No more Oil Cooler!
Team WorldTour
Team WorldTour is offline
PostPosted: Tue Jun 06, 2017 6:36 am    Post subject: No more Oil Cooler! Reply with quote
...sorry TenCent, nothing personal.
I removed the oil cooler today. It dropped it's last drop (¼ltr) in my driveway.
I really liked the design, and I liked the idea, but it never worked for me.
I take that back. It did work for me. For about 8 months. Then I needed to replace one of the hoses, and it just went down hill from there. With my replacement hose, I gave a little too much torque on the upper right angle joint, and broke the weld on the connector. Crap.
Mr. TenCent was kind enough to point me in the direction of a new cooler, but the shipping made it cost prohibitive. So, I found a repair shop (guy was older than dirt...), and they took a week to fix it right up.
I go to remount it, now the lower connector is dripping. Double Crap.
I take it back to Methuselah, and he fixes it again. This time I figure I will be clever, and get it all connected on the bench Very Happy . Then struggle and curse for 30 minutes trying to get it fit in Sad .
...only to have it continue to leak Shocked .
In the meantime, the thermal switch stopped functioning (wire broke). Again, Mr. TenCent was kind enough to point me in the direction of parts, and once again, cost prohibitive for me. The local Radio Shack-type place had a replacement for me, IF I could give him the correct amount of resistance.
Turns out he meant electrical resistance. Laughing
So, all in all, I can't say it worked as intended. I never got the chance to go 'wheeling with it in (too many other issues for reliability). I will say that the fan was ever willing to fill it's roll. Even with the resistor turned all the way up, the fan would come on in the most ridiculous of places.
On the Autobahn, for example. At speed.
I really hope this is a good product, but I never got to find out. Once I had to replace stock components, it ceased to be a functioning system, and instead left a dark stain in my life (which Mrs. WT says I have to clean up!).
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
Last edited by Team WorldTour on Tue Jun 06, 2017 8:12 am; edited 2 times in total
msewalson
msewalson is offline
PostPosted: Tue Jun 06, 2017 7:09 am    Post subject: Re: No more Oil Cooler! Reply with quote
Sorry if I come across as a dick but don't think your post is very constructive. I can understand your frustration when shit happens but in all fairness it sounds like your issues were a result of user error.
I used one of Chris's oil coolers when I still had a WBX and it worked great. I ended up selling it when I did my Subaru conversion. I was going to try and fit it to the EJ22 but decide not since I could resale it and make a little coin. But I do know of at least one of his kits being fitted to an EJ25 and working great.
Matt
87 Syncro w/EJ22
Team WorldTour
PostPosted: Tue Jun 06, 2017 8:11 am    Post subject: Re: No more Oil Cooler! Reply with quote
I'm sorry. I thought I made myself clear. Maybe the prose is a little thick.
Click to view image
IdahoDoug
IdahoDoug is offline
PostPosted: Tue Jun 06, 2017 8:28 am    Post subject: Re: No more Oil Cooler! Reply with quote
That little factory cooler is indeed a pain to fiddle in and out of there with the crazy tiny hoses and even tinier space. Once it is in place, I like it but agree it is an access nightmare.
Jon_slider
Jon_slider is offline
PostPosted: Tue Jun 06, 2017 11:21 am    Post subject: Re: No more Oil Cooler! Reply with quote
sorry for your pain
when in doubt, take it out
He is talking about an aftermarket cooler, not the stock one.. see
http://vanistan.com/oil_cooler_kits.html
My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
Team WorldTour
PostPosted: Wed Jun 07, 2017 1:52 am    Post subject: Re: No more Oil Cooler! Reply with quote
The 'dark stain' is more physical and less esoteric. It's sitting in the driveway, just under the van, and I've used all my Kitty Litter already.....
Click to view image
tjet
tjet is offline
PostPosted: Wed Jun 07, 2017 11:05 am    Post subject: Re: No more Oil Cooler! Reply with quote
Sorry you had troubles with it. It's a quality setup. Mine saved my engine when my fan belt broke going thru Park City Utah.
HoustonPhotog
HoustonPhotog is offline
PostPosted: Wed Jun 07, 2017 12:10 pm    Post subject: Re: No more Oil Cooler! Reply with quote
Love mine... I had a slight leak but it was a loose fitting. tightened it and all good now. Love keeping my oil temps under control on crazy mountain passes...
Abel Longoria
VanAlert App for Vanagons/Buses | Texas Vanagons | My Vanagon Build Thread | Follow Me On Instagram | Vanagon-centric Stickers Available Now
raoul mitgong
raoul mitgong is offline
PostPosted: Wed Jun 07, 2017 12:19 pm    Post subject: Re: No more Oil Cooler! Reply with quote
Fan belt? A fan belt that long would definitely have some issues! Laughing
84 Westy with a 2.1 (Groover)
86 Tintop Syncro (Crow)
86 Tintop Syncro to Westy project (Tom Servo)
91 Westy (Only the top 12 inches of this van (a burn victim))
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Wed Jun 07, 2017 12:26 pm    Post subject: Re: No more Oil Cooler! Reply with quote
Perhaps the thread title should be: "I had a great oil cooler kit, but then I broke it and now it's removed"
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Jun 07, 2017 1:03 pm    Post subject: Re: No more Oil Cooler! Reply with quote
Maybe he had that oil cooler kit with an aircooled engine? Wink
Steve M.
Steve M. is offline
PostPosted: Wed Jun 07, 2017 2:18 pm    Post subject: Re: No more Oil Cooler! Reply with quote
Would you perhaps have an easier time installing it if you removed the right rear tail light to help access when installing?
I've yet to install mine for lack of time, but that was the first thing I thought of when looking at it. (that might be in the instructions, but it was last year when I looked at it and I don't even remember yesterday.)
djkeev
djkeev is offline
PostPosted: Wed Jun 07, 2017 2:44 pm    Post subject: Re: No more Oil Cooler! Reply with quote
Every product built, no matter the quality or price has it's "lemons", "rotten apples", what have you.
When most say it's great and one or two say it's horrible...... well..... you sadly got the rotten apple.
Dave
Ghia
Vanagon
Beetle
