Front Engine Tin?
builtbychevy
builtbychevy is offline
PostPosted: Sun Jan 20, 2013 8:13 pm    Post subject: Front Engine Tin? Reply with quote
Do we need to use the Front Engine Tin? I think it is useless.
Josh Smith
Dirty Racing & Rods
My Store: www.dirtyracingandrods.com
My Blog: http://blog.dirtyracingandrods.com/dirty-racing-rods-the-paradise/the-vw-squareback-progress/
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Sun Jan 20, 2013 8:36 pm    Post subject: Re: Front Engine Tin? Reply with quote
wow - three posts and you already know more than the Wolfsburg engineers... is there anything the Samba can't do?
póg mo thóin
Certified DHS Technician
Samba Member # 24517
Brent
Brent is offline
PostPosted: Sun Jan 20, 2013 9:00 pm    Post subject: Re: Front Engine Tin? Reply with quote
Everyone knows the front tin is useless on a Chevy.
69 Fastback Build
Berg5 Build
wj32796
wj32796 is offline
PostPosted: Sun Jan 20, 2013 9:10 pm    Post subject: Re: Front Engine Tin? Reply with quote
Why do you think its useless?
builtbychevy
PostPosted: Sun Jan 20, 2013 11:06 pm    Post subject: Re: Front Engine Tin? Reply with quote
Other than aesthetics. It is functionally useless in my opinion. I think it restricting the volume of fresh cool air available to my DCNF carburetors. You know for every 10 degrees you reduce the temperature of the intake air you gain 1 hp. and its true than 100 degrees F. are worth 10 Horsepower.
I reckon I just might test this squareback carb temps with an ir meter both with and with out that there front tin.
Josh Smith
Dirty Racing & Rods
Tram
Samba Socialist
Tram is offline
PostPosted: Mon Jan 21, 2013 12:08 am    Post subject: Re: Front Engine Tin? Reply with quote
You do know there's a cold air intake for carbs built right into the body... right?
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
wj32796
wj32796 is offline
PostPosted: Mon Jan 21, 2013 12:40 am    Post subject: Re: Front Engine Tin? Reply with quote
So are you going to "ir" the carb temps or the air going into the carbs? Im a little confused as to what your going to read the temperature off of.
Why don't you tell us a little about your motor. How fast have you had it and how much faster do you think it will go with you removing the tin that is there for looks? Pictures?
notchboy
notchboy is offline
PostPosted: Mon Jan 21, 2013 1:05 am    Post subject: Reply with quote
That tin keeps the road monkeys and the trans-gremlins out Rolling Eyes
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Max Welton
Max Welton is offline
PostPosted: Mon Jan 21, 2013 6:31 am    Post subject: Reply with quote
It holds onto my throttle-cable guide tube.
Max
1967 Type-3 Fastback
notchback
Insensitive Jerk
notchback is offline
PostPosted: Mon Jan 21, 2013 10:25 am    Post subject: Reply with quote
Just baja your type3 and you won't have to worry about it.
zeen wrote:
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point.
FU#3
PostPosted: Mon Jan 21, 2013 12:50 pm    Post subject: Re: Front Engine Tin? Reply with quote
I don't know about that... it may be preventing heat from the heater boxes from getting into the engine compartment in your non-stock situation.
1hp gain for every 10 degrees story:
This one time I was driving at the South Pole and it was -80F and my bone-stock 1500cc Squareback had almost 200hp. I had started to slip into a crevasse and was able to power out of it. Smile
Tram
Samba Socialist
Tram is offline
PostPosted: Mon Jan 21, 2013 1:22 pm    Post subject: Re: Front Engine Tin? Reply with quote
I'd say you'd increase power until your carby ices up...
Bryan67 wrote:
Those who can- do.
Bobnotch
Bobnotch is offline
PostPosted: Mon Jan 21, 2013 3:50 pm    Post subject: Re: Front Engine Tin? Reply with quote
Don't confuse him with facts Tram. Wink
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
builtbychevy
PostPosted: Tue Jan 22, 2013 6:02 pm    Post subject: Reply with quote
you guyses are silly. Sure in my signature there is a link to my webstore. In the top left there is also a link to my (Blog). In that (Blog) there is a link that says (Paradise) if you hoover over (Paradise) it says squareback progress.
Josh Smith
Dirty Racing & Rods
blankmange
Type 3 Darksider
PostPosted: Tue Jan 22, 2013 6:19 pm    Post subject: Reply with quote
builtbychevy wrote:
you guyses are silly. Sure in my signature there is a link to my webstore. In the top left there is also a link to my blog. In that blog there is a link that says (Paradise) if you hoover over (Paradise) it says squareback progress.
WTF does that have to do with your front engine tin?
póg mo thóin
builtbychevy
PostPosted: Tue Jan 22, 2013 6:24 pm    Post subject: Reply with quote
wj32796 asked for pictures.
Josh Smith
Dirty Racing & Rods
