CanStan Samba Member
Joined: October 16, 2005 Posts: 1040 Location: Calgary, AB
Posted: Mon Jul 23, 2018 9:26 am Post subject: Re: Allstate single wheel service parts list / set up tips |
I want to build a complete spare tire/wheel/bearing assembly to carry with the trailer. I have several long road trips planned this summer, and it would be nice to be able to do a quick change if something goes wrong. My question is about the rim- the only thing I'm finding that would work is a wheelbarrow rim. Nothing else at the trailer places is the same as the Allstate rim. Will a heavy duty wheelbarrow rim do the trick as long as I find a proper trailer tire and bearings for it? What have others done?
Here's my current wheel. It's not the 2 piece bolt together type. I'm not sure if it should be for my trailer, or if this is the original? I don't particularly care as long as I can get something that will work safely.
ottvw Samba Member
Joined: February 28, 2006 Posts: 928 Location: Auburn,WA
Posted: Thu Aug 16, 2018 12:28 pm Post subject: Re: Allstate single wheel service parts list / set up tips |
Anyone have luck on a wheel? Searching everywhere and can’t find a replacement. _________________ Save a tree eat a beaver |
Posted: Mon Aug 20, 2018 7:38 am Post subject: Re: Allstate single wheel service parts list / set up tips |
ottvw wrote: |
Anyone have luck on a wheel? Searching everywhere and can’t find a replacement. |
Not yet. But I need to get some time and pull my current wheel apart to see how it is shaped inside the hub where the bearing sits. It was freshly greased when I got it so I didn't bother taking them out at the time to see.
A standard wheel barrow bearing won't be rated to handle the speed required of it, and a proper speed rated bearing will have a taper to it. If the outer race of the bearing will allow it to fit into a wheel barrow rim, I don't see why it would be an issue using it. However, if the Allstate rim has a taper built into the inner hub to accept the high speed bearing, that's going to be an issue.
From all outward appearances, it sure seems to be the same as a wheel barrow rim. |
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
Posted: Tue Aug 21, 2018 3:39 am Post subject: Re: Allstate single wheel service parts list / set up tips |
CanStan wrote: |
ottvw wrote: |
Not sure if you've seen this
https://trailerpartssupplies.com/mounted-tires-and...rings.html
Some Specs on it:
Load range: C (You'll have to dig around to find out what that means)
Maximum load: 760 lbs
Tire pressure: 90 psi
Wheel size: 8" x 3.75"
Offset: 0
Wheel color: White
You'd have to check around to see if their DOT rated also. Hope this helps _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
ottvw Samba Member
Posted: Tue Oct 23, 2018 8:18 am Post subject: Re: Allstate single wheel service parts list / set up tips |
Does anyone know the size of the spacer that goes on either side of the wheel and where to find them? _________________ Save a tree eat a beaver |
Posted: Fri Oct 26, 2018 7:51 am Post subject: Re: Allstate single wheel service parts list / set up tips |
ottvw wrote: |
Does anyone know the size of the spacer that goes on either side of the wheel and where to find them? |
There seems to maybe be a few different styles. If yours is anything like mine, it has a threaded stud through the whole assembly. I have thin washers and 1/2" thick spacer nuts against the bearings that need to turned in or out to get the correct bearing adjustment. Outward of those, I have the 'L' shaped brackets that attach the wheel assembly to the leaf springs, and holding those in place is a castle nut to keep the whole assembly together. It took a lot of messing around to get everything adjusted properly and even from side to side.
Hopefully this helps a bit? I suppose if your centre shaft isn't threaded you could just use some sort of pipe as a spacer. But it would have to be pretty thick so it doesn't load the bearing off centre I would think.
Posted: Fri Oct 26, 2018 7:57 am Post subject: Re: Allstate single wheel service parts list / set up tips |
MonT3 wrote: |
Some Specs on it:
Offset: 0
Wheel color: White
You'd have to check around to see if their DOT rated also. Hope this helps |
Not sure how I missed this post? Thanks for the link! That looks like it might do the trick. I'll have to look into it a little further. |
ottvw Samba Member
Posted: Sat Oct 27, 2018 6:11 pm Post subject: Re: Allstate single wheel service parts list / set up tips |
CanStan wrote: |
ottvw wrote: |
I found that Harley axle spacers will work. There a 3/4” axle and they make them in a variety of lengths. _________________ Save a tree eat a beaver |
Posted: Thu Jul 25, 2019 5:35 pm Post subject: Re: Allstate single wheel service parts list / set up tips |
I finally got around to pulling my bearings to check and re-grease them. I'm glad I checked because they weren't in very good shape. Interestingly, they are different bearings than what has been recommended in this thread and elsewhere. They actually seem to be a common bearing for '90's Harley Davidson bikes among other things. They also seem to be a lot cheaper than the recommended bearings (as far as I could find anyway). I ordered a replacement set of them from Rock Auto. For $12 Canadian I got 2 of each Timken bearings and races. The other bearings seemed to be 2x or even 4x the price of these, although maybe someone has a better source than the places I looked.
That being said, I haven't been able to confirm 100% that my rim is a proper Allstate rim. I've never seen another up close to confirm, so these bearings may or may not work for you.
Here are the Timken part numbers for bearings and races:
LM11949 for the bearing and LM11910 for the race
Here is my rim. You can see the lip inside where the race butts up to. I'm not sure if that's the same as an original?
And here is the bearing and grease seal installed:
Hopefully this helps someone else out. These bearings also seemed easy to find from lots of sources so maybe a good option for anyone looking. |
vintagevwnut Samba Member
Joined: November 25, 2007 Posts: 175 Location: Plainfield, Il
Posted: Mon Jul 29, 2019 5:19 am Post subject: Re: Allstate single wheel service parts list / set up tips |
Yeah hard to say. But depending on the year there were two different manufacturers of Allstate trailers for Sears. Also possible the parts changed throughout the years. Or that it’s a different wheel because of a previous owner.
