Under storage rifle case?
Selsk
Selsk is offline
PostPosted: Thu Jul 22, 2021 11:28 am    Post subject: Under storage rifle case? Reply with quote
I have been reading post about under van storage. I like the cutout container, but I don't really want to cut into my floor at the moment. I'm wondering if a pelican or similar rifle case would fit? That space behind the door is so nice and long/deep I would love to take advantage and rid my interior of a sliding container of tools/parts/fluids.
A bunch of strong neodymium magnets would be really cool way of snapping it up there. But most likely bungy cords to start. If it even fits...just wondering if anyone has done it before I go get dirty with my tape measure.
SCM
SCM is offline
PostPosted: Thu Jul 22, 2021 11:31 am    Post subject: Re: Under storage rifle case? Reply with quote
I don't really understand what you're talking/asking about. You want to store a rifle under your van? That sounds insanely insecure, both in terms of the rifle's mechanical safety and the potential for theft.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
Selsk
Selsk is offline
PostPosted: Thu Jul 22, 2021 11:37 am    Post subject: Re: Under storage rifle case? Reply with quote
sorry, not a rifle. Just a rifle case with tools in it.
RoryGirl
RoryGirl is offline
PostPosted: Thu Jul 22, 2021 11:41 am    Post subject: Re: Under storage rifle case? Reply with quote
You're going to need all the magnets
Selsk
Selsk is offline
PostPosted: Thu Jul 22, 2021 12:24 pm    Post subject: Re: Under storage rifle case? Reply with quote
I feel like a pack of these https://www.amazon.com/DIYMAG-Neodymium-Magnets-Do...2ARZO?th=1 epoxied on the case and frame would do the trick. But would have to see, would suck to loose a hard case of tools.
pnwkayaker
pnwkayaker is offline
PostPosted: Thu Jul 22, 2021 12:53 pm    Post subject: Re: Under storage rifle case? Reply with quote
If you have your spare tire on an external carrier, the tire tray is an awesome place to put a container to store fluids, spare parts, etc. There're several threads with info about it.
Going back to your original question, I don't like the idea of using the rifle case in that location because it's difficult to open/remove without spilling everything out.
I've seen folks build a tray with angle iron, mesh wire (or similar) and hinges to enclose the space between the rails on the side and then using Pelican boxes or other containers to store fluids, etc (easier to attach to the tray using rope, wire, etc).
87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link)
dobryan Premium Member
dobryan is offline
PostPosted: Thu Jul 22, 2021 4:26 pm    Post subject: Re: Under storage rifle case? Reply with quote
You need to account for the g forces on a shock load when uou hit a pithole or similar. Maybe several g of force exerted.
Dave O
Traveling after Building a bus for travel in Europe (euroBus)
The Western Syncro build
DanHoug
DanHoug is offline
PostPosted: Thu Jul 22, 2021 5:56 pm    Post subject: Re: Under storage rifle case? Reply with quote
there's so VERY few truly waterproof storage boxes, especially when length is involved vs square. it's all about the sealing-to-latch pressure interface and the longer you go, the more latches you need.
there's few things worse than an ALMOST water-tight box...let's moisture in and never out. things rust rilly fast. military 'rocket boxes' are good but their width doesn't fit between the structural rails. it's a horrible envrionment to try to seal with an openable box.
-dan
www.thefixitworkshop.com
Crankey
Crankey is offline
PostPosted: Thu Jul 22, 2021 7:59 pm    Post subject: Re: Under storage rifle case? Reply with quote
I've seen the floor cut out box. I like that way better than having stuff outside the body shell.
Maybe because I'm a welder and could use a little rust cut out of the floor anyway.
If I were to attach a storage box I'd do it with bolts. I've used the magnets to attach things but magnets work best when they touch metal to metal with more than a couple layers of paint, no undercoating.
That said, it's probably worth experimenting with. Who knows you might need to detach that box with a pry bar ?
Sodo
Sodo is offline
PostPosted: Thu Jul 22, 2021 8:14 pm    Post subject: Re: Under storage rifle case? Reply with quote
With the proper amount of magnets, yes, a crowbar.
I wouldn't glue a shiny nickel plated magnet to a plastic case and put my tools hanging on that.
They need to be the washer-type, with a countersunk screw.
I put a 2gallon gas can in that area under the slider.
I built a cradle for it that holds the weight with steel.
Have to lift it up a little and slide forward to drop the rear out.
Here's the thread: 2 gallon fuel tank (...a get outta jail card)
'87 Tintop, EJ25, cooled filtered (original) gearbox
....KTMs, GasGas, SPOT mtb
All Vanagons should do this:
Add direct starter-to-chassis cable THEN delete ground strap at front transaxle mount.
