dwill49965 Samba Member
Joined: August 08, 2005 Posts: 1404 Location: Dartmouth, Nova Scotia
Posted: Thu Oct 20, 2022 11:52 am Post subject: Re: Front Seat Swap (Town & Country 2nd Row) |
Yes, I have read all 29 pages of this thread over the last couple of weeks.
I am ready to do this seat swap in my '78 Westy - using leather seats from a 2014 Dodge Grand Caravan. One concern I just noticed as I was about to order the Small Car adapter bracket from their website is that it does NOT list the bracket as being compatible with a 1978 passenger side swivel seat - only up to 1976, and nothing about '77-79 passenger side swivel seat.
"Seats and Mounting Brackets Fit the Following Vehicles:
1980-1991 Vanagon
1968-1976 Bay Window Bus: Driver's Side
1977-1979 Bay Window Bus: Driver's Side
1968-1976 Bay Window Bus: Passenger's Side requires a custom bracket
1976 Bay Window Bus: Passenger Side with swivel"
So I am not sure if I should order two brackets, or just one for the drivers side. I also recall from somewhere earlier in the thread that it is easy to install the seat directly onto the swivel passenger side, and I believe the '78 swivel is similar if not identical to the 1980-91 vanagon. Can anyone confirm that?
Thanks in advance. _________________ Darryl
'78 Westy, Boston Bob built 2.0 L, FI, MSD 6A |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5843 Location: Wamego, Kansas, USA
Posted: Thu Oct 20, 2022 12:26 pm Post subject: Re: Front Seat Swap (Town & Country 2nd Row) |
I used a pair of adapters, one for each side in my '78 Westy.
But as I'm considering your comment, it may well be possible to bolt the seat straight down to the swivel. I honestly never considered that!
If you're interested, maybe I can look at that a bit more closely, and if it looks like it would work, I'd sell you my passenger side bracket for use on your driver side, and we can both just bolt the seat to the swivel! (Or if you want to try bolting yours down to the swivel, then we'll know and I could sell you my extra bracket.) _________________ Dave Cook
1973 Wild Westerner
My Thing |
pnwkayaker Samba Member
Joined: April 01, 2008 Posts: 977 Location: Sammamish, WA
Posted: Thu Oct 20, 2022 7:20 pm Post subject: Re: Front Seat Swap (Town & Country 2nd Row) |
dwill49965 wrote: |
One concern I just noticed as I was about to order the Small Car adapter bracket from their website is that it does NOT list the bracket as being compatible with a 1978 passenger side swivel seat - only up to 1976, and nothing about '77-79 passenger side swivel seat. |
I think the SmallCar folks are the best people to answer this question - I found that I would usually send them an email with a question about a product and I'd get an answer by the next morning.
It might be just a mistype in their description too. _________________ 87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link) |
Posted: Fri Oct 21, 2022 5:54 am Post subject: Re: Front Seat Swap (Town & Country 2nd Row) |
vwwestyman wrote: |
If you're interested, maybe I can look at that a bit more closely, and if it looks like it would work, I'd sell you my passenger side bracket for use on your driver side, and we can both just bolt the seat to the swivel! (Or if you want to try bolting yours down to the swivel, then we'll know and I could sell you my extra bracket.) |
Hi Dave - that's a great idea. I was mostly wondering if the bracket would fit, but it certainly sounds like yours did fit fine on your '78 passenger side swivel. I would be willing to buy your "extra" bracket for use on my vehicle. I will have to go back through this thread to make sure about bolting it to the swivel. I think someone said it gave them a little lower height doing it that way.
Since you've already installed your seats and bracket, and know what you are doing, if you could have a look and determine the feasibility of doing that, I would appreciate it. Thanks.
pnwkayaker - thanks for the suggestion, I will do that too. _________________ Darryl
Posted: Fri Oct 21, 2022 7:05 am Post subject: Re: Front Seat Swap (Town & Country 2nd Row) |
Yep, I will do my best to take a look soon. But if you can also take a look and see if it looks like you can bold your seat straight to the swivel, that would be helpful. (I'm in the midst of a lot of house projects in preparation to move!)
Then we can hit it both ways!
I would very much appreciate if I can get it to mount lower on that swivel, as would my wife!
The SNG seat frames have their own fore/aft adjustment as a part of the frame, so that isn't a concern with not using the adapter. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Wed Oct 26, 2022 3:45 pm Post subject: Re: Front Seat Swap (Town & Country 2nd Row) |
pnwkayaker wrote: |
It might be just a mistype in their description too. |
I took your suggestion and they got back to me later the same day. So it looks like I may not be able to easily/simply install the passenger side seat in my '78 (edit) using the SmallCar bracket.
Darryl,
I’ve triple checked with our T2 expert and he assures me that mounting to the passenger side of a ’78 Westy w/ a swivel base would require cutting and welding the bases to the area where the flip seat used to be. Feel free to reach out if you have any other questions. Thanks, and take care.
