Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2599 Location: UK (South)
Posted: Fri Aug 20, 2021 10:10 am Post subject: Re: VW Bus air cleaners |
| Eric&Barb wrote: |
Not enough room for that.
How so? I'm using a 1500 air cleaner on the metal elbow. Mine is on a 1600 dual-port engine. It all fits, even though the 1600 fan shroud has the fresh air outlets.
The air cleaner touches the fresh air outlets, but it fits. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
EVfun  Samba Member
Posted: Fri Aug 20, 2021 2:26 pm Post subject: Re: VW Bus air cleaners |
| Who.Me? wrote: |
| Eric&Barb wrote: |
The air cleaner touches the fresh air outlets, but it fits. |
Is this picture of yours an early 1500 Bus air filter on a 40 horse Bus fixed tube from the carb?
If so this looks like it may work for me. I have a beach buggy with almost no room above the top of the fan shroud, making a good air cleaner solution difficult. Since I have a 36 horse style fan shroud on the engine even that slight contact you show wouldn't happen. _________________
| Wildthings wrote: |
| As a general rule, cheap parts are the most expensive parts you can buy. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26279 Location: Olympia Wash Rinse & Repeat
Posted: Fri Aug 20, 2021 5:00 pm Post subject: Re: VW Bus air cleaners |
| Who.Me? wrote: |
Exactly, touching means rubbing a hole thru the air cleaner. _________________ In Stereo, Where Available! |
blacka1vw Samba Member
Joined: September 11, 2013 Posts: 100 Location: N. Central PA
Posted: Sun Oct 31, 2021 7:51 am Post subject: Re: VW Bus air cleaners |
| rjelli wrote: |
Just found this NOS mount - I hope it's for my dusty oil bath filter. Could not find any information based on the part number: 261 613 503. Think it's for welding in. Anyone seen this before?
Your bracket looks very similar to a bracket I got on a bay window bus that has spent much of its life in South America. It has the dusty conditions air cleaner with the part number ending in 612e 71 date stamp. My bracket is the same shape at the bottom and longer at the top with an additional angle in it. I may use this oil bath in my s/c. I could possibly make a shorter bracket like yours. I’ll take some measurements.
_________________ 64 SC truck.
71 Beetle -Skyy
71 Super -Sweet pea
73 Bus
79 Bus -Tic Tak
86 Cabriolet |
Posted: Sun Oct 31, 2021 8:04 am Post subject: Re: VW Bus air cleaners |
But both of those brackets are different from the split bus one shown on page one. Maybe they are both bay window parts. _________________ 64 SC truck.
71 Beetle -Skyy
71 Super -Sweet pea
73 Bus
79 Bus -Tic Tak
86 Cabriolet |
Chewie Baker Samba Member
Joined: April 10, 2005 Posts: 102 Location: West Midlands, England
Posted: Mon Dec 11, 2023 2:14 pm Post subject: Re: VW Bus air cleaners |
Looking to buy an original air cleaner for my ‘67 bus… can anyone out there help please? _________________ '67 S042 - BETTER THAN BEING MARRIED! |
Posted: Mon Dec 11, 2023 2:49 pm Post subject: Re: VW Bus air cleaners |
| Chewie Baker wrote: |
| Looking to buy an original air cleaner for my ‘67 bus… can anyone out there help please? |
Do a search in the classifieds. Putting up a WTB advert in the forums is against the rules.
If no luck in the classifieds doing a search, put up a "WTB" titled advert. _________________ In Stereo, Where Available! |
EVfun  Samba Member
Posted: Mon Dec 11, 2023 3:39 pm Post subject: Re: VW Bus air cleaners |
This popped back up on my “unread” list and I see I never never provided an installed picture. I found the Bus 40 horse elbow here in theSamba classifieds. This is a good shot showing the fit.
With an aftermarket 36 horse style fan shroud I’d guess a stock oil bath would fit, and the filter I installed would clear a stock fan shroud. I used a K&N RG-1003RD-L air filter and an Outerwears 20-1570 filter cover. In this picture the homemade support bracket off the coil mount was installed backwards so the pipe is slightly angled down. The bracket is very close to, but not quite, symmetrical. I’ve since painted it black and flipped it over. _________________
| Wildthings wrote: |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53190 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Dec 11, 2023 11:57 pm Post subject: Re: VW Bus air cleaners |
thanks for replies and apologies for not knowing the forum rules _________________ '67 S042 - BETTER THAN BEING MARRIED! |
Posted: Tue Dec 12, 2023 10:33 am Post subject: Re: VW Bus air cleaners |
| thanks for replies and apologies for not knowing the forum rules |
No worries, we all step in dog doodoo now and then.
