Arnolds64 Samba Member
Posted: Fri Feb 15, 2008 3:07 pm Post subject: Straight Cuts |
Put them in my street 2017. I did however buy the less noisy CB's. I really can't hear them that much from the drivers seat. Whe you rebuild why not improve it? If it gives me a few extra ponies and will let the valve train rev easier for not a bunch of money then why not. I looked at it this way. I did not go with light lifters so taking friction away may equal it out. My little stroker really revs well and it needs some tuning yet. the sound is more of a whining at idle and that is about it. I really don't notice much on my however just a hint. So if noise is loss of HP then the CB's must be the best?
I mean lets face it. With a merged Header and a big Dynomax hanging out back you can't tell much of a difference from one noisy thing to the other. If you want quiet you are into the wrong cars. Go to a Lexus forum or something. _________________ 64 Bug, White, 2017, Dual Weber 44's, Engle 130/Engle lifters, Home P&P'd 40X35 heads, CB 4340 nitrided crank, Eagle knock off H Beam 5.5" rods, Lowering Beam, Rancho Trans, Traction Bar. 225X60's rear, 145's front on Porsche Chrome Nipple Wheels. |
shegel Samba Member
Joined: November 03, 2006 Posts: 378 Location: Kennewick, WA
Posted: Fri Feb 15, 2008 2:28 pm Post subject: |
just because i hear people talking about them everyonce and a while. what exactly is the benefit to running strait cut cam gears. just so you can run heavier valve springs? im kindof confused _________________ My stuff with engines
1969 Karmann Ghia
1999 Jetta tdi
1977 Honda gl1000
1993 Honda xr250L |
jamestwo Samba Member
Posted: Sat Feb 02, 2008 7:23 pm Post subject: |
not sure, just what i was thinking. what is greater loss, the noise or the friction of the side load on helical gears?
I'm in favor of them by the way, I just make them quiet.
How? offset cam bearings.one more secret out the bag for you, must be .5 hp there.
Bruce wrote: |
jamestwo wrote: |
It takes HP to make noise....energy is not free and noise is energy. |
So you are saying straight cut gears rob hp? |
_________________ hEY, lOOK, i'M WRONG HALF THE TIME, AND THE OTHER HALF i'M NOT SURE WHAT THE HECK i'M TALKING ABOUT. MY POST ARE FOR MY OWN ENTERTAINMENT VALUE ONLY. |
millerje78 Samba Amishman
Joined: October 16, 2005 Posts: 2445 Location: Holmes County, Ohio
Posted: Sat Feb 02, 2008 3:11 pm Post subject: |
Glenn wrote: |
Eaallred wrote: |
Just remember: If you install some straight cut gears strictly for the sound, you lose all privelages of making fun of the ricers.
Nothing sounds more badder-ass than a 1776 with a set of Kadrons, a stinger, and a set of straight cuts.  |
I generally can't hear any sounds that are behind my car, so run whatever you like
Seriously... run what you like. The only you you need to please is yourself. |
Herr Ring does not need such things to improve the sound of his engine.
_________________ always seeking a better way
my 73 standard project
do your research, consult with experts, and buy quality parts. you won't be sorry |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17634 Location: Left coast, Canada
Posted: Sat Feb 02, 2008 2:29 pm Post subject: |
jamestwo wrote: |
So you are saying straight cut gears rob hp? _________________
Posted: Sat Feb 02, 2008 10:05 am Post subject: |
It takes HP to make noise....energy is not free and noise is energy. _________________ hEY, lOOK, i'M WRONG HALF THE TIME, AND THE OTHER HALF i'M NOT SURE WHAT THE HECK i'M TALKING ABOUT. MY POST ARE FOR MY OWN ENTERTAINMENT VALUE ONLY. |
kekonaiii Samba Member
Posted: Sat Feb 02, 2008 9:48 am Post subject: |
I like to use straight cut gears in stock motors. When I rebuild peoples stock motors I put Counter weighted cranks and straight cut gears and Double Thrust Cam Bearings. In my own opinion I feel this makes for a better stock motor, things that cause less wear...
