Generator vs Alternator with small sub and speakers
whatthehucks
whatthehucks is offline
PostPosted: Wed Jan 01, 2020 10:15 pm    Post subject: Generator vs Alternator with small sub and speakers Reply with quote
So i was i able to find anything in the search so hopefully someone can lead me in the right direction.
I have a 4 channel amp and 2 speakers on the way to install into the 64. It has already been converted to 12v from the po. My question is will the 12v generator be sufficient enough to power the stereo and everything or should i think about upgrading to a alternator?
If I should convert to an alternator setup is a basic 55amp good enough? I don’t have any other electronics other than the stereo and most of my interior lights and tails have been converted to LEDs also.
Q-Dog
Q-Dog is offline
PostPosted: Thu Jan 02, 2020 8:23 am    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
It all depends on how efficient your amplifier is. How many amps does it draw?
Back in the 80s I ran Linear Power active crossover with a 150 watt and a 60 watt Linear Power amps and an Alpine head unit with a stock generator. That setup made over 120db SPL before distortion measured from the drivers position and did OK in competition when judged for accuracy. I spent more for those amps than I spent for the car ... a lot more.
The stock generator and voltage regulator was fine. The new solid stated voltage regulators are much better.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
whatthehucks
PostPosted: Thu Jan 02, 2020 10:16 am    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
Thanks!
Not looking for competition sound at all. Just a little oomph over the single 4”.
Miklo
¡Chale!
Miklo is offline
PostPosted: Thu Jan 02, 2020 11:44 am    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
Ditch the old generator not just for the stereo...
I recommend buying an alternator from AutoZone.
They come with a lifetime warranty and are relatively cheap.
They are good alternators but use bad bearings.
Replace or apply your own quality grease in them and they will last. Going through a few in only a couple years, I learned.
They have never hassled me and I've only payed once.
Same goes for their starters! Which are rebuilt OG Bosch.
Again, some work on those too and they function great for years!
Miklo
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote:
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche...
Q-Dog
Q-Dog is offline
PostPosted: Thu Jan 02, 2020 12:17 pm    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
Why anyone would put up with "going through a few (alternators) in a few years" is beyond me. Each replacement costs me time even if they give me a new one that will also fail eventually.
I have over 320,000 miles on the generator I am running on my buggy. It was in my convertible for its first 299,000 miles and about half of those miles were running the stereo system I mentioned in the above post. Replace brushes when worn and don't overtighten the belt and they can last a long time.
Brian
'69 Dune Buggy
'70 Beetle
cbeck
cbeck is offline
PostPosted: Thu Jan 02, 2020 12:36 pm    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
Watts ÷volts =amps.
My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779
whatthehucks
PostPosted: Thu Jan 02, 2020 3:24 pm    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
Is there a sticky or forum that discusses after market stereo and what not. I haven’t had luck finding anything
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Thu Jan 02, 2020 3:47 pm    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
Useless information unless you own stock in autozone and enjoy swapping out their chinese alternators regularly Very Happy Very Happy
whatthehucks
PostPosted: Thu Jan 02, 2020 8:42 pm    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
yeah not buying a 155$ 30 amp alternator from autozone. But thanks
ashman40
ashman40 is offline
PostPosted: Fri Jan 03, 2020 9:40 am    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
cbeck wrote:
Watts ÷volts =amps.
I think cbeck's post was meant to question how many watts does your stereo and amp draw?
The stock 12v generator is rated at 30A(?) while the stock alternator is rated at 55A. That's an extra 25A that you can use for your stereo+amp (and other add on accessories). Knowing if your system draws more current than this is the answer to your question. The size of the fuse will give you the biggest idea how much power the devices draw.
Here is a good collections of FAQs for amps:
https://www.crutchfield.com/S-9hRP4C8EYf6/learn/car-amplifier-installation-questions.html
This link provides the formula for amp rating based on amp RMS and type:
https://www.crutchfield.com/learn/learningcenter/car/cable_gauge_chart.html?showAll=N
AshMan40
cbeck
cbeck is offline
PostPosted: Fri Jan 03, 2020 10:49 am    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
Dark and raining, high beams(100watt ea?), Wipers(? Watts), ignition(8amp?), Parking lites (25 ?watt ea), blinkers, bet your getting close.
Q-Dog
Q-Dog is offline
PostPosted: Fri Jan 03, 2020 4:58 pm    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
Dark and raining with the high beams going, I doubt you'll be blasting the stereo at full power. Wink
Brian
'69 Dune Buggy
'70 Beetle
Danwvw
Danwvw is offline
PostPosted: Fri Jan 03, 2020 5:28 pm    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
Yes if you have incandescent headlamps still they are normally 55/60 Watts and the Generator is designed to run them full time. If you put a 100 Watt Stereo in with a subwoofer probably it's on the verge of needing an alternator. One solution is to run rather expensive 12 volt LED headlights that free up some power. I think the best way to tell if you have a problem is if the battery starts to be under charged IE below 12.6 volts at rest not charging.
(I figured out a way to measure the amps at my 6 Volt generator using el-cheapo Digital Amp meter etc.. The 6 Volt Electronic Generator Voltage Regulator shown would not be needed Just the 100 amp Digital Display that comes with it's own shunt and an AD22057 Isolation Chip is needed because the Digital Ammeter was designed to run between the Generator/Alternator and Ground and that doesn't work on Negative Ground charging systems.)
Lights Off:
60 Watt 6 volt Lights On: (Current on a 12 volt system could be 1/2 this!)
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Fman
Fman is offline
PostPosted: Sun Jan 05, 2020 9:40 am    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
Go get an alternator and ditch the generator. I run a 5 channel amp with 10" sub, 6 co-ax speakers with no issues with alternator. I can run headlights, running lights, fog lights, etc with no issues with alternator.
Also keep in mind the amp draws more power the louder you turn it up.
theduck
theduck is offline
PostPosted: Tue Sep 22, 2020 9:29 pm    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
Shocked Off topic,but,Hey is a generator stand the same as a alternator stand?I know about the fuel pump difference.But seems like they're both the same? Shocked
Sharp64
Sharp64 is offline
PostPosted: Wed Sep 23, 2020 5:02 am    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
If I remember correctly, there was a difference initially between alt/gen stands but I beleive all new ones are universal.
1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine
61SNRF
61SNRF is offline
PostPosted: Wed Sep 23, 2020 6:30 am    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
Great site with info galore...
https://www.the12volt.com/
-Bruce
An ounce of prevention is worth a pound of cure.
Cusser
Cusser is offline
PostPosted: Wed Sep 23, 2020 6:53 am    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
Yes.
A factory generator-only stand won't let an alternator fit in.
An alternator-type stand would fit both/either.
ashman40
ashman40 is offline
PostPosted: Wed Sep 23, 2020 8:55 am    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
Pictures! Smile (I think the first one is from glutamodo)
Here you can see the cutaway sections in the alternator stand (right) to allow for the larger diameter at the rear end of the alternator case.
The diameter of the generator and alternator case that rest on the top of the stand are the same. This is why you can mount a generator on top of an alternator stand. But when you try to mount an alternator on top of a generator stand the larger diameter "belt" of the alternator case interferes with the rear side of the stand and cannot align the fan inside the fan shroud. This is why the alternator stand is cut away in this area.
AshMan40
theduck
theduck is offline
PostPosted: Wed Sep 23, 2020 10:54 pm    Post subject: Re: Generator vs Alternator with small sub and speakers Reply with quote
Very Happy Thank all of you for the advise!! Very Happy
