Door speaker placement
porkchop-rob
porkchop-rob is offline
PostPosted: Tue May 11, 2021 3:24 pm    Post subject: Door speaker placement Reply with quote
Anyone see anything horribly wrong with my proposed speaker locations? They do not interfere with the glass, dash, or window crank. They will be flush mounted through the door panel and to the steel door itself.
1965 Beetle
1968 Beetle Baja (Son's First Car)
1976 Bus with Subaru (Wife's Riviera Camper)
BUSBOSS
BUSBOSS is offline
PostPosted: Tue May 11, 2021 3:50 pm    Post subject: Re: Door speaker placement Reply with quote
Just be aware that, by design, water will weep down the window and into the bottom of your door. You need to have a properly installed vapor barrier to protect your speakers. I personally do not like speakers in the door due to the moisture/water issues. Regardless of where you mount your speakers, make sure the weeps holes in the bottom of the door are clear.
All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible
(sold - but not forgotten)
porkchop-rob
PostPosted: Tue May 11, 2021 3:58 pm    Post subject: Re: Door speaker placement Reply with quote
Good point. I will install some modified baffles to keep the speakers dry.
1965 Beetle
JaimeH Premium Member
JaimeH is offline
PostPosted: Tue May 11, 2021 4:05 pm    Post subject: Re: Door speaker placement Reply with quote
That just seems like a lot of metal to be removed. I used the opening below with a piece of aluminum angle to catch the 4th screw and stiffen the panel. I put riv-nuts on the angle and bolted through the panel to that.
1978 Transporter 2.0 FI, BA6
Special Thanks to Razor's Customs, Boscawen, NH
aeromech
aeromech is offline
PostPosted: Tue May 11, 2021 4:06 pm    Post subject: Re: Door speaker placement Reply with quote
Yes, I see something wrong
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
porkchop-rob
PostPosted: Tue May 11, 2021 4:09 pm    Post subject: Re: Door speaker placement Reply with quote
1965 Beetle
germansupplyscott
germansupplyscott is offline
PostPosted: Tue May 11, 2021 6:10 pm    Post subject: Re: Door speaker placement Reply with quote
If I had to guess I'd say aero is thinking "don't cut holes in your bus for speakers, find another way that doesn't involve cutting".
SL
porkchop-rob
PostPosted: Tue May 11, 2021 6:59 pm    Post subject: Re: Door speaker placement Reply with quote
Late bay bus, already cut on by ASI to become a Riviera Camper....cut on by PO for a single DIN radio....further cut on by a different PO and converted to Subaru power.
I'm not the least bit worried about a little German steel being lost on the way to the enjoyment of my bus.
1965 Beetle
richparker
richparker is online now
PostPosted: Tue May 11, 2021 9:07 pm    Post subject: Re: Door speaker placement Reply with quote
Just mount them to the door card so the magnet goes into the bottom hole, no cutting required. As stated above, make sure you use a vapor barrier. It’s not hard, buy some plastic drop cloth, spray the door with adhesive, stick on the plastic (leaving room for the speaker) and trim. You can buy speakers with a shallow magnet designed to clear the window for doors.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
Globespotter
Globespotter is offline
PostPosted: Tue May 11, 2021 9:35 pm    Post subject: Re: Door speaker placement Reply with quote
Mounting them on the door results in really poor sound. They face each other and sound terrible. I eventually mounted under-dash speakers - on brackets and tilted both slightly inward and up. The sound is SO much better, and no worries about speakers in the doors.
You could mount them between the dash and your parcel shelf. That's what I did on the passenger side.
1977 Westfalia - October 2015 - Current
1971 Super Beetle - May 2012 - Current
1979 Westfalia - 1986-1991
1971 Super Beetle - 1977-1980
1971 SB Survivor Story: https://globespotter.com/
Road Trip Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=511800&highlight=
My 77 Westy Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=647114&highlight=
http://vw-mplate.com/mcode.php?lang=EN&id=30990
https://vw-type2-id.xyz/mplate/72067382
JaimeH is offline
PostPosted: Wed May 12, 2021 3:49 am    Post subject: Re: Door speaker placement Reply with quote
If you don't mind removing metal and you've verified no interference go for it. You may get more sound to the listener with them up higher. My bus has the armrest vent so I went low. I prefer the tweeter a little higher than where you have it and maybe angled. Mine are in pods at the base of the A pillar. I kept twisting the pods to get what I wanted. A DSP will help. It's usually better to have more signal and tune down though.