The best time to do this mod was in 2010. The second best time is TODAY.
If your starter is slow, this is MORE important.
Selsk
Selsk is offline
PostPosted: Fri Jul 23, 2021 11:35 am    Post subject: Re: Under storage rifle case? Reply with quote
Man that fuel tank looks amazing, nice job fabricating.
I'm going to try a prototype with a small pelican case I have. Basically a big Hide-A-Key box.
These look pretty cool too:
https://www.amazon.com/Neodymium-Rectangular-Magne...&psc=1
Selsk
Selsk is offline
PostPosted: Fri Jul 23, 2021 11:39 am    Post subject: Re: Under storage rifle case? Reply with quote
Pelican cases are pretty good. Plus, I am in California...I think I have driven the van 2 times in the rain. The van isn't my primary vehicle. It would be cool to have some oil & fluids, cleaning stuff, jumper cables etc.
PDXWesty
PDXWesty is offline
PostPosted: Fri Jul 23, 2021 11:56 am    Post subject: Re: Under storage rifle case? Reply with quote
These posts have examples of storage in this area:
https://www.thesamba.com/vw/forum/viewtopic.php?t=497051
https://www.thesamba.com/vw/forum/viewtopic.php?t=711071
https://www.thesamba.com/vw/forum/viewtopic.php?t=649165
https://www.thesamba.com/vw/forum/viewtopic.php?t=650456
89 Westy 2.1 Auto
SyncroHead
SyncroHead is offline
PostPosted: Fri Jul 23, 2021 12:32 pm    Post subject: Re: Under storage rifle case? Reply with quote
Selsk wrote:
That space behind the door is so nice and long/deep I would love to take advantage...
Did you mean "below" the door?
If so, I'm kind of liking the idea of a rifle-sized pelican case. I imagine fastening the lid of the case to the floor of the van with bolts with the hinges facing the center of the van. As long as the sturdy clasps were accessible, they could be undone and the bottom of the case would swing down to get at the contents. Contents would shift a bit as the case swung down, but sounds workable.
Something like this photoshop mock-up:
Jim Davis
"A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote:
I have *no* idea what the previous owner carried in his Westy... angry donkeys?
joetiger Premium Member
joetiger is offline
PostPosted: Thu Sep 23, 2021 5:43 am    Post subject: Re: Under storage rifle case? Reply with quote
Thought I'd update this thread with another storage box idea.
My last, temporary storage box didn't do so well. Perhaps I should have taken the hint the last time I had to duct tape it back together.
But I liked the dimensions. This RIGID 22" tool box was $31 at HD. It's allegedly water-resistant, meaning you can't totally submerge it but it should be fine with road spray. It has a silicone seal around the rim and clamps down tight.
Various hoses, clamps, splices, cap, rotor, wires, fuel pump, CV joint & boot, v-belt pulleys. all the sensitive stuff in plastic bags.
It has a spring-loaded handle on the front so it's easy to pull out of the clamshell, too.
It doesn't use up all the space, but it should work for my needs.
Joe T.
'02 Baja-ish Beetle "Bubbles"
mikemtnbike
mikemtnbike is offline
PostPosted: Thu Sep 23, 2021 6:24 am    Post subject: Re: Under storage rifle case? Reply with quote
That looks great Joe, especially like the little compartments.
2020 GTI SE manual
Corwyn Premium Member
Corwyn is offline
PostPosted: Thu Sep 23, 2021 8:16 am    Post subject: Re: Under storage rifle case? Reply with quote
If you need a rifle case full of tools, you're maintenance is shabby or youre takingtoo much stuff. Just my opinion . . .
'90 White Westy ("White Lightning")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~
joetiger is offline
PostPosted: Thu Sep 23, 2021 8:27 am    Post subject: Re: Under storage rifle case? Reply with quote
It's a tool box full of parts, based on mechanical failures I've experienced in the past. Probably it's more for peace of mind than anything, but burned up pulley bearings, ruptured hoses, and shitty ignition parts have put me on the side of the road here and there in the past, so I prefer to be prepared.
Joe T.
dobryan is offline
PostPosted: Thu Sep 23, 2021 8:29 am    Post subject: Re: Under storage rifle case? Reply with quote
I feel naked without tools. I use them on other buses more than my own.... Cool
Dave O
joetiger is offline
PostPosted: Thu Sep 23, 2021 8:31 am    Post subject: Re: Under storage rifle case? Reply with quote
Same with some parts. I remember when Pam and Jeremy fried their ignition switch at Syncro Solstice one year. They asked if anybody had a spare and around ten people ran up with a new ones in hand. Very Happy
Joe T.