Go up to the top of any TS webpage and hover your mouse cursor over the "Classifieds" button there. In the pop up list that pops up left click on the "Rules" there. That will take you to the rules. Good to refresh oneself now and then.
Lots of other very cool need to know VW stuff through those buttons. _________________ In Stereo, Where Available! |
von_hansel  Samba Member
Joined: June 12, 2006 Posts: 846 Location: Inland Empire
Posted: Tue Jul 16, 2024 2:07 pm Post subject: Re: VW Bus air cleaners |
I recently purchased a Dusty Condition Air Cleaner (Mcode 156) for a 1500. When I went to install it, I kept scratching my head because the bracket was 10mm short of where it should fit on a passenger bus.
Then it dawned on me that it was made for a Truck (Single and/ or Double Cabs) as the bed rails sit lower in the engine bay on trucks.
Below is some comparison photos. On the left is the passenger/ non truck commercial bracket and right is the Truck bracket
Non Truck Bracket = 40cm
Truck Bracket = 29.3cm
I hope this helps someone else down the road. _________________
| Mugatu wrote: |
| von_hansel is still so hot right now |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3505 Location: Anderson SC
Posted: Wed Jul 17, 2024 4:00 am Post subject: Re: VW Bus air cleaners |
great information - thanks for sharing _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Wed Jul 17, 2024 8:16 am Post subject: Re: VW Bus air cleaners |
| von_hansel wrote: |
I hope this helps someone else down the road. |
Great info, but bracket would be turned around so the bottom is flat to the wheel well. _________________ In Stereo, Where Available! |
Stocknazi Samba Member
Posted: Tue Mar 04, 2025 8:28 am Post subject: Re: VW Bus air cleaners |
Was there a "squeeze type" clamp used on the pre-heat hose for 40hp or 64-67 style air cleaners?
Here is what WW has:
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113255737
Same size as a Type 4 engine oil filler clamp? _________________ WANTED:
Thomas Jefferson |
Posted: Tue Mar 04, 2025 10:33 am Post subject: Re: VW Bus air cleaners |
Correct. Have no idea about the type 4 filler size.
Here shown on a 22 mile original 1964 VW beetle.
Takes a special pair of pliers (Swivel Jaw Wire Clamp Plier) to work that clamp without hassles.
https://duckduckgo.com/?t=lm&q=pliers+for+wire...252C5074.1 _________________ In Stereo, Where Available! |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15456 Location: Casa de Oro, California
Posted: Tue Mar 04, 2025 6:48 pm Post subject: Re: VW Bus air cleaners |
| Eric&Barb wrote: |
| Here shown on a 22 mile original 1964 VW beetle. |
Stupendous. What is the red mark at the air cleaner tube clamp? |
Joined: April 27, 2002 Posts: 6854 Location: Pentwater, Michigan
Posted: Tue Mar 04, 2025 7:14 pm Post subject: Re: VW Bus air cleaners |
A light reflection on the shiny new paint? _________________ Roads Scholar
Member# 2059 |
| BarryL wrote: |
| Eric&Barb wrote: |
Have no idea. Lots more great info and tons more images in this thread here: https://www.thesamba.com/vw/forum/viewtopic.php?t=657206
Even though that is a beetle engine it would have been just the same as the 1964 40 HP bus engine and very close to the 1961-63 40HP and 1500 bus engines. With the exceptions of the beetle air cleaner, muffler, and a little different jetting in the carb.
So neat to see the spark plug cable colors that only show up as grey in the B&W owners manuals of that time. Plus the white (nylon?) holders for the spark plug cables, that are now only sold in a black plastic. _________________ In Stereo, Where Available! |
Posted: Mon Sep 22, 2025 8:22 pm Post subject: Re: VW Bus air cleaners |
Found an NOS 1963 thru early 1964 air cleaner in the classifieds here:
https://www.thesamba.com/vw/classifieds/detail.php?id=2685486
Big thing about this is it shows the water decal that is always missing today.
Figure best to let EverettB insert the images he thinks will work on page 1. _________________ In Stereo, Where Available! |
