whatthehucks Samba Member
Posted: Wed Jan 01, 2020 10:15 pm Post subject: Generator vs Alternator with small sub and speakers |
So i was i able to find anything in the search so hopefully someone can lead me in the right direction.
I have a 4 channel amp and 2 speakers on the way to install into the 64. It has already been converted to 12v from the po. My question is will the 12v generator be sufficient enough to power the stereo and everything or should i think about upgrading to a alternator?
If I should convert to an alternator setup is a basic 55amp good enough? I don’t have any other electronics other than the stereo and most of my interior lights and tails have been converted to LEDs also. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8844 Location: Sunset, Louisiana
Posted: Thu Jan 02, 2020 8:23 am Post subject: Re: Generator vs Alternator with small sub and speakers |
It all depends on how efficient your amplifier is. How many amps does it draw?
Back in the 80s I ran Linear Power active crossover with a 150 watt and a 60 watt Linear Power amps and an Alpine head unit with a stock generator. That setup made over 120db SPL before distortion measured from the drivers position and did OK in competition when judged for accuracy. I spent more for those amps than I spent for the car ... a lot more.
The stock generator and voltage regulator was fine. The new solid stated voltage regulators are much better. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Thu Jan 02, 2020 10:16 am Post subject: Re: Generator vs Alternator with small sub and speakers |
Thanks!
Not looking for competition sound at all. Just a little oomph over the single 4”. |
Miklo ¡Chale!
Joined: August 27, 2008 Posts: 2058 Location: Antelope Valley, Ca
Posted: Thu Jan 02, 2020 11:44 am Post subject: Re: Generator vs Alternator with small sub and speakers |
Ditch the old generator not just for the stereo...
I recommend buying an alternator from AutoZone.
They come with a lifetime warranty and are relatively cheap.
They are good alternators but use bad bearings.
Replace or apply your own quality grease in them and they will last. Going through a few in only a couple years, I learned.
They have never hassled me and I've only payed once.
Same goes for their starters! Which are rebuilt OG Bosch.
Again, some work on those too and they function great for years! _________________ ✠Miklo✠
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote: |
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche... |
Q-Dog Samba Member
Posted: Thu Jan 02, 2020 12:17 pm Post subject: Re: Generator vs Alternator with small sub and speakers |
Why anyone would put up with "going through a few (alternators) in a few years" is beyond me. Each replacement costs me time even if they give me a new one that will also fail eventually.
I have over 320,000 miles on the generator I am running on my buggy. It was in my convertible for its first 299,000 miles and about half of those miles were running the stereo system I mentioned in the above post. Replace brushes when worn and don't overtighten the belt and they can last a long time. _________________ Brian
'69 Dune Buggy
'70 Beetle |
cbeck Samba Member
Joined: January 14, 2014 Posts: 2562 Location: high ridge, mo
Posted: Thu Jan 02, 2020 3:24 pm Post subject: Re: Generator vs Alternator with small sub and speakers |
Is there a sticky or forum that discusses after market stereo and what not. I haven’t had luck finding anything |
Zundfolge1432  Samba Member
Posted: Thu Jan 02, 2020 3:47 pm Post subject: Re: Generator vs Alternator with small sub and speakers |
Miklo wrote: |
Again, some work on those too and they function great for years! |
Useless information unless you own stock in autozone and enjoy swapping out their chinese alternators regularly  |
Posted: Thu Jan 02, 2020 8:42 pm Post subject: Re: Generator vs Alternator with small sub and speakers |
yeah not buying a 155$ 30 amp alternator from autozone. But thanks |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16564 Location: North Florida, USA
Posted: Fri Jan 03, 2020 9:40 am Post subject: Re: Generator vs Alternator with small sub and speakers |
cbeck wrote: |
Watts ÷volts =amps. |
I think cbeck's post was meant to question how many watts does your stereo and amp draw?
The stock 12v generator is rated at 30A(?) while the stock alternator is rated at 55A. That's an extra 25A that you can use for your stereo+amp (and other add on accessories). Knowing if your system draws more current than this is the answer to your question. The size of the fuse will give you the biggest idea how much power the devices draw.
