"What wheels fit?" The ultimate wheel post.
Page: Previous  1, 2, 3 ... , 174, 175, 176  Next
Crooked Designer
Crooked Designer is offline
PostPosted: Tue Nov 05, 2024 8:25 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
cdussault wrote:
Hi there,
Really like the Mobelwagen's - really havent seen many pics of what they look like on vanagons. Seems like all pics are either to dark or shot at angle. Those of you that have them, any pics you can share? One other question, are they the same weight as the GW/ASA wheels? (22lbs).
Thank you!
Same question. Looking to go up to 16s on my van and these are the lead contender right now. Any reports from those running them? I'd also love to see what setups use these riding at stock height.
'85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit
thejameshansen
thejameshansen is offline
PostPosted: Tue Nov 05, 2024 9:14 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
I was browsing Instagram this morning and noticed @surlydoka has a few clear shots of the 512B on his orange Doka.
1990 Vanagon GL passenger van, 2wd, 2.1l, auto
Crooked Designer
PostPosted: Tue Nov 05, 2024 10:39 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Thanks! I'll DM and find out if it's lifted. Hard for me to tell.
tdivan82 Premium Member
tdivan82 is offline
PostPosted: Tue Nov 05, 2024 11:05 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Mobelwagen Interceptor 512B with Yokohama Geolandar A/T in 215/70-R16. Schwenk Westy springs which are a near-stock height (less than 1" lift). I like these Interceptor wheels because they accept the OEM style hubcaps for a period-correct look, and because they're light at 23 lbs each. I don't like the 7.5" width, which fits, but is less than ideal. A 6.5" wheel width would be a better match for a 215 tire.
Close up:
82 Westy TDI (ahu)
Crooked Designer
PostPosted: Tue Nov 05, 2024 12:12 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Amazing. Thanks!
nullacrux
nullacrux is offline
PostPosted: Fri Nov 15, 2024 11:59 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
I got stuck overthinking things but then finally read the fine print on ASA Type 9 : these rims eliminate need for spacers/new lugs/stud changes etc etc… makes life simple Cool I got the 16x7.5 from tire rack. 215/65/16 Grabber. No ET issues. Stock suspension. PERFECT FITMENT. Absolutely no issues on hard turns or speed bumps.
Much smoother and really stable ride.
finalwest
finalwest is offline
PostPosted: Tue Dec 10, 2024 11:21 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
205/80r16s on a gowesty lifted Multivan. Cheap tires but they ride well and will probably dry rot before I wear them out.
dhaavers
dhaavers is offline
PostPosted: Tue Dec 10, 2024 1:36 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
finalwest wrote:
205/80r16s…Cheap tires…
Achilles Desert Hawk, perhaps? No fair keeping secrets…
Wink
- Dave
PS…needs posting here: https://www.thesamba.com/vw/forum/viewtopic.php?t=584507
"The WonderVan"
finalwest
PostPosted: Tue Dec 10, 2024 1:44 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Wink
- Dave
You are correct Mud Terrains
LOL No Secrects Laughing I thought you could see them on there. These aren't the tires for the majority of our sophisticated compadres on this site. But I like em so far. ONly have have 500 miles on them.
https://www.prioritytire.com/by-brand/achilles-tires/desert-hawk-xmt?var-achilles=34488
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu Jan 02, 2025 2:44 pm    Post subject: Re: VW Beetle Heritage Wheel Reply with quote
[quote="dagriztx"]
mxitup wrote:
Wheel Specs:
VW Heritage Wheel (CZ8)
5x112, 17x7, ET43
Center bore 57.1mm
17" Wheel Black: 5C0-601-025-M-AX1
17" Wheel White: 5C0-601-025-G-Y9C
Chrome Center: 5C0-601-149-D-QZQ
Chrome Ring: 5C0-601-157A
I just scored a set of 4 wheels like these for 80 bucks, but one chrome ring is messed up. No center cap, which I don't care much for anyway.
