Vintage Speed Information on The Samba
John Moxon Premium Member
John Moxon is offline
PostPosted: Tue Oct 21, 2008 10:44 am    Post subject: Vintage Speed Information on The Samba Reply with quote
Gerhard Oettinger - the story of the man who created Okrasa
1954 Road & Track Test - Fischer/Amal Twin Carbs
1955 Autosport Denzel article
1955 Road & Track Test. - MAG Supercharger on Beetle Pg 1
1955 Road & Track Test. - MAG Supercharger on Beetle Pg 2
1956 Sports Car Illustrated Article - Vitality for the VW
1957 Road & Track Test. - Okrasa Kit on Ghia Pg 1
1957 Road & Track Test. - Okrasa Kit on Ghia Pg 2
1957 Autocar Test - MAG Supercharger on Ghia – Pg 1
1957 Autocar Test - MAG Supercharger on Ghia – Pg 2
1957 Autocar Test - MAG Supercharger on Ghia – Pg 3
1957 Hot Rod Magazine, April 1957 - Page 1
1957 Hot Rod Magazine, April 1957 - Page 2
1957 Hot Rod Magazine, April 1957 - Page 3
1957 Hot Rod Magazine, April 1957 - Page 4
1957 Hot Rod Magazine, April 1957 - Page 5
1957 Hot Rod Magazine, April 1957 - Page 6
1957 Road & Track Test - Judson Supercharger Pg 1
1957 Road & Track Test - Judson Supercharger Pg 2
1958 Sports Car Illustrated Magazine - Denzel 1300 Pg 1
1958 Sports Car Illustrated Magazine - Denzel 1300 Pg 2
1958 Sports Car Illustrated Magazine - Denzel 1300 Pg 3
1958 Sports Car Illustrated Magazine - Denzel 1300 Pg 4
1958 Sports Car Illustrated Magazine - Denzel 1300 Pg 5
1958 EMPI Catalogue
1959 Car Craft Weber Cranks
June 1960 Hot Rod Denzel Article
1961 Okrasa High Torque Power Kit Pamphlet
1961 Sports Car Graphic Magazine - Okrasa article Pg 1
1961 Sports Car Graphic Magazine - Okrasa article Pg 2
1961 Sports Car Graphic Magazine - Okrasa article Pg 3
Okrasa Brochure - German
1962 Road & Track Test - EMPI Modified Beetle Pg 1
1962 Road & Track Test - EMPI Modified Beetle Pg 2
1962 Road & Track Test - EMPI Modified Beetle Pg 3
1962 Road & Track Test - EMPI Modified Beetle Pg 4
1964 Autocar Test - Shorrock Supercharger Pg 1
1964 Autocar Test - Shorrock Supercharger Pg 2
1965 Speedwell Catalogue
1966 Road & Track Feature - EMPI Inch Pincher Pg 1
1966 Road & Track Feature - EMPI Inch Pincher Pg 2
1966 Car Life Article - Teasing & Tuning the VW
1967 Road & Track Feature - EMPI GTV
1969 Popular Hot Rodding Article - More Power for VW's!
How to Install Fram external Oil
John.
PostPosted: Tue Nov 04, 2008 9:44 am    Post subject: Reply with quote
More 36hp Data supplied by Burly Burlile...thanks Burly.
There are some gaps that Burly would like filled so if you think you can add to the charts below just add them to this "Sticky" and it will be consolidated into the charts as and when.
John.
