Buttafuoco Samba Member
Posted: Mon May 18, 2009 7:33 pm Post subject: Sync Dual weber carbs w/o sync tool? |
| I need to get my carbs syncronized ASAP as I'm in a bind and need to get the car running and have no sync tool handy at the immediate moment. They are weber 34ict's. They worked pretty good for the most part then I started f**king with the what I believe is the mixture screw and all went bad. Can anyone lend some knowledge. |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22679 Location: Escondido CA
BSQUARE Samba Member
Joined: November 05, 2004 Posts: 1898 Location: Feeling, Minnesota
Posted: Tue May 19, 2009 5:51 am Post subject: |
In leiu of the synch tool, you can use a 2 or 3' section of small diameter flexible hose (fuel line, vinyl tubing, etc. I use a stethoscope with the 'drum' removed)
Hold one end in your ear, and the other end at the top of each carburetor.
When the pitch of the 'hiss' is the same on both carbs, they're drawing air at equal volumes. _________________ 1968 Regatta Blue Squareback
1967 Granada Red Squareback
1971 Rattle-Can Red Westfalia Camper |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue May 19, 2009 6:16 am Post subject: |
And spend the $20 and get a sync tool as soon as possible. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
69sqbck Samba Member
Joined: August 12, 2004 Posts: 311 Location: Savannah, GA
Posted: Tue May 19, 2009 7:45 am Post subject: Tuning |
Go to: http://www.redlineweber.com/html/Tech/34_ICT_tunning.htm for the factory baseline settings for Weber 34ICT carbs. Without a sync you will never get them perfect but this should get you going. _________________ Don't think of yourself as an ugly person, think of yourself as a good looking Monkey!!!!!
1968 Ghia Vert
1969 Type 3 Squareback
1969 Type 3 Fastback
(o)\|/(o) Sole Designs, VW Restorations, Savannah, GA |
RafCarre12 Samba Member
Joined: January 06, 2008 Posts: 1019 Location: Glen Rock, NJ
Posted: Tue May 19, 2009 11:29 am Post subject: |
hmm, does anyone have the proper settings (is there such a thing) for baby dels? (34s) _________________ Type 3 Fasty |
Posted: Tue May 19, 2009 3:46 pm Post subject: |
You need to go down the same path like Solex, Brosel and Webber. Tune them to the motor with a balance tube, a dwell meeter and a sync. _________________
| t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
mark111 Samba Member
Posted: Tue May 19, 2009 10:04 pm Post subject: |
| use the redline info for a start point, then lean them out 1/4 turn at a time. run the rpms up and hold them, if theres popin , keep leaning. i just did mine this way , it takes patience, but you can do it. |
Posted: Tue May 19, 2009 10:18 pm Post subject: |
| oh, and once the carbs arnt poping , take it for a short putt around, and take a flat head, it will need to be "fine tuned" under load. and if you have the 009, 1st gear will always be tuff. try the svda distibutor when you can afford to upgrade. good luck. |
ozker Samba Member
Joined: September 08, 2010 Posts: 5 Location: south bay
Posted: Fri Sep 24, 2010 5:45 am Post subject: |
I know these are old post but i am just checking to make sure I get this right.
I have just puchased dual 34 ict webers and I wish they would put more pictures with details anyways I would like to sync my carbs.
I have a rubuilt 1641, the tube type synch and a timing gun that also reads the rpm of the vehicle.
My first question is, I only see two screws, one of the screws is low and has a spring on it and it goes right into the body of the carb. What do they call this screw and does it have many names?
The other screw is directly connected to the what controls the butterfly and the linkage.
When I sync should I set the synch tool on one carb and adjust the other? and what screw should I start adjusting first?
My timing is set at 10 deg is this ok I read somewhere that it should be 32 deg and that doesnt sound right. |
Posted: Fri Sep 24, 2010 6:00 am Post subject: |
32 degrees total advance.
Put the sync tool on one carb and get a reading, and then move it to the other carb, and adjust it to the same reading.
Keep moving back and forth until you get the 2 adj. the same.
Now, bring the RPM up to about 2500 rpm, and check them again. Adjust the throttle linkage until they are both about the same. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
ozker Samba Member
Posted: Fri Sep 24, 2010 1:02 pm Post subject: |
Ok so the timing should be 32 after TDC?
How about the fuel adjustment how do you synch that? |
ozker Samba Member
Posted: Fri Sep 24, 2010 2:14 pm Post subject: |
| And what should my rpm be |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23533 Location: Kimball, Mi
Posted: Fri Sep 24, 2010 2:33 pm Post subject: |
| ozker wrote: |
If you're using an 009 distributor, you want to set the total timing at 30 degrees at 3000 rpms, and let the idle fall where it will.
As for fuel adjustment, you set it where it runs the best. You might want to do a search for ICT tuning instructions, as I know someone was looking for a set and found them on CB Performance's web site. That will help you dial them in, and the instructions are much better than the 1/2 page you get from CIP.  _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
ozker Samba Member
Posted: Fri Sep 24, 2010 2:35 pm Post subject: |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11131 Location: Black Forest, CO
ozker Samba Member
Posted: Sat Sep 25, 2010 9:20 pm Post subject: |
Ok first let me say a thousand thanks to you guys and this site. After listening to the advise you guys gave me and doing some web research synchro carbs isnt really that hard, but it can't be rushed.
First I ran the mixture screw all the way in with out cramming it, and then I backed it out 2 fulll turns.
Second I backed out the idle screw to were it just touched the stop and then I turned it in 1 1/2 turns in. I dont know but it semmed to me like Weber drives the screw in a lot cause it took what seemed to me like a lot turns to back it out.
Next I had to set the timing so I got the rotor near number 1 plug and then set the pulley near 30 deg BTDC I then got a voltmeter ( but a test light could also be used) and put the neg lead of the voltmeter and clipped it on to the neg end of the coil. The pos end I clipped on to a grounded part of the vehicle ( any part ). I then moved
the dist. till I got 12 volts on the meter, that got me real close to where it needs to be.
I fired up the engine and did my adjustments and everything came out great. No popping, smooth running, it doesnt run hot and its got power like it should. I live where ther is a lot of hills and stop signs but it doesnt have any problems taking off.
If there is one thing I learned it is before you start the engine check and recheck the linkage. Make sure both carbs open and close at the same time. Also after all adjustments are made recheck that all carbs open and close together.
Thanks a lot for all the help guys. |