Did ya get it working? |
Posted: Mon Jul 29, 2019 3:12 pm Post subject: Re: Allstate single wheel service parts list / set up tips |
vintagevwnut wrote: |
It works great with those bearings. One of these days hopefully I'll be able to look at another wheel to compare. Although they've been around long enough, it would be pretty hard to be certain any of them have the original wheel anymore. |
Posted: Fri Aug 02, 2019 3:13 pm Post subject: Re: Allstate single wheel service parts list / set up tips |
CanStan wrote: |
So looking in your gallery I see your trailer is a later one built in Iowa. When I started this thread I didn’t even realize that there were two different manufacturers. I don’t remember the name of the later Iowa manufacturer. But the earlier one was Dunbar Kaple (Kapple?) in Geneva IL. I also have not bothered Everett to modify the original post (it’s to old I can’t) with the other info. I suppose we could. |
Posted: Mon Aug 19, 2019 8:17 am Post subject: Re: Allstate single wheel service parts list / set up tips |
Interesting. What are the differences between early and late? Any idea of the year the manufacturer changed? Using references here and at singlewheel.com I was able to pin it down to between 1961 and 1971. A lot of that was using the Sears advertisements through the years to compare the features, but there were a lot of them missing between those years so it was hard to tell for sure. I think in '72 they changed to brown paint so I think that was why I guessed it was at least earlier than that. I'd be interested to know anything more I can about it. Thanks! |
Posted: Mon Aug 19, 2019 8:26 am Post subject: Re: Allstate single wheel service parts list / set up tips |
CanStan wrote: |
Per Jon LaTorre, someone I helped a little with local research on Allstate trailers- ‘61 was the first year for the Iowa production of the Sears Allstate.
“In the Spring and Fall 1973 Catalogs, the price is now $159.95, and in the Spring and Fall 1974 catalogs it's $164.95. But in the Spring 1975 issue, the price soars to $224.95. That price remains in effect until the Fall 1975 catalog, the last catalog to list the single-wheel trailer.” |
Posted: Mon Aug 19, 2019 9:02 am Post subject: Re: Allstate single wheel service parts list / set up tips |
Good info. Thanks! |
vwvega Samba Member
Joined: April 24, 2009 Posts: 3 Location: NEW YORK, NEW YORK
Posted: Fri Dec 20, 2019 5:51 pm Post subject: Re: Allstate single wheel service parts list / set up tips |
Hi, I have a single wheel Allstate trailer. It is one with like a steering damper. Do anyone knows what kind of steering damper shock absorber thingy I could replace it with? _________________ VWVEGA |
Posted: Fri Dec 20, 2019 5:58 pm Post subject: Re: Allstate single wheel service parts list / set up tips |
vwvega wrote: |
Hi, I have a single wheel Allstate trailer. It is one with like a steering damper. Do anyone knows what kind of steering damper shock absorber thingy I could replace it with? |
Pics? Sounds like a Heilite, not a Allstate |
kaferdude Samba Member
Joined: December 29, 2003 Posts: 51 Location: Syracuse, NY
Posted: Wed Feb 03, 2021 2:36 pm Post subject: Re: Allstate single wheel service parts list / set up tips |
Recently purchased a very solid Allstate one-wheel trailer with a bill of sale but no title/registration (looks like it has the original Allstate tire too). The trailer data plate indicates model #231 96360 and serial #E9222 but I can't find a year of manufacture anywhere. Based on the Singlewheel website and the Dragonwiz article:
http://dragonwing.biz/sears%20swt.htm?fbclid=IwAR0...VdjUKu6454
the trailer appears to be a 'Second Generation' mid-to-late '50's trailer.
I'd like to register the trailer in NYS but the DMV requires a year of manufacture. It would be nice if I could provide them something besides my best 'guess'.
- Ques 1: Is there a written listing somewhere with the model and/or serial numbers of Allstate trailers by year?
- Ques 2: I've seen pictures of Allstate data plates that have model #231 963. I'm not sure why my trailer model # has the additional '60' at the end of it. Someone told me it means it might be a Canadian model but they weren't sure. Any idea what the '60' means?
- Ques 3: Is there a number listed somewhere else on the trailer (besides the data plate) which might indicate the yr of manufacture? If so, where? I can't find one on mine.
Thanks,
Dan
Envious Samba Member
Joined: January 08, 2003 Posts: 1821 Location: Toronto, Ontario, Canada
Posted: Wed Feb 03, 2021 3:58 pm Post subject: Re: Allstate single wheel service parts list / set up tips |
kaferdude wrote: |
Thanks,
Dan
I saw that trailer. Good deal!! _________________ 71 Type 1302 Custom
64 Type 151
63 Type 117 L469 Anthracite
64 Type 361 L575 Nutria
64 Porsche 356c
56 Type 113 L227 Strato Silver
52 BSA C11G
59 Heilite Single Wheel Camping Trailer
56 Allstate Single Wheel
84 Vanagon Westfalia
http://www.thesamba.com/vw/forum/viewtopic.php?t=388225 |
panel Samba Member
Joined: December 02, 2001 Posts: 1091 Location: Victoria B.C. Canada
Posted: Sun Aug 08, 2021 4:05 pm Post subject: Re: Allstate single wheel service parts list / set up tips |
Are most of you guys running the 45lbs recommended ? Have you found that if it's to bouncy that it's better to lower the PSI ? _________________ My '65-Subaru EJ20 Turbo conversion |