I was wondering if some of you had an extra ring they didn't use that they would sell?
I bet some of you are running them with the chrome center cap and no chrome ring Very Happy
Aloha!
Alika
thejameshansen
PostPosted: Tue Jan 07, 2025 2:14 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Cross-posting from the GoWesty alloy wheel replica thread.
Here's my van with the new GoWesty OEM-look wheels mounted. These are 16x7.5-inch wheels with 215/60R16 Vredestein Quatrac tires. Everything fits nicely, except the sliding door rubs the right-rear tire a decent bit. I can open the door, but I'm worried a zealous passenger could damage the sidewall.
The look of these GW wheels is great—a bit over-branded, but they got the OEM look just right. The change in sizing has made for a great improvement in braking, handling, and highway speeds. Acceleration feels the same around town but is a bit slower from 40 to 60mph.
Here's a "before" pic for comparison. 14" steelies on low mileage but old 185R14 Hankook Vantras.
Overall, I'm happy.
Twan
Twan is offline
PostPosted: Fri Jan 10, 2025 4:08 pm    Post subject: Re: VW Beetle Heritage Wheel Reply with quote
Aloha!
Alika
If you can't find a single, you can always get a new one. https://www.shopdap.com/69ae4543284923120dfd82b6f1b7d13d.html?gQT=2
1984 2wd 7 Passenger Tin Top
chrisrsamba
chrisrsamba is offline
PostPosted: Fri Jan 24, 2025 8:18 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Can any of you tell me what wheel this is? I stopped off at the beach near SF to see what tires this owner was running, since I can no longer get Nokian WRG's in 215-65/16 (garage door max height issue, sigh). Nice looking Toyo tires. a little chunky but seem to have stiff sidewalls, he said he really liked them so far. Then later I realized from the picture his wheels were pretty snazzy, but they are kind of Method clones (NOT from Burley). Any idea what they are?
Christopher Schimke
PostPosted: Fri Jan 24, 2025 8:27 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
ASA Type 9
https://www.tirerack.com/wheels/WheelCloseUpServle...t=Featured
chrisrsamba
PostPosted: Fri Jan 24, 2025 8:32 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Wow...when you know, you know! Thanks!
webberjames95
Snorkelstang Finder
webberjames95 is offline
PostPosted: Sun Jan 26, 2025 7:17 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
cdussault wrote:
Installed the Mobelwagen Interceptors today...really like the fit. Running Geolander 215 60r16. They were a bit wonky to balance...
these are friggen cool Cool
1967 Bug:
Olga: the Cal look car lost in the PNW SOLD Sad
1984 Vanagon:
Berty the Vanagon
1973 Bus
Amber the Bus Sold
INSTAGRAM @jwebber95
S4VAGE
S4VAGE is offline
PostPosted: Sun Feb 16, 2025 10:00 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
rumor is that these can fit Shocked ... https://t3technique.com/collections/wheels
Laughing
Great look!
Edgy01
Edgy01 is offline
PostPosted: Mon Mar 17, 2025 8:59 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
I’ve been running Ronal R9s since I first saw them used by Project Zwo in Europe. They work great. Good clearances etc. I have two sets…one for streets and the others snow.
Jammasterjay
Jammasterjay is offline
PostPosted: Wed Mar 19, 2025 9:55 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
After lurking wheel fitment posts for months, I decided to try the Maxilite wheels and KO2’s. I would have liked 15” wheels for the sidewall profile, and I liked the old 14” KO2’s more square profile. The slider is .5-.75 clearance. Balancing was a little heavy because I didn’t want outer face weights.
campism
campism is offline
PostPosted: Tue Mar 25, 2025 4:26 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Not mine, set of five Mercedes wheels (NOT CLK) and four tires, with spacers but no lugs. $500.
http://www.facebook.com/marketplace/item/662014733124483
Page 175 of 176
