:50 am    Post subject: Reply with quote
I always take the 4 fenders off first. The headlight wiring is kind of hard to get loose & there is a small phillips head screw hidden under the hatch rubber, but you'll figure it all out at your own pace! Cool
lakedawgs
PostPosted: Fri Feb 20, 2015 5:06 am    Post subject: Reply with quote
I took the driver side fenders off last week. Wiring was a bit tricky. Took a couple of pics, clipped the leads and labeled and baggied everything. Once I get the passenger side fenders off I will store them.
Mike Fisher
PostPosted: Fri Feb 20, 2015 5:42 am    Post subject: Reply with quote
Don't be scared of the heater channels. I wish I still had pics of the nice job 'nassau' did installing this heater channel in his square. He told me he was an absolute beginner when he started. There is just cutting,grinding,test fitting until it's ready for a good welder to weld in.
lakedawgs
PostPosted: Fri Mar 06, 2015 5:00 pm    Post subject: Reply with quote
Have been out of town on business and still stupid cold here so not much going on but did remove the brake master cylinder. Previous owner had a new one in the box so I thought I would change it out. Removed the old one and it does not match the new one......
The new one is a Varga, marked on the master cylinder, VFCC 1318-8. Research tells me this will fit a '66 Bug, not sure what else. Need to research more and sell it.
Only marks on the old one are a 79 and a 6.
Here is a pic of the old unit taken apart. Is it possible to buy a rebuild kit for these? Looks like it would be very easy to rebuild.
Here is a pic of the two units together. The brake line ports on the new unit come out the top, ports on the old unit come out the bottom. Also, the brake pedal end is obviously longer on the old unit.
Here are close up pics of the numbers on the two units. Old unit first, new unit second.
Thanks
lakedawgs
PostPosted: Fri Mar 06, 2015 6:53 pm    Post subject: Reply with quote
Found this rebuild kit but the piston is 46mm long and mine is about 49mm long. 19mm is correct on the diameter of the piston. Either way, it is out of stock, need to keep looking.
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-111-698-173-A
W1K1
W1K1 is offline
PostPosted: Fri Mar 06, 2015 8:39 pm    Post subject: Reply with quote
I bought my rebuild kit from the local napa
1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap
ataraxia
ataraxia is offline
PostPosted: Fri Mar 06, 2015 8:59 pm    Post subject: Reply with quote
66 is a one year only single disc brake master cylinder
Different part than a 65 (drum brakes) or a 67 (dual master disc)
Page 3 of 4