Here is a good collections of FAQs for amps:
https://www.crutchfield.com/S-9hRP4C8EYf6/learn/car-amplifier-installation-questions.html
This link provides the formula for amp rating based on amp RMS and type:
https://www.crutchfield.com/learn/learningcenter/car/cable_gauge_chart.html?showAll=N _________________ AshMan40
cbeck Samba Member
Posted: Fri Jan 03, 2020 10:49 am Post subject: Re: Generator vs Alternator with small sub and speakers |
Dark and raining, high beams(100watt ea?), Wipers(? Watts), ignition(8amp?), Parking lites (25 ?watt ea), blinkers, bet your getting close. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Q-Dog Samba Member
Posted: Fri Jan 03, 2020 4:58 pm Post subject: Re: Generator vs Alternator with small sub and speakers |
Dark and raining with the high beams going, I doubt you'll be blasting the stereo at full power.  _________________ Brian
'69 Dune Buggy
'70 Beetle |
Danwvw Samba Member
Joined: July 31, 2012 Posts: 8895 Location: Oregon Coast
Posted: Fri Jan 03, 2020 5:28 pm Post subject: Re: Generator vs Alternator with small sub and speakers |
Yes if you have incandescent headlamps still they are normally 55/60 Watts and the Generator is designed to run them full time. If you put a 100 Watt Stereo in with a subwoofer probably it's on the verge of needing an alternator. One solution is to run rather expensive 12 volt LED headlights that free up some power. I think the best way to tell if you have a problem is if the battery starts to be under charged IE below 12.6 volts at rest not charging.
(I figured out a way to measure the amps at my 6 Volt generator using el-cheapo Digital Amp meter etc.. The 6 Volt Electronic Generator Voltage Regulator shown would not be needed Just the 100 amp Digital Display that comes with it's own shunt and an AD22057 Isolation Chip is needed because the Digital Ammeter was designed to run between the Generator/Alternator and Ground and that doesn't work on Negative Ground charging systems.)
Lights Off:
60 Watt 6 volt Lights On: (Current on a 12 volt system could be 1/2 this!)
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Fman Samba Member
Joined: November 21, 2018 Posts: 151 Location: Nor Cal
Posted: Sun Jan 05, 2020 9:40 am Post subject: Re: Generator vs Alternator with small sub and speakers |
whatthehucks wrote: |
Go get an alternator and ditch the generator. I run a 5 channel amp with 10" sub, 6 co-ax speakers with no issues with alternator. I can run headlights, running lights, fog lights, etc with no issues with alternator.
Also keep in mind the amp draws more power the louder you turn it up. |
theduck Samba Member
Joined: March 05, 2006 Posts: 257 Location: hesperia california
Posted: Tue Sep 22, 2020 9:29 pm Post subject: Re: Generator vs Alternator with small sub and speakers |
Off topic,but,Hey is a generator stand the same as a alternator stand?I know about the fuel pump difference.But seems like they're both the same?  |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Wed Sep 23, 2020 5:02 am Post subject: Re: Generator vs Alternator with small sub and speakers |
theduck wrote: |
If I remember correctly, there was a difference initially between alt/gen stands but I beleive all new ones are universal. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4656 Location: Whittier 90602
Posted: Wed Sep 23, 2020 6:30 am Post subject: Re: Generator vs Alternator with small sub and speakers |
Great site with info galore...
https://www.the12volt.com/ _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33058 Location: Hot Arizona
Posted: Wed Sep 23, 2020 6:53 am Post subject: Re: Generator vs Alternator with small sub and speakers |
Sharp64 wrote: |
theduck wrote: |
If I remember correctly, there was a difference initially between alt/gen stands but I beleive all new ones are universal. |
Yes.
A factory generator-only stand won't let an alternator fit in.
An alternator-type stand would fit both/either. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Sep 23, 2020 8:55 am Post subject: Re: Generator vs Alternator with small sub and speakers |
Pictures! (I think the first one is from glutamodo)
Here you can see the cutaway sections in the alternator stand (right) to allow for the larger diameter at the rear end of the alternator case.
The diameter of the generator and alternator case that rest on the top of the stand are the same. This is why you can mount a generator on top of an alternator stand. But when you try to mount an alternator on top of a generator stand the larger diameter "belt" of the alternator case interferes with the rear side of the stand and cannot align the fan inside the fan shroud. This is why the alternator stand is cut away in this area. _________________ AshMan40
Posted: Wed Sep 23, 2020 10:54 pm Post subject: Re: Generator vs Alternator with small sub and speakers |
Thank all of you for the advise!!  |
