Fuel Gauge Accuracy
Max Welton
Max Welton is offline
PostPosted: Wed Apr 23, 2025 3:41 pm    Post subject: Fuel Gauge Accuracy Reply with quote
Having solved some of the more serious problems, I'm dealing with some small stuff.
My fuel gauge is inaccurate. Today I gassed up when the needle was half way between R and 1/4 and it only took 5 gallons.
This is what it reads when full (minus a 20 mile ride home).
I'm used to going by miles traveled since my MPG is known as ~25. But I would like to make the gauge more accurate. Any Ideas?
1967(ish) type-3 Fastback.
Max
1967 Type-3 Fastback
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Apr 23, 2025 3:48 pm    Post subject: Re: Fuel Gauge Accuracy Reply with quote
Start with grounds.
The stock gauge grounding is via the two spring arms that hold it in the pod, and this is not reliable. Consider running an additional (try to use brown) ground wire from the gauge body to the behind-dash ground tabs.
Next ground fault is the sender, which grounds through a mounting screw, and through the tank to the mounting tabs, also unreliable. Add an eyelet lug under one of the sender mounting screws and run the wire to a nearby body ground.
And tighten the female connectors (maybe replace them with a new, factory-style double crimp connector, or at least a properly-soldered one). Add heat shrink to protect them from shorts.
You can check for ground faults with a grounded temporary jumper wire, and see if that moves the needle.
Last resort is a new sender, but some of these are junk, too.
Gauges seem pretty bulletproof.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Max Welton
PostPosted: Wed Apr 23, 2025 4:32 pm    Post subject: Re: Fuel Gauge Accuracy Reply with quote
I've never liked the idea of relying on clips and stuff for grounding. So as I've been reassembling the car, everything has gotten an actual ground wire. That's gauge pods, brake/turn/parking lights ... and the sender on the fuel tank.
Now, the sender is actually a variable resistor, right? Does more resistance mean a fuller tank or more empty?
Max
sctbrd
sctbrd is offline
PostPosted: Wed Apr 23, 2025 9:46 pm    Post subject: Re: Fuel Gauge Accuracy Reply with quote
About 90 ohms empty and 0 ohms full. The float reduces the resistance of the wire in the float- as it rises, so less resistance as you fill it.
https://www.thesamba.com/vw/forum/viewtopic.php?p=8792057
gt1953
gt1953 is offline
PostPosted: Thu Apr 24, 2025 6:58 pm    Post subject: Re: Fuel Gauge Accuracy Reply with quote
My fuel gauge reads full for some time then starts to drop. I did remove the sending unit when i got the vehicle, it sat for ten yrs. If you do remove the sending unit be careful up dissassembly. The wire are fragile. Agree with the gounding of the sendng unit. I spent a lot of tme repairing every ground connection i could find. I used a star washer on the ones I was able to locate. No electrical issues.
72 type 1
72 Squareback
Max Welton
PostPosted: Thu Apr 24, 2025 8:28 pm    Post subject: Re: Fuel Gauge Accuracy Reply with quote
The grounds on this car are as good as I could make them. Wiring harness is new.
I suppose I could try another sender and see if I get lucky. I'll test mine with an ohm-meter first.
Max
Zwitterkafer
Zwitterkafer is offline
PostPosted: Fri Apr 25, 2025 10:46 am    Post subject: Re: Fuel Gauge Accuracy Reply with quote
Grounds are crucial of course. But when grounding is poor, the readings tend to be erratic, before the eventual total failure. If your Full reading is consistently low but at the same spot, it could be that the float itself is sticking. If all else fails, remove the sender and turn it end for end a number of times, listening to the float as it slides along the resistor wires, and hits a stop at either end with a small clunk. If that does not happen, carefully open to inspect and find out why.