For high performance do what you want to do. I would always put the straight cut in unless told not to by the customer.. |
70VWkid Samba Member
Posted: Sat Feb 02, 2008 9:18 am Post subject: |
finally some people who are actually for them! |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1662 Location: Marshallville Ohio
Posted: Fri Feb 01, 2008 3:27 pm Post subject: |
That video doesn't sound like straight cut's to me. More like fan rubbing fanshroud noise. |
bugnut68 Samba Member
Joined: June 10, 2003 Posts: 4180 Location: Eugene, OR
Posted: Fri Feb 01, 2008 10:06 am Post subject: |
Eaallred wrote: |
Shoot, muffler aside, that's my combo right there... In all honesty, while I do like the sound of my Magnums, I also bought mine with the anticipation of future upgrades... |
Posted: Thu Jan 31, 2008 9:18 pm Post subject: |
That is correct that is something we use to do in Hawaii back in the 80's |
CJG Samba Member
Joined: November 07, 2005 Posts: 571 Location: Phoenix
Posted: Thu Jan 31, 2008 9:14 pm Post subject: |
sorry that is not a strait cut gear noise, I have seen it done before with the fan. that is the fan making that noise, please  |
Posted: Thu Jan 31, 2008 9:07 pm Post subject: |
I bet you that car is from Hawaii... |
Fattie I'd roll it
Joined: November 27, 2005 Posts: 5582 Location: louisiana
Bad bug Samba Member
Posted: Thu Jan 03, 2008 6:29 pm Post subject: |
57 Rag wrote: |
I got a set of Scats in my new motor and can't tell I have them unless you really listen for it. I wanted them quiet but not that quiet.  |
Is that the scat drag fast gear. I have one just haven't used it as yet. Did you set the torque on the gear to 22lbs or 20lbs. |
Posted: Thu Jan 03, 2008 1:37 am Post subject: |
I ran a set of dyna gears (bought at swapmeet &10.00) the year before last all season in the drag car. It runs 11.81ET 1/4 mile at best and the car is 1650lbs. I had no problem making every PRA event but one.
of course we just threw the motor together just so we could go race and it worked well so why change it. I will run the same gear this coming year and I am not worried about it. I think the Dyna gear in good enough for the street application...I'll sell you mine since it's already tested for 5.00. just kidding..
I run straight cuts in everything even the stock motors. The gears I use don't have a big giant whine. Even a stock motor pushes hard on a thrust bearing..
You can't make a wrong choice do what you like. You have enough info to make the choice...
Aloha Kona |
57 Rag Samba Member
Joined: October 24, 2006 Posts: 1145 Location: Paradise
Posted: Wed Jan 02, 2008 9:53 am Post subject: |
I got a set of Scats in my new motor and can't tell I have them unless you really listen for it. I wanted them quiet but not that quiet.  _________________ 57 Ragtop
84x94 86C
IDAs |
CJG Samba Member
Posted: Tue Jan 01, 2008 8:12 pm Post subject: |
When I was a senior in High School in 1988 I was the first to have the straight cut gear deal and the whine, little 1835 with a 120 cam and some 40IDF, probably only made 110 hp but it kicked everyones ass and sounded cool at the same time, I have had the same gear set since then which is Magnum, steel on steel. Yeah I like the sound but the motor is pretty stout now being a 2276 and making just over 200 hp at 6700 RPM'S. The sound is to each and their own taste. If your making more than 170 hp you will probably want to run the straight cuts. Good luck  |
Posted: Tue Jan 01, 2008 12:22 pm Post subject: |
So just install them for the reason I have listed above and steer clear of dis-honor. LOL....
The V-8 croud has done it for the same reasons for years.
I like Mangnum, CB, Scat, Competition Engineering, etc... As long as they are billet.
Don't get cast Dynagear or the super cheap dynagear-copies either.
The loudness of them will depend on the case and the brand of gears used.
CB's are quite for one person, and loud for another (in a different case). |
Posted: Tue Jan 01, 2008 12:07 pm Post subject: |
Eaallred wrote: |
2ND that again. |