oval56
oval56 is offline
PostPosted: Fri Nov 07, 2008 5:02 am    Post subject: Reply with quote
so to complete the list a bit, here my datas:
- 36hp engine 1433ccm
- 78,5mm (third oversize) pistons kolbenschmidt/ machined
- 74mm porsche 356 crank
- 356 rods (poished, custom bushings for 20mm bolt)
- flywheel porsche 356 8 dowel 4,25kg after machining
- cam aircooled research stage II bolt on gear
- valfes 36/28mm
- carbs 34PCI dual (venturi 26mm, 138,5/180)
- manifolds riechert welded and ported
- heads 36hp, some porting and welding
- compressionratio 8,8:1
- spacers 11mm
- headvolume 39cc / ball shaped
- exhaust stock, TDE pipes
- ignition Bosch BR25
Datas:
- corrected din power engine 70PS (nearly same as HP), @ 4223
- 50ps on wheels
- torque 126Nm @3282 upm
www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com
t3kg
t3kg is offline
PostPosted: Sun Nov 16, 2008 4:03 pm    Post subject: Reply with quote
Some early EMPI stuff:
1958 EMPI brochure
1960 Camber Compensator flyer
1961 X300 Stroker Kit
I WAS THERE! The 2017 Type 3 Rally / September 29–October 1 / Cayucos, CA
2014: The 2014 Type 3 Rally / October 3–5 / Cayucos, CA
2011: 50 Years of the VW Type 3 / September 29–October 1 / California Central Coast
J
J is offline
PostPosted: Sat Dec 06, 2008 11:12 am    Post subject: Reply with quote
1192cc (64x77) pepco supercharged (28 pci) comp: 6.6-1
Hp: 59,8 hp (rear wheels)
Torque: 93 nm
PostPosted: Tue Dec 09, 2008 7:34 am    Post subject: Technical Data Comparisons Reply with quote
Here are some useful Technical Data Comparisons, taken from period tuning book "Souping The Volkswagen" by Dick Morgan.
John.
PostPosted: Thu Nov 19, 2009 4:18 am    Post subject: Carburettor Airflow Comparisons for the VW. Reply with quote
Tom Bruch as kindly tested, recorded and compiled this Airflow Comparison Chart for most of the commonly used carburettors for the VW.
If you wish to ask questions or pass comment on this information please use this related topic: http://www.thesamba.com/vw/forum/viewtopic.php?t=387316
John.
TomSimon
TomSimon is offline
PostPosted: Thu Feb 25, 2010 10:56 am    Post subject: Reply with quote
Did any of you guys see the vintage film (converted to digital by Aussie Dubbers) of Dick Bieth back in 1961 at Bonneville with his 36hp powered Beetle LSR (complete with bicycle chain-driver Pepco roots blower on top)?
It's great classic stuff, email Burly for a digital copy...
PostPosted: Thu Feb 25, 2010 11:26 am    Post subject: Reply with quote
Hi Tom, Yes Burly has sent a copy and "wiggy" is converting it for inclusion in "The History of Vintage Speed" sticky here. Smile
BTW if you want to add any of your experiences to the history topic...short and concise or long and rambling, you'd be most welcome. Wink
John.
Boonies
Boonies is offline
PostPosted: Mon May 24, 2010 11:58 am    Post subject: Reply with quote
Modern Motor April 1958-- Okrasa review PG 1
Modern Motor April 1958-- Okrasa review PG 2
Modern Motor July 1957: Volkswagen "special" test PG 1
Modern Motor July 1957: Volkswagen "special" test PG 2
Modern Motor July 1957: Volkswagen "special" test PG 3
Modern Motor July 1957: Volkswagen "special" test PG 4
The Old Speed Shack
swanlakers
swanlakers is offline
PostPosted: Mon Feb 17, 2020 12:18 pm    Post subject: Re: Vintage Speed Information on The Samba Reply with quote
https://www.thesamba.com/vw/archives/manuals/55denzel.php
https://www.thesamba.com/vw/archives/lit/6_60_hot_rod/Hot_Rod_June_1960_VW_Article%20Denzel.pdf
https://www.thesamba.com/vw/archives/lit/8_59_car_...Cranks.pdf
https://www.thesamba.com/vw/archives/lit/56ghia/cover.jpg
Trylon
Trylon is offline
PostPosted: Tue Jul 28, 2020 4:05 am    Post subject: Re: Vintage Speed Information on The Samba Reply with quote
Okrasa
https://www.thesamba.com/vw/gallery/pix/2069280.jpg
https://www.thesamba.com/vw/gallery/pix/2069279.jpg
https://www.thesamba.com/vw/gallery/pix/2069278.jpg
https://www.thesamba.com/vw/gallery/pix/2069276.jpg
https://www.thesamba.com/vw/gallery/pix/2069275.jpg
https://www.thesamba.com/vw/gallery/pix/2069274.jpg
1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel!
