BA6 Heater Install into 1973
vwwestyman
vwwestyman is offline
PostPosted: Wed Oct 21, 2015 5:25 pm    Post subject: BA6 Heater Install into 1973 Reply with quote
I have what seems to be a complete or very nearly complete BA6 heater kit on the way to me that I intend to install in my '73.
I could swear that I had looked at a thread last week that showed with lots of details where all of the components are supposed to go and all that.
But for the life of me, I can't find it again. I don't know if I was searching for something else at the time and happened to find it or what, but I am coming up nada on that today. I did find TypeTooCrazy's thread but that isn't the one I'm thinking of.
Do any of you know the thread I may be talking about? If you post a link, I'll use it when I install mine and also take some pics to add to this thread later.
Dave Cook
1973 Wild Westerner
My Thing
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Wed Oct 21, 2015 5:26 pm    Post subject: Reply with quote
Wasn't that a BN4 post?
Robert in Memphis
Engine rebuild thread
vwwestyman
PostPosted: Wed Oct 21, 2015 5:41 pm    Post subject: Reply with quote
Nope. It may not have been an installation thread, really. It seems like the person just decided to take a lot of pics of all the components of their heater to show where they went and such.
Dave Cook
1973 Wild Westerner
My Thing
obieoberstar
obieoberstar is offline
PostPosted: Wed Oct 21, 2015 5:59 pm    Post subject: Reply with quote
Not sure of the thread of BA6 heaters, but here is pic I took some years ago. Maybe this will help.
Tcash
Tcash is offline
PostPosted: Wed Oct 21, 2015 9:09 pm    Post subject: BA6 Reply with quote
To link to this thread
Code:
[url=https://www.thesamba.com/vw/forum/viewtopic.php?p=7863248#7863248]BA6[/url]
BA6
http://www.ratwell.com/technical/Microfiche/t202720.gif
http://www.ratwell.com/technical/Microfiche/t202730.gif
http://www.ratwell.com/technical/Microfiche/t202800.gif
http://www.jerseylooker.com/FicheDump/LateBaywindow/027-20-2-019.jpg
http://www.jerseylooker.com/FicheDump/LateBaywindow/027-30-2-020.jpg
http://www.jerseylooker.com/FicheDump/LateBaywindow/027-30-2-021.jpg
http://www.jerseylooker.com/FicheDump/LateBaywindow/028-00-2-022.jpg
http://www.jerseylooker.com/FicheDump/LateBaywindow/028-00-2-024.jpg
BA6 PIX
BA6 Replacement Duct - Installed Front View
1977eberspacher wiring diagram
BA6 pictures
My BA6 gas heater install (pic heavy)
Eberspacher BA6 Gas Heater
1977 Eberspacher BA 6 VW Gas Heater Repair Manual
BA6 Wiring Diagram
Eberspaecher BA-6/BN-4 Heater Manuals
VW Workshop Maual: Fresh Air Heating
BA6 fan running but no heat
LT1025 - Micropower Thermocouple Cold Junction Compensator
M557 Gas Heater Clock:
BA6 Heater Relay
BA6 in vehicle lots of pix
BA6 Belly Pan
BA6 Repair Manual
BA6 Heater not run for 10+ years
BA6 Videos notchboy
vwwestyman
PostPosted: Thu Oct 22, 2015 5:09 am    Post subject: Reply with quote
Dang, Tcash! Do you have these threads/subjects already grouped up as files to send to these threads? Very helpful, thanks!
It seems that it was probably the "has not run in 10 years" thread that I was looking for again. I must have clicked it last week but forgot the title, and then looked past it when I was trying to find the thread again thinking that subject matter was not correct.
Dave Cook
1973 Wild Westerner
My Thing
Tcash
Tcash is offline
PostPosted: Thu Oct 22, 2015 10:57 am    Post subject: Reply with quote
Ya it would be nice to have one Topic for each Subject . That way you could open that Topic and (search this topic) once.
Instead of having to open 99 Post and search each and every one of those. A lot of the good stuff is buried in build threads and then you get non related titles ie (Bubus butt cold) as well.
Good luck putting in the BA6. From what I understand they started putting them in t2's in 74.
Tcash
vwwestyman
PostPosted: Sat Oct 24, 2015 2:17 pm    Post subject: Reply with quote
I'm a little apprehensive cutting as much into the Westerner as I'd have to do to install this thing... I didn't realize that a recirc duct cut was necessary, and I didn't realize that the heat tube on a '73 was welded in.
So I decided I'd still spend some time testing it out on the garage floor to see if it needs any repairs, etc. At least then if I sell it, I'll be able to say it works.
I've got most of the parts hooked up to each other, but there are a few pieces of the wiring I'm not sure of. I'm hoping someone can help me out.
Edit: Clearer pic and descriptions in a later post, further down in the thread.
Also, the wires on the safety reset switch: I just matched up the wires to the colors on the diagram. Correct?
Dave Cook
1973 Wild Westerner
My Thing
vwwestyman
PostPosted: Fri Nov 06, 2015 7:26 am    Post subject: Reply with quote
Anyone have any ideas on those wire ends? I took the day off work today and it would be kind of nice to bench test this thing.
For the control/thermostat switch wires, I saw one post that commented that 31 was to be hooked to ground and K was only used if there was a timer clock installed.
Can anyone confirm this for me please?
Also, I think the only part I'm missing is the "flapper box" that is mounted between the factory heater Y and the gas heater, that the recirc fan ducts into.
I'd like to find this to work properly. (If you find/have one to sell, please let me know!)
