Piston coolers, oil squirters
fathing
fathing is offline
PostPosted: Thu May 26, 2005 5:37 am    Post subject: Piston coolers, oil squirters Reply with quote
Does anybody have information, drawings, how to's on machining the Type 1 case for oil squirters, which squirters do I have to get etc. I know the VW TDI engine uses squirters. I am preparing a 1914cc engine for a later turbo installation and I would like to use piston coolers.
All help will be appreciated.
Cool Peace Dom
Mech_Meister
Mech_Meister is offline
PostPosted: Thu May 26, 2005 6:25 am    Post subject: Reply with quote
if you really need them ..you would only need them on one side as the crank splashes one set of pistons due to the direction it spins
gears
gears is offline
PostPosted: Thu May 26, 2005 7:38 am    Post subject: Reply with quote
Installing the Porsche piston squirters is somewhat tricky. I can e-mail photos, if you wish --
brianwheelies
brianwheelies is offline
PostPosted: Thu May 26, 2005 10:02 am    Post subject: Reply with quote
AJ Simms does this for his turbo motors, don't know if he'll spill the beans though.
OTO X58
OTO X58 is offline
PostPosted: Thu May 26, 2005 10:54 am    Post subject: Reply with quote
rimco can do it for you too, i think.
i've seen a type 4 case done by them, but i'd guess they do it for type 1 also.
gears
gears is offline
PostPosted: Fri May 27, 2005 9:00 am    Post subject: Reply with quote
This mods been done on Type I's for over 25 years.
chazavw
chazavw is offline
PostPosted: Fri May 27, 2005 10:42 am    Post subject: Reply with quote
so whats the secret?
Bruce
Bruce is offline
PostPosted: Fri May 27, 2005 11:17 am    Post subject: Reply with quote
Could you post the pics?
gears
gears is offline
PostPosted: Fri May 27, 2005 2:59 pm    Post subject: Reply with quote
Doubtful. I'm OK with the Bridgeport, but a dunce with the computer ---
gears
gears is offline
PostPosted: Fri May 27, 2005 3:51 pm    Post subject: Reply with quote
I think Bruce can paste the photos. This is the text:
> Did you make the squirter nozzles your self or are these parts you
> can buy? What hole size does the nozzle have?
Porsche piston squirters are available for a couple bucks apiece from some Porsche machine shops. I used to get mine from Ray Litz, who had a shop in the Pasadena area. The squirters are available in at least two types: standard, and turbo. The VW uses standard.
The squirters have a check valve in them (ball & spring). Pretty nice. The optimum angle of the squirter positions the 6mm installation hole to overlap the oil groove by about 50% (assuming you use the bearing type with groove on the backside), which is plenty of oil supply for the tiny squirter hole. The installation hole is drilled from bearing side with a tapered 1/4" drill (following a pilot hole of slightly smaller diameter).
The 6mm squirter drops easily into the 1/4" hole, and is carefully driven in the last 1/4" (where the hole tapers down in size), with about a .002" interference fit. When drilling with the 1/4" drill, you should stop just short of poking through the piston side of the case, leaving you with a bit of meat to hold the squirter in place.
This is the proper way to install squirters. Some guys cheat and go from the piston side, and then peen the squirter in place. This is not recommended. The output end of the squirter is delicate, while the backside is beefy (to allow it to be driven in).
Bruce
Bruce is offline
PostPosted: Sat May 28, 2005 1:18 am    Post subject: Reply with quote
Paul, do you just eyeball the angle?
turbo_bob
turbo_bob is offline
PostPosted: Sat May 28, 2005 5:42 pm    Post subject: Reply with quote
I had a type 1 case installed with the Porsche oil squirters, Rimco did the install. I will see how this works out in the future as this is a street turbo engine.
Bruce
Bruce is offline
PostPosted: Sun May 29, 2005 2:04 am    Post subject: Reply with quote
The pics show the squirters being installed in the left half. But up top, Mech_Meister said they aren't necessary on the left side, I tend to agree.
Robert, did Rimco do all 4?
turbo_bob
PostPosted: Sun May 29, 2005 9:00 am    Post subject: Reply with quote
Yes.
Besides Porsche, aircraft also use oil squirters on each piston to cool down the piston top, (good for lowering high temps from boost).
I was just looking at a new Mooney Brovo the other day and it also had oil injection on each exhaust valve/guide/spring area on each cylinder, it is turboed as well.
gears
gears is offline
PostPosted: Sun May 29, 2005 10:51 am    Post subject: Reply with quote
My buddy Jon Karcey turned me on to the idea, but didn't really want to experiment with my case. So I spent some time figuring out the correct angle, and yes -- I just eyeballed it on that case.
Porsche doesn't do just half a job on their engines, so I don't think I'd rely on somewhat random splash to take care of one side. If I recall, Porsche's estimated reduction in piston temperature is around 100 degrees F.
BTW, the machining must be started with a 1/4" endmill. A drill bit will wander too much at that severe angle.
pupjoint
pupjoint is offline
PostPosted: Sun Oct 28, 2007 6:34 pm    Post subject: Reply with quote
this is interesting. any other detailed pictures on this?
http://www.elitedsm.com/oilsquirters.htm
http://www.turbomagazine.com/tech/0609turp_honda_f20c_stroker_build/photo_10.html
http://e30m3performance.com/installs/installs-3/squirters/index.htm
SHTUBBY
SHTUBBY is offline
PostPosted: Mon Oct 29, 2007 8:41 am    Post subject: Reply with quote
I've always drilled squirters into the Connecting Rods. Similar to a Jap engine. Same result, much easier, and cheaper.
Your sister is hot. But your mom does that thing with her tongue.
Steve
nsracing
nsracing is offline
PostPosted: Tue Oct 30, 2007 5:52 pm    Post subject: Reply with quote
There are so many ways you can install "squirts". YOu can machine the hole directly in the case just by drilling the proper size jet hole and facing with an endmill. Or you can also machine inserts that you can press-in. Or install threaded ones. You can also make some with "O" ring and secure w/ a tab and hex bolt. These are all the different styles out there.
But they all do the same purpose.
The easiest one is to just machine the case directly. A facing cut with an endmill and then followed by spotting drill. Then you can drill for the desired jet hole all the way through the back of mains.
You can also use MIG welding tips...these come threaded already. All you need to do is spotface the threaded hole after you tap and it is held in there nicely.
Cheers.
flyinglow94
flyinglow94 is offline
PostPosted: Sat May 14, 2011 9:59 am    Post subject: Reply with quote
Where can I get the Porsche oil squirts? I have looked on line and most Porsche suppliers don't advertise these little things. Does any one have a part # they can share?
"What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.."
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