- Zeuxius, 400 BC
Bobnotch
Bobnotch is offline
PostPosted: Fri Apr 25, 2025 12:48 pm    Post subject: Re: Fuel Gauge Accuracy Reply with quote
Max
It might be worth contacting Jim Adney and having him rebuilt your sending unit. Yes, he does them too.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
gt1953
gt1953 is offline
PostPosted: Fri Apr 25, 2025 8:47 pm    Post subject: Re: Fuel Gauge Accuracy Reply with quote
Jim Adney rebuilt my speedometer, works great as does the trip meter. I wuld recomend him.
72 type 1
72 Squareback
Max Welton
PostPosted: Sun Apr 27, 2025 5:00 pm    Post subject: Re: Fuel Gauge Accuracy Reply with quote
So my sender measures ~85 ohms to 4.5 ohms. Close. Connecting the sender wire to ground (0 ohms) makes the gauge read "full".
Sending it to Jim Adney would take the out car of service unless I get another one to use in the meantime.
What I may do is buy a new sender and see if it measures any different. If I care enough, I can send one of the senders to Jim to see if he can bring it into spec.
This is also something I can live with. At 25 MPG, my range is ~260 miles. I've lost a small amount of capacity to an internal fuel pump, but not much.
Max
sctbrd
sctbrd is offline
PostPosted: Tue Jun 17, 2025 12:39 am    Post subject: Re: Fuel Gauge Accuracy Reply with quote
Nearly everywhere on fuel tank level info, resistance of the sender is the most talked about value. Makes sense, but...
Question about voltage coming out of the gauge to the sender:
What should the voltage read coming OUT of the gauge (to the sender)?
With 6 volts at the inlet of the gauge, I get 2.3 volts out to the sender.
With the gauge reading 1/4 tank, but I have about 1/2 tank in it (checked with sender out). Havent been able to fill it up all the way yet to check readings at FULL- Ill probably take the sender out and check its operation in a container.
Operation of the systems seems straight forward, especially after reading a bus thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=627043
The gauge itself has 63 ohm resistance across the G and + terminals, and 23 ohms across a coil of wire at one side of the gauge.
So, with that I would NOT expect 6 vdc at the sender connection.
With my 60 year old original wiring, would it be necessary to add a resistance in the circuit to calibrate the gauge to read correctly?
(yes, new wire would be best Wink )
Or am I missing something?
Additional interesting info- found that the gauge itself will go to FULL with a 1.2 vdc battery connected across it, when it is removed.
mdege
mdege is offline
PostPosted: Tue Jun 17, 2025 6:08 am    Post subject: Re: Fuel Gauge Accuracy Reply with quote
This is the theory behind the gas gauge:
https://en.wikipedia.org/wiki/Wheatstone_bridge
measuring the Voltage across the sender does not mean much if you don't know the resistances of the other three resistors.
The good thing about this circuit is, that the supply voltage does not really matter. The instrument shows the difference between two voltage dividers which both are supplied by the same source. This also shows why good grounds are essential for the system to work right. Both grounds should have the same potential (voltage level). and that will only happen if you have clean grounds.
- Michael
1963 Typ3 Notchback project
1988 Multivan Magnum 112i
sctbrd
sctbrd is offline
PostPosted: Tue Jun 17, 2025 9:10 am    Post subject: Re: Fuel Gauge Accuracy Reply with quote
Wheatstone bridge, that is buried in the back dust of my brain... Smile
It's been a long time, 1988 Navy Electrician's school. Makes sense. Thanks.
I also came across this today, and with my actual readings and the voltage drops, it looks like my gauge is working fine.
I may still add a resistor to fine-tune the pointer.
Bobnotch
Bobnotch is offline
PostPosted: Tue Jun 17, 2025 12:29 pm    Post subject: Re: Fuel Gauge Accuracy Reply with quote
Max
Keep in mind you only have a 10 gallon fuel tank. Since you have pump in it, you've lost a little bit of that capacity. I don't know how much space you've lost, but it might be a quart, or a 1/2 gallon. Just something to keep in mind. And that 5 gallons you put in should be closer to a half tank.
edit: You might want to carry a 2 gallon can with you, and run the fuel out of the tank, so you know where empty is. Then put that in, and see what the level on the gauge moves to, so you can drive home on the 2 gallons, or stop and get more gas to top up the tank.
