brionsab Samba Member
Joined: January 10, 2007 Posts: 2 Location: Springdale, UT
Posted: Sat Dec 29, 2012 7:19 pm Post subject: Adding heat using an after market exhaust sytem. |
I recently installed an after market exhaust system on a 1969 Squareback. I wanted to retain interior heat and installed stock heat exchangers. I installed the metal and paper fiber smaller fresh air tubes.
The question was how to supply the fresh air to these tubes. I was warned that operating the heat without supplying the secondary fresh air would pop the thermostats in the Warm air mixers that are attached to the body. That would result in extremely hot air being expelled into the interior.
The stock exhaust system/muffler utilizes an extra small heat exchanger that is located directly above the muffler. This supports the large metal elbows that provide the fresh air to both the small fresh air tubes and the main under car heat exchangers.
Materials used:
Original Elbows
1" PVC pipe couplings (2)
1 1/2" Rubber pipe coupling (1)
3/8" long #8 sheet metal screws (4)
2" heater hose from fan shroud flexible aluminum (2)
Hose clamps (eight)
1 1/8" Forstner Bit
Step 1 - Secure the 1" PVC coupling on a drill press. Open up the inside to 1 1/8" by drilling through the center with the forstner bit. Drill at a slow speed and proceed slowly to avoid overheating the bit and melting the pvc coupling. Enlarge the opening in both couplings.
Step 2 - Cut the 1 1/2" rubber pipe coupling exactly in half. This result in two rubber couplings the correct length for both sides.
Step 3 - Slip the now 1 1/8" pvc coupling onto the nipple of the right side elbow. The left side coupling onto the metal fresh air tube.
Step 4 - Install each 1 1/2" rubber coupling half onto the fresh air outlet of the fan housing. Be sure the rubber is warm and flexible as it has to be coaxed on as it is slightly too small for the application.
Step 5 - Slip each large metal elbow onto the just installed rubber coupling, left side and right side. Make sure to line up the smaller outlet nipples so they align with the metal fresh air tubes. Clamp both ends of the large rubber coupling securely.
Step 6 - Slide the smaller 1 1/8 " pvc coupling so that it connects the metal nipple from the large elbow to the metal fresh air tube on each side. Secure each end with a sheet metal screw. I drilled pilot holes before attaching the screws.
Step 7 - Install the 2" aluminum hose from the end of each elbow to the main under engine heat exchangers. It is easier to clamp them to the Heat Exchangers first, then cut them to length and clamp them to the large metal elbows.
The result is a sturdy installation that operates the heating system as VW intended. It is also completely reversible, does not render any of the used parts unusable, allowing them to be utilized with a stock exhaust system in the future.
This is the completed left side.
The right side.
Close up of the Rubber coupling.
Right side pvc coupling.
Left side coupling.[/code] |
Brent Samba Member
Joined: April 28, 2010 Posts: 1622 Location: San Tan Valley, AZ
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23579 Location: Kimball, Mi
Posted: Sun Dec 30, 2012 10:20 am Post subject: |
Just keep an eye on the aluminum tubing, as it gets fragile when it ages. It also likes to tear and or wear easily, and also fall off the heat exchanger end. Keep in mind you won't get the full heat that a stock muffler set up will give, since you're only using the large heat exchangers. Looks like a decent set up though. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
dailyt3 Samba Member
Joined: May 07, 2010 Posts: 208 Location: North Louisiana
Posted: Sun Dec 30, 2012 10:34 am Post subject: |
what other option is there to use other then the aluminum hose ??????? _________________ 1973 Squareback Stock F.I - Hazel
2005- 2012 Sitting in dirt lot in Compton Ca.
Purchased Aug-2012
Revived and on the road March 1, 2013 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18052 Location: Eugene, OR
Posted: Sun Dec 30, 2012 11:40 am Post subject: |
Ducting from Aircraft Spruce rated up to 530 degrees.
_________________ 69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sun Dec 30, 2012 1:04 pm Post subject: |
| About a month once it warms up in the desert, I will come up with a more permanent hose. Will get some flexible metal exhaust or fresh air hose. Stainless seems to an item I can order. Maybe 1 1/2" and expand the ends to fit or 2" with crimped down ends. I will post an update. |
chaosisme Samba Member
Joined: August 29, 2005 Posts: 1164 Location: Orange County, Ca
Posted: Sun Dec 30, 2012 8:31 pm Post subject: |
| Mike Fisher wrote: |
Hey Mike, is it this stuff?
http://www.aircraftspruce.com/pages/ep/ducting/sceet.php
What diameter should be used? _________________ '65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's |
Posted: Sun Dec 30, 2012 9:28 pm Post subject: |
That does look like the stuff, but someone else said to be sure to order the best grade Aircraft Spruce sells which is SCEET? I think it was the 2.25" I ordered, but take some measurements yourself. That is an 18" long piece in my picture. _________________ 69 FI/AT square Daily Driver
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1991 Location: South Dakota
Posted: Mon Dec 31, 2012 1:30 am Post subject: |
I like your solution to the getting air to the tubes. I'm using the same type of aircraft duct with an aftermarket exhaust as what Mikes pic shows. Do you think the PVC will withhold the engine temps? Just curious to know as the coupler idea is a great one for guys wanting to run heat with non-stock exhausts. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Brent Samba Member
Posted: Mon Dec 31, 2012 3:24 am Post subject: |
| montehm wrote: |
| I like your solution to the getting air to the tubes. I'm using the same type of aircraft duct with an aftermarket exhaust as what Mikes pic shows. Do you think the PVC will withhold the engine temps? Just curious to know as the coupler idea is a great one for guys wanting to run heat with non-stock exhausts. |
It's cool air blowing through those. I think it will hold up as good as any other plastic part. _________________ 69 Fastback Build
Berg5 Build |
Yooyenkoo Samba Member
Joined: August 22, 2006 Posts: 284 Location: Nebraska
Posted: Mon Dec 31, 2012 4:54 am Post subject: |
Does this get pretty good heat though? I'm wondering as I'd like to do the same... Not one for a quite car. In the mean time, what would you say it cost you total to do this? _________________ "84 Vanagon
"81 Vanagon "Mini truck" |
Brent Samba Member
Posted: Mon Dec 31, 2012 5:19 am Post subject: |
| Yooyenkoo wrote: |
| Does this get pretty good heat though? I'm wondering as I'd like to do the same... Not one for a quite car. In the mean time, what would you say it cost you total to do this? |
There's plastic clips for the spark plug wires right on the tin, they don't melt. I don't see how the PVC would get any hotter. _________________ 69 Fastback Build
Berg5 Build |
Posted: Mon Dec 31, 2012 10:19 am Post subject: |
| Yooyenkoo wrote: |
| Does this get pretty good heat though? I'm wondering as I'd like to do the same... |
If you want hot heat, use the stock exhaust set up. An alternative to adding the hoses like Brion did, would be to remove the heat exchanger thermostats, and plug the cool air inlet. This will make more heat, without having the "pre-heaters" that the stock exhaust uses. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
