Max Welton Samba Member
Joined: May 19, 2003 Posts: 10982 Location: Black Forest, CO
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23294 Location: Kimball, Mi
Posted: Mon May 29, 2017 8:08 pm Post subject: Re: Remove - Install assembled engine + tranny |
That's an interesting way to do it. Let us know how it works out. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed May 31, 2017 10:45 am Post subject: Re: Remove - Install assembled engine + tranny |
Max Welton wrote: |
Hopefully the corners of the chassis are strong enough to lift the body. Should be fine. Car isn't rusty and the subframe/transmission/engine will be disconnected. |
Well I'm not 100% sure on a stock pan, but we just did a rear sub swap on my son's car (took out the swing axle, and installed an IRS unit), and lifted the body using 2 jacks. His car has a 1x2 steel reinforcing tube, that's bolted and stitch welded to the pan in the cavity, to make up for not having a roof. This helped us out as we could literally put the jacks anywhere along the sides of the car.
You might try doing your lifting with a block of wood in the pan channel, or using the jack points (or maybe slightly rear of them). The perimeter of the pan should be pretty strong, but I'd add something inside it to keep from crushing the edges of it. But use 2 jacks, so you can get the rear lifted high enough to clear the tires (our biggest challenge too). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
akokarski Samba Member
Posted: Wed May 31, 2017 1:00 pm Post subject: Re: Remove - Install assembled engine + tranny |
maybe take the wheels off and put the whole sub on a moving dolly. the flat one like this:
this can give you a bit more clearance. But I am not sure how you are going to balance the whole thing on the jack to raise it to the body... |
Posted: Wed May 31, 2017 2:23 pm Post subject: Re: Remove - Install assembled engine + tranny |
My removal plan is to unhook the subframe, lift the car then roll the old sf/tranny/engine assembly, on its own wheels, out from under the raised car.
Installation of the new stuff is just the reverse.
The center of mass is only a little aft of the axle. Moving it is easily a one-person no jack effort. Put the transmission in neutral and move it around like a wheelbarrow.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
stonecoldcars Samba Member
Joined: February 21, 2013 Posts: 265 Location: Oregon
Posted: Thu Jun 01, 2017 11:59 am Post subject: Re: Remove - Install assembled engine + tranny |
Do you have a thread on the EFI set up you have going on there?. Looks clean and I would like to know more. _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
superalex Samba Member
Joined: December 10, 2008 Posts: 60 Location: tavira, algarve, portugal, europe
Posted: Thu Jun 01, 2017 2:59 pm Post subject: Re: Remove - Install assembled engine + tranny |
Today i pulled out my first type 3 motor. Much more easyer than a type 1 and almost as easy than a type 2
I think the whole assembly will tend to tilt backwards. Wont it be dangerous? |
supersuk Samba Member
Joined: December 20, 2010 Posts: 958 Location: Honolulu, Hawaii
Posted: Thu Jun 01, 2017 5:58 pm Post subject: Re: Remove - Install assembled engine + tranny |
I can confirm with Max that the entire assembly isn't too heavy on the engine side with the subframe assembly as he showed. I wheeled mine around without a problem. However, I did not install my assembly like Max plans to do. I just stored mine like that for a little bit. I was fortunate enough to have the body off the pan to attach everything first before putting the body on. _________________ 68 Fastback Build: http://www.thesamba.com/vw/forum/viewtopic.php?p=5396323#5396323 |
Posted: Thu Jun 01, 2017 9:15 pm Post subject: Re: Remove - Install assembled engine + tranny |
Max Welton wrote: |
Max |
Unless you hang a type 4 engine off the trans.  _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Jun 01, 2017 11:59 pm Post subject: Re: Remove - Install assembled engine + tranny |
Max Welton wrote: |
After I pass this kidney stone I'll give it a go. Pictures to follow.
Max |
Oh man that's painful! Hope your stone is not to big. |
D/A/N Samba Member
Posted: Fri Jun 02, 2017 4:09 am Post subject: Re: Remove - Install assembled engine + tranny |
akokarski wrote: |
Max Welton wrote: |
Max |
I hope "Pictures to follow" doesn't mean he's planning on showing us the stone.... |
Posted: Fri Jun 02, 2017 8:28 am Post subject: Re: Remove - Install assembled engine + tranny |
D/A/N wrote: |
akokarski wrote: |
Max Welton wrote: |
Max |
LOL! Don't touch that dial!
PS: Ramva list alumni may remember a certain person sharing a picture of his fingernail into which he had drilled a neat little hole. Made me cringe a little.
Posted: Sat Jun 03, 2017 7:30 pm Post subject: Re: Remove - Install assembled engine + tranny |
Extraction completed.
To lift the car, I used a pair of 450 lb transmission jacks, one under each jack point. I was a little worried about the weight but figured lifting only the rear of the car without the engine/transmission/subframe should come in under 900 lbs. Since it worked it either was less than 900 lbs or I got away with it.
Here is my process.
Remove battery.
Jack the car up by the s/f with an ordinary floor jack. Take the wheels and the (split) rear brake drums off. Because type-3.
Unhook everything underneath.
I moved front to back, starting with the forward s/f pad (get all FIVE bolts), the brake hardlines, emergency brake cables, backup switch plug, clutch cable, bowden tube, shift coupler, heat control cables and tubes. Disconnect the fuel line and either clamp or drain. I clamped. Bad choice. Open all windows. Apply kitty litter.
Now put the wheels back on and lower the car.
Topside I started inside the car and buzzed out the four s/f to body bolts.
In the engine bay I disconnected the ignition, throttle cable, anti-torque brace (swing axle). Don't forget to remove the dipstick. And the engine-to-body boot. Ahem.
Don't worry too much about having left something connected. Anything you forgot will make you pay, perhaps involve a replacement search and generally prevent a happy ending.
Place the floor jack just under the engine. As the car lifts off, the engine will tilt down. The jack will catch the engine.
Start jacking, a little on each side, keeping the car reasonably level and checking for hangups.
That happy ending looks like this.
The car may now be easily moved around the garage on the wheeled transmission jacks for further depot level maintenance.
Mexiwop Samba Member
Joined: February 04, 2010 Posts: 2 Location: whittier, CA
Posted: Sun Apr 27, 2025 1:35 pm Post subject: Re: Remove - Install assembled engine + tranny |
I stumbled upon this. Im so glad as im in the middle of doing a refresh on my sub frame, trans and engine. This looks so easy, and safe. Again thanks for posting |