Tram wrote:
Tram wrote:
Bobnotch
Bobnotch is offline
PostPosted: Tue Jun 17, 2025 12:38 pm    Post subject: Re: Fuel Gauge Accuracy Reply with quote
Something else to keep in mind, your gauge might not be reading the bottom end correctly, but the top end is right. I've ran into that on other cars, where the top of the gauge goes further than the bottom (it drops quickly from half tank), but takes forever to get to half tank. Some cars are different too, and work the opposite way, meaning the top burns off quickly.
Tram wrote:
Tram wrote:
Max Welton
PostPosted: Tue Jun 17, 2025 1:01 pm    Post subject: Re: Fuel Gauge Accuracy Reply with quote
Thanks Bob. I do carry a 1 gallon gas can and am using a hydramat pickup which is really good at scavenging that last little bit of fuel. When the weather cooperates (thunder bumpers today), I'll run the tank dry and know for sure what my range is. As long as I'm within 25 miles of a gas station (one gallon), I'm good.
This vid may give an idea of how much capacity I'm giving up.
Max
Bobnotch
Bobnotch is offline
PostPosted: Wed Jun 18, 2025 2:36 pm    Post subject: Re: Fuel Gauge Accuracy Reply with quote
Max
That's a huge pump screen/filter in that tank. It looks like you might be giving up and quart and a pint of fuel displacement between the pump and the filter. And with only having 10 gallons of fuel in the tank, you're now working off of 9.75 gallons and change. So your 250 miles per tank will drop off, unless your mpg gets better.
Tram wrote:
Tram wrote:
Max Welton
PostPosted: Wed Jun 18, 2025 3:43 pm    Post subject: Re: Fuel Gauge Accuracy Reply with quote
I guess we'll see. The mat is very light dry and winds up saturated with fuel so it isn't really displacing its entire volume. I took it out to change the mount a couple weeks ago and was surprised at the weight difference dry vs wet.
Btw, I replaced the gauge illumination bulbs with leds. I can see now. Maybe a little too white though.
So far I only have 535 miles in my log with an average of 26.99 mpg. Mixed driving including a trip to Boulder last week and one up to Littleton before that. Current tank has 192 miles and still a fair bit to go. I had the needle substantially lower than as shown and it only took 7.067 gallons.
Max
Max Welton
PostPosted: Wed Jun 18, 2025 3:59 pm    Post subject: Re: Fuel Gauge Accuracy Reply with quote
Something else I might try is getting the sender to sit lower in the tank. I could make a new gasket out of a sheet of thin nitrile. It seems to off more than that would change but who knows.
Max
Bobnotch
Bobnotch is offline
PostPosted: Thu Jun 19, 2025 2:51 pm    Post subject: Re: Fuel Gauge Accuracy Reply with quote
Max
It might work. It's hard to say unless you try it. If you're averaging 27 in mixed driving, you're not doing too bad considering your elevation changes. I think my Solexs were doing 26 in strictly freeway running, and 27 in mixed city-country cruising. My Webers were about 1mpg less. At least you have a baseline for your injection, so now you need to run the tank empty from full, then you can get a miles per tank reading. Keep in mind that when I'm doing a cruise on the freeway (like going to an Invasion) I'll run about 200 miles, then fill up. I do that at about 1/4 tank, since I don't know where the next fuel stop will be. Also, we'll run in a group, and whoever is getting the less distance between stops is the one calling for a fuel stop. Quite often it was Dave in our group calling for a stop. When John J and I were running together, we were both getting close to the same distance on a tank, so we'd stop when we needed to. Of course we were both hitting it hard @75+ mph, as that's what we were used to running along. I hope this helps.
Tram wrote:
Tram wrote:
