jpineau Samba Member
Posted: Mon Jan 23, 2017 11:14 am Post subject: Vanagon Cruise Control - fix or replace? |
I have some leaky vacuum lines, and a throttle actuator that need to be rebuilt or replaced. Not sure about the vacuum pump itself.
Does it make sense to fix the stock cruise? If so, where to I get the parts? Or should I just replace it with the GW system or something similar?
Thanks! |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12161 Location: Port Manteau
Posted: Mon Jan 23, 2017 11:44 am Post subject: Re: Vanagon Cruise Control - fix or replace? |
Vanagon CC is a very robust system which makes freeway trips much more pleasant, so I strongly suggest you fix what you have. The good thing is that the parts are shared with lots of the same era VAG vehicles, so you shouldn't have to look too hard to find anything required to get it up and running again. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Mon Jan 23, 2017 11:49 am Post subject: Re: Vanagon Cruise Control - fix or replace? |
I did look at all the common vendors that I know of.. All I can find is the switches that go under the pedals. |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Mon Jan 23, 2017 12:16 pm Post subject: Re: Vanagon Cruise Control - fix or replace? |
jpineau wrote: |
Leaky valves or misadjustment is the #1 cause of cruise not working. I woud just fix what you have The actuator arm is available at Van-Cafe and the bulb is a common part, probably still a dealer item, but I woudl grab one from the junkyard. They were one Volvos, Mercedes and VWs. I have a spare if you don't have a junkyard nearby. The pump is probably fine, but I have one of those too. I imagine anything you need is in the classifieds.
There are good troubleshhoting threads on the cruise system and the Bentley procedure for testing component is great. |
Posted: Mon Jan 23, 2017 1:10 pm Post subject: Re: Vanagon Cruise Control - fix or replace? |
Thanks Dave! I will dig a bit locally and see if I can come up with a bulb. |
Posted: Mon Jan 23, 2017 1:33 pm Post subject: Re: Vanagon Cruise Control - fix or replace? |
As mentioned, the brake/clutch vacuum valves are the primary failure points for the system. I've had good luck taking them apart and then cleaning and re-lubing with silicone grease. _________________ Casey--
y u rune klassik? |
Posted: Mon Jan 23, 2017 1:37 pm Post subject: Re: Vanagon Cruise Control - fix or replace? |
I did test those. Both needed the electrical connections cleaned and one of them needed to be re-lubed. Both test out fine now.
I hooked my vacuum tester to the throttle actuator and it leaks like crazy. I also checked the main line that runs up front and it leaks slowly. Raining here today, so I'll get under the van and find the source of that leak when it drys up. |
geodude Samba Member
Posted: Mon Jan 23, 2017 4:23 pm Post subject: Re: Vanagon Cruise Control - fix or replace? |
If your vacuum switches or the line going to them are leaking you can simply plug the vacuum line by the pump. The switches are redundant (in a good way) and the electrical half will still disconnect the CC. Maybe not ideal, but the system works fine that way. _________________ 1988 GL Camper
1991 Multivan — the basket case |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
Posted: Mon Jan 23, 2017 6:15 pm Post subject: Re: Vanagon Cruise Control - fix or replace? |
The bellows in the throttle actuator has a hole in it. Otherwise it seems fine. Is patching it with a bicycle inter tube kit a great idea or a horrible idea? |
stevey88 Samba Member
Joined: January 16, 2008 Posts: 1317 Location: Fremont, SF Bay Area
Posted: Mon Jan 23, 2017 6:25 pm Post subject: Re: Vanagon Cruise Control - fix or replace? |
jpineau wrote: |
The bellow was also used in the P38 range Rover cruise control. There are many many Range Rover from 94 to 01 in the breaking yard as they are no longer worth spending money to fix, the resale value of the car is so low. The cost is $4 at my local Pick N Pull. _________________ Steve
87 Westfalia full camper 4 speed |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4228 Location: Redwood City, California
Posted: Mon Jan 23, 2017 7:11 pm Post subject: Re: Vanagon Cruise Control - fix or replace? |
I agree with all posted, disconnecting the vacuum line is great to determine that the switches are bad (replace or rebuild) as you see fit.
I have also installed a Rostra unit with mixed results. Not an ideal specimen, a 1.9 auto Westy.
As stated the bellows are used on many European cars for more then just cruise, Audi uses them for cam actuators.
I have seen these systems not work because the plugs for the Brake Fluid and the VSS were switched.
I have installed factory units from scratch and they work so well with a little tweaking.
Get out the Bentley manual and follow their flowchart and you to will have a working cruise system.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
rowan Samba Member
Joined: March 18, 2007 Posts: 133 Location: Knoxville, Tennessee, USA
Posted: Mon Jan 23, 2017 7:58 pm Post subject: Re: Vanagon Cruise Control - fix or replace? |
I also have a Rostra unit and am unimpressed. Has anyone here ever tried to install a factory CC in a non CC equipped van? _________________ Rowan
89 Syncro - Juniper Mackenzie
09 Honda Fit - Finnie
17 Ram ProMaster - John Hordle |
16CVs Samba Member
Posted: Mon Jan 23, 2017 10:34 pm Post subject: Re: Vanagon Cruise Control - fix or replace? |
I have done numerous, the biggest issue is getting all of the little pieces.
The harness is fairly easy to make, The pump and Vacuum pod are universal, but there are specific bracket and linkage . The ECU for 2WD is specific, but the ECU for 4WD is the same as any front drive VW. You can buy new switches but you need the brackets or just buy the GW replacements. The biggest issue is the stalk which is specific, but you can use a Jetta or Cabriolet switch but are bent differently.
With a small amount of effort you can put together a system for about $75.00 - $200.00.
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5818 Location: Wamego, Kansas, USA
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Tue Jan 24, 2017 7:47 am Post subject: Re: Vanagon Cruise Control - fix or replace? |
Those vacuum switches get tired and cause problems. On my vanagon I rebuilt the switch a couple of years ago and it failed, leaking vcuum again.
Easy fix for $30 on on the bay. See the link:
http://www.ebay.com/itm/131537909630 |
Posted: Tue Jan 24, 2017 3:33 pm Post subject: Re: Vanagon Cruise Control - fix or replace? |
Followed the Bentley flow chart and everything checks out. The pump turns on, but it doesn't have much pull. I'm guessing it's time for a new pump. Any suggestions on source? |
Posted: Tue Jan 24, 2017 5:35 pm Post subject: Re: Vanagon Cruise Control - fix or replace? |
If you do need a pump you'll probably want to buy a used one. New ones are like $250 and they are a dime a dozen at the junkyard or in the classifieds. The only downside is you don't know if it will be better than yours. When yours runs does it not pull the throttle back? Did you block the lines to the front when you tested it to make sure it isn't a vacuum leak? If you suck on that engagement arm vacuum tube, you will see how little vacuum is required. There is probably a way to open the pump and lube it or look for issues. I woudl think if it is running, it probably is o.k. but what makes you think the pump is too weak? |
Posted: Tue Jan 24, 2017 5:49 pm Post subject: Re: Vanagon Cruise Control - fix or replace? |
It wont pull the throttle back nor will it hold it in position if I pull it back. No vacuum leaks (anymore). I can hook my brake bleeder up to it and pull the throttle back with vacuum easily. |