jakokombi
jakokombi is offline
PostPosted: Wed May 12, 2021 4:40 am    Post subject: Re: Door speaker placement Reply with quote
If you are not apposed to cutting steel, I cut them into my dash and don't regret it.
https://www.thesamba.com/vw/gallery/pix/1368391.jpg
70 Sunroof Kombi
85 Motherfukinvanagon
73 Thing
72 Baja
pioneer1
pioneer1 is offline
PostPosted: Wed May 12, 2021 5:19 am    Post subject: Re: Door speaker placement Reply with quote
I installed speakers in the kick panels under the dash snuggled in beside the headlite pots
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
Mberglo
Mberglo is offline
PostPosted: Wed May 12, 2021 6:23 am    Post subject: Re: Door speaker placement Reply with quote
I installed dual 3.5" in the center of the dash. No cutting, and the sound bounces off the windshield right to you.
alman72
alman72 is offline
PostPosted: Wed May 12, 2021 8:02 am    Post subject: Re: Door speaker placement Reply with quote
2 vintage Realistic speaker boxes behind my seats with a bunch of extra cordage to move them around anywhere when i am parked. even outside on the roof.
vwwestyman
vwwestyman is offline
PostPosted: Thu May 13, 2021 7:20 am    Post subject: Re: Door speaker placement Reply with quote
Ha ha, we're getting way off the original question! But since that's happened:
You can buy vintage style speakers that take both the left and right signal and send it to the same speaker. (May be dual cone, I'm not sure.) That would work nicely in the dash spot.
In my Buses, I installed a single speaker in the dash spot. Then wired the positive of one side and the negative of the other side to it. Correction: Wired the positive wire of one side to the positive of the speaker, and the positive wire of the other side to the negative of the speaker. That is supposed to make it basically a center channel. (if I understood everything I read correctly!)
I do also have (in one bus) door speakers down low and (in the other bus) speakers mounted under the dash screwed to the air vent as someone else showed.
The center channel bounces off the windshield and provides a nice fill. Especially nice when listening to spoken word stuff (news, podcasts).
I actually also installed a "pot" to control the volume of the center speaker, so I can turn it down if listening to music and want a little more stereo separation.
Dave Cook
1973 Wild Westerner
My Thing
Mberglo
Mberglo is offline
PostPosted: Thu May 13, 2021 7:23 am    Post subject: Re: Door speaker placement Reply with quote
Then wired the positive of one side and the negative of the other side to it. That is supposed to make it basically a center channel
I don't think it works that way.
And a dual cone just has two speakers with one input. It will play left or right, but not both.
vwwestyman
PostPosted: Thu May 13, 2021 7:32 am    Post subject: Re: Door speaker placement Reply with quote
Thanks for the catch. Edited my post.
For "dual cone" wasn't thinking like a coax speaker (essentially a mid/low speaker, with tweeter in the middle) but basically two cones right next to each other, in one housing.
Here's an example: https://www.crutchfield.com/S-WVpy6vTHnTy/p_068D57...jMQAvD_BwE
Looks like it is a combo of the two ideas:
A "coax" speaker with the lows coming out of one combined cone (probably combined similar to how I described) with two high range cones for a little bit of stereo separation.
Dave Cook
1973 Wild Westerner
My Thing
Globespotter
PostPosted: Thu May 13, 2021 7:36 am    Post subject: Re: Door speaker placement Reply with quote
Not really. The original question asked if there was any problem with speaker placement, and the responses identified both problems and potential alternatives. It's a constant source of amusement when people ask questions. I think they really just want the answer - "Looks awesome. Do it!"
jtauxe Premium Member
jtauxe is offline
PostPosted: Thu May 13, 2021 7:43 am    Post subject: Re: Door speaker placement Reply with quote
This may not be helpful advice, but I removed the stereo and speakers from my truck entirely. I just use an mp3 player (e.g. phone) and headphones. Speakers are so old school.
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