Kristopher
Sustainability and Product Manager
(253) 473-2474
smallcar.com _________________ Darryl
Posted: Wed Oct 26, 2022 6:04 pm Post subject: Re: Front Seat Swap (Town & Country 2nd Row) |
Here are two pics of my Smallcar adapter on my 1978 Westy seat swivel. It is even currently turned to face the back!
I would say their T2 expert is mistaken. The stock seats could be swapped from one side to the other; I don't know why they would think the adapters that fit one set of rails wouldn't fit the other.
Unless he is talking about the increased height? Otherwise, I dunno.
It appears I was mistaken in thinking you could very easily bolt the frame of the SNG to the swivel; you'd need to weld a couple cross braces to the swivel and mount to that. But it would lower the seat a bit. But possibly create other sources of frustration, such as the seat itself interfering with the swivel base.
1973 Wild Westerner
My Thing |
rustednuggs Samba Member
Joined: June 29, 2008 Posts: 511 Location: Summerdale
Posted: Sun Jan 08, 2023 2:36 pm Post subject: Re: Front Seat Swap (Town & Country 2nd Row) |
Greatest post and awesome pics! So I have an 80 air cooled vanagon, with swivel seats. I have been looking but what year Town and Country would be best for me to grab the 2nd row, stow and go? Is the Town and Country the only ones I can grab?
Thanks in advance! |
shagginwagon83 Samba Member
Posted: Sun Jan 08, 2023 3:36 pm Post subject: Re: Front Seat Swap (Town & Country 2nd Row) |
The ~2015 brown leather looks great with brown/tan interior. _________________ "Jo Ann" - '83.5 Westfalia EJ22e w/Peloquin |
Posted: Sun Jan 08, 2023 3:37 pm Post subject: Re: Front Seat Swap (Town & Country 2nd Row) |
I agree! I am looking for some as we speak! Located in Southern Alabama and will to drive a few..TY in advance! |
campism Samba Member
Joined: September 07, 2007 Posts: 4686 Location: Richmond VA
Posted: Sun Jan 08, 2023 4:28 pm Post subject: Re: Front Seat Swap (Town & Country 2nd Row) |
rustednuggs wrote: |
T&C gets all the press but the Dodge Grand Caravan is essentially the same vehicle, from the 2008 vehicles up to '15 for the T&C that became the Pacifica with a new body style in '16. I've heard those middle row seats are not as comfortable. The DGC carried on with the '08 body style for a few more years (until '18?) before it was dropped. Good luck! _________________ '87 Westy in Wolfram Grey Metallic, tragically crushed by a falling hickory tree in my own driveway and now gone, leaving me Vanagonless and with no plans to replace it, alas. |
gtinseth Samba Member
Joined: July 25, 2019 Posts: 77 Location: NW California
Posted: Wed Aug 23, 2023 7:36 pm Post subject: Re: Front Seat Swap (Town & Country 2nd Row) |
Just a quick note to confirm that the newer Pacifica seats work with the German sliders. It isn't plug and play. The seats I bought had no underseat mounting rails or crossbars. I looked at the smallcar instructions for the Pacifica seats with their slider mounts. I used their idea to bolt on angle iron on both edges to the two spots they highlight. Then I bolted on the German sliders to the angle iron.
Here are the German sliders:
https://www.vw-t3-bus-shop.de/sitzadapter-fur-sportscraft-armlehnensitz-s91s81
I used 2 inch by 2.5 inch by 3/16 inch angle iron and M10 bolts as described in the smallcar pdf. Driver side, for my install, must be moved back to the stops in order to "stow" and I installed the passenger side onto a swivel base with no problems.
I haven't put any time into driving with them yet, but will soon. Feel free to message for more details. I have been super swamped and haven't taken any photos. Sorry. I just wanted to say they are usable with a little fabrication. Or you could buy the smallcar slider system and bolt it on. |
bammbamm1961 Samba Member
Posted: Fri Dec 08, 2023 8:01 pm Post subject: Re: Front Seat Swap (Town & Country 2nd Row) |
Does ANYBODY have a set of post install photos showing the total install Hgt???
Here is an image of bmw X1x3 seats in my 82, but they are not a great option due to sitting so high.. Looking to see if these pacifica 2nd row seat are a better option.
4" between Steering wheel and seat top puts the head of my 6'2" tall body nearly into the headliner.[img][/img]
kamzcab86 Samba Moderator
DuncanS Samba Member
Posted: Sat Dec 09, 2023 5:52 am Post subject: Re: Front Seat Swap (Town & Country 2nd Row) |
The Bimmer seats look great. Why not carve the lower seat mount away and get rid of the height.
Duncan |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32989 Location: Reading Pennsylvania