But in the mean time, I'm thinking I could simply cut the original metal duct further forward, and cut a hole in it to duct the recirc fan into. The only downside I can think of for this is there won't be a flap in it. This would mean that if I didn't have the gas heater on, but did have the heat exchangers opened up, some of that heat from the exchangers would end up being pushed backwards, through the recirc fan, and into the back of the bus.
Is that really bad somehow? Or not a big deal besides some potential heat loss (up front) when the gas heater isn't fired up?
Dave Cook
1973 Wild Westerner
My Thing
vwwestyman
PostPosted: Wed Nov 18, 2015 9:10 pm    Post subject: Re: BA6 Heater Install into 1973 Reply with quote
I'll try bumping the thread on a different day/time than last time hoping to catch someone's schedule.
I just cant imagine there is no one who can help with the questions, I think they just haven't seen them.
Dave Cook
1973 Wild Westerner
My Thing
notchboy
notchboy is offline
PostPosted: Thu Nov 19, 2015 9:03 am    Post subject: Re: BA6 Heater Install into 1973 Reply with quote
Hey Im in the same boat for the most part - or at lease was when I did the BN4 stuff. I haven't had to set up my BA6 on the bench for any reason so I never laid it out and plugged in the power.
There is going to be lots of negative spots that need to have wires run to work. From what I remember you'll need a neg wire with 4 leads to tap into. Plus the red power, the gray is the power in from the switch.
All I can pull off the top of my head.
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
busdaddy
busdaddy is offline
PostPosted: Thu Nov 19, 2015 9:07 am    Post subject: Reply with quote
vwwestyman wrote:
On the control switch: What wires connect to K and 31 terminals? I find warnings that if these are switched the switch will be damaged but I can't figure out what connects to these.
According to the diagram there's a warning light between K and 31, K is also connected to 58b (internally) and there's a note in the diagram key stating "terminal 58b remains vacant", 31 is a ground.
Слава Україні!
vwwestyman
PostPosted: Thu Nov 19, 2015 9:58 am    Post subject: Re: BA6 Heater Install into 1973 Reply with quote
Here is a numbered pic to help identify wires. If you can identify where any of these go, it would be most helpful!
1 Female Connector: blue/white and black wires crimped together with it. My hunch is this goes to a fuse. Which one?
2 From pics I've seen, this just curls up to the screw that mounts the safety reset switch and provides its ground.
3 Based on red color, likely the main power for the system. Which fuse?
4, 5 Based on wire colors, this is likely the light for the control switch when the headlights are turned on. Where does the female connector go (somewhere on the cluster, I suppose), and the other wire with the plastic shield?
6 From the switch, brown with white stripe. Does this piggyback to the fan relay wire in the heat switch?
7, 8 According to busdaddy (If I'm understanding correctly) 31 will need to go to ground and K should be left alone and open.
If anyone can add any info to this, please do! Thanks!
Dave Cook
1973 Wild Westerner
My Thing
notchboy
notchboy is offline
PostPosted: Thu Nov 19, 2015 10:54 am    Post subject: Re: BA6 Heater Install into 1973 Reply with quote
3 - you hot to the bat
2 - grounds to the screw that holds the circuit breaker to the bulkhead
4&5 is just a jump from the dash lights. 4 goes to the light for the air control dash pod and 5 ends at the hazard switch.
1964 1500 S
vwwestyman
PostPosted: Mon Jan 11, 2016 1:16 pm    Post subject: Re: BA6 Heater Install into 1973 Reply with quote
Thanks Jason.
Still haven't decided on this.
One problem is I don't have the air flapper box that sits directly behind the heater, for the fan return intake. Been trolling the classifieds for a while and haven't found anything. Also been thinking about a way to make something.
I've thought about setting it all up so that rather than the BA6 fan turning on, the rear booster fan is turned on. This would preserve the ability to warm up the bus ahead of time, with that fan blowing instead.
The only downside I can see is that I would lose out on the benefit of recirculation.
But would it hurt anything with regards to the actual heater running?
I know the answer is primarily going to be theory, but I want to hear your theories on how it might work! Or has anyone actually tried this?
Dave Cook
1973 Wild Westerner
My Thing
notchboy
notchboy is offline
PostPosted: Mon Jan 11, 2016 7:11 pm    Post subject: Re: BA6 Heater Install into 1973 Reply with quote
On my 76 the booster heater is on when the recirculating fan is on. They both run at the same time when the BA6 is running. Since you have a westy there is that out put hole under your back seat. Stuart was going to maybe use that as his recirc hole. Not sure how it could be plumed. Secondly worst case is having the recirc fan pulling outside air in and over the heater - runs less efficient but will still allows it all to work properly. Eberspacher has an on and off history of re-circulation. Maybe they did it based on application. But a BN4 started with no recirc and ends with one.
Just some thoughts.
1964 1500 S
chabanais
chabanais is offline
PostPosted: Mon Jan 11, 2016 7:58 pm    Post subject: Re: BA6 Heater Install into 1973 Reply with quote
Nice! I've had mine in my kitchen for the last 17 years. One day...
"I spud therefore I yam."
vwwestyman
PostPosted: Mon Jan 11, 2016 9:38 pm    Post subject: Re: BA6 Heater Install into 1973 Reply with quote
Just some thoughts.
Well this is going into the '73 if it gets installed. That is just a passenger bus, not Westy.
The fact that the booster turns on when the heater is on made me think the idea may work.
I thought about swapping the booster fan for two fans to increase the airflow through the heater, but I'd have to do something about the flaps to keep hot air from coming up from the heat exchangers in the summer.
How bad would it be to install it with the recirculation and everything but not the flaper box that the recirculation fan blows into, that is just behind the heater body? I don't have that.
Or, any ideas anyone on how to make something that would work as a substitute for this part?
Dave Cook
1973 Wild Westerner
My Thing
