HastaAlaska Samba Member
Joined: November 22, 2012 Posts: 1450 Location: Off Grid
Posted: Wed Mar 08, 2017 1:34 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
| wcfvw69 wrote: |
| Maybe you can consider "buying" it back from the person who won it. You'd save face, respect and continue on with your adventure. |
Maybe some day but for now the new owner has plans with it
Thanks for that post Robbie _________________ Around The World in a VW - Follow the Docuseries
2011 - 20Something
Latest Adventure Series - https://bit.ly/LifeDoneDifferently |
williamM Samba Member
Joined: August 07, 2008 Posts: 4343 Location: southwest Arizona
Posted: Wed Mar 08, 2017 2:01 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
| asiab3 wrote: |
| williamM wrote: |
If you are going oil bath air cleaner- drop by and us my sawzall - the rest is going to the scraper.
[img]
Bottom right is the bracket it sits on. (pie pan thing.) |
Bill, even if Ben doesn't take you up on it, I think that would be a worthy piece to cut off and save. I think the "dusty conditions" filter uses a different mount anyway.
Robbie |
your right--
The dusty conditions oil bath is basically a 181 oil bath with a 2 strap bracket. This is a mimic of a lot of "small tractor" air cleaner.
But back to original equipment- I think the original T2 pre 71/72 air cleaner is as good, but hasn't the snorkel for getting cleaner air up higher the 181 has. Or the thermostatic controls on the intake for warm air the 181 has. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Xevin  Samba Member
Posted: Wed Mar 08, 2017 2:34 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
จนกระทั่ง Australia? _________________ Keep on Busin'
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
| Clatter wrote: |
Damn that Xevin...  |
| skills@eurocarsplus wrote: |
| SGKent wrote: |
MadMax78 Samba Member
Joined: May 26, 2007 Posts: 511 Location: The Netherlands
Posted: Sat Mar 11, 2017 4:28 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
Hi
Some guys mentioned it before, but we drove our bus through some pretty remote areas, including Asia. If you're interested you can look through our prep threads to see what we changed on our bus. I added the links at the end of this post.
On our trip from Amsterdam to Being the only thing we had failing was the fuel pump relay I think, for which we carried a spare.
I think for overlanding, these would be the most important things:
- Make sure everything is in good shape when you start out, no worn bearings, brakes, engine etc.
- Get a LSD, it makes a huge difference when offroading
- Get new tyres from a good brand with the right size and thread.
- Install a transmission and sump guard as specified in the difficult conditions manual.
- Install CHT, oil temp and pressure gauges.
- Have jerrycans or similar for 50L of extra gas to extend range
- Get adjustable steering rods on both sides (easier to fix those when they get bent)
Send me a PM and I can send you a list of the spares we carried. All our spare parts fit under the rear bench, so you really don't need that much.
In about 70.000 kilometers of overlanding we really didn't have that many failures. What we've seen failing was: shocks (yes, even Koni's), bearings, CV's, front torsion leaves, front sway bar, windscreen (cracks), double relay, clutch cable, steering rod and our Coleman gas stove (we had spares for that one too, so fixed it )
Amsterdam - Beijing http://www.thesamba.com/vw/forum/viewtopic.php?t=241979
Amsterdam - Cape Town http://www.thesamba.com/vw/forum/viewtopic.php?t=370281
Amsterdam - Euro 2012 http://www.thesamba.com/vw/forum/viewtopic.php?t=448292 (Ended up using another vehicle)
New York - Rio http://www.thesamba.com/vw/forum/viewtopic.php?t=538190 _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply , Busted Bus, Aircooled Technology & DIYAutoTune
2008: Amsterdam - Beijing - Olympics -- 17.500km
2010: Amsterdam - Cape Town - FIFA World Cup -- 26.000km
2014: New York - Rio de Janeiro - FIFA World Cup -- 27.000km
http://www.oranjetrophy.nl
Camper Special Club Member |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24431 Location: NYC/Upstate/ROW
Posted: Sat Mar 11, 2017 6:08 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
| Quote: |
| Get a LSD, it makes a huge difference when offroading |
Helped me through many a bad moment, as long as the newspaper taxis don't catch you on the Bay Shore _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
momdoer Samba Member
Joined: December 08, 2015 Posts: 12 Location: Yorba Linda, CA
Posted: Sat Mar 11, 2017 11:01 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
| I have a Toyota 3.4 liter V6 in my 78 bay. Super strong and reliable. |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Sun Mar 12, 2017 11:27 am Post subject: Re: Overlanding a VW Bus Around The World?! |
If you go with a type 4 engine, use all stock components inside, except the cam and lifters. Get a web-cam and lifters. I say that because I have seen two sets of 'oem' (whatever that means) cam and lifters grind themselves flat in 250 miles on rebuilt engines recently. Someone has messed up the manufacturing process on those parts.
If you go type 1, use an aluminum case. Magnesium (especially used) cases just don't have what it takes to push a bus around the world. The metal is too weak for all the leverage required to move a heavy vehicle like a bus. This is why the mexican air-cooled bus never went above 50ps, because more horsepower in a mag case in a bus destroys the engine.
For either engine, have you thought about modern fuel injection, say megasquirt? You can buy a whole kit from this guy and he can tune it for you:
http://www.thedubshop.net/
Can you imagine not having to worry about a distributor? Megasquirt systems use GM components which are widely available worldwide.
Lastly you're gonna want a strong transaxle. Seen this?
https://weddleindustries.com/transaxles/vw-transaxles/ultimate-091-bus-transaxle-0
You can even get it with a locking differential, which you'll need. _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
Posted: Sun Mar 12, 2017 1:18 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
| MadMax78 wrote: |
Hi
Some guys mentioned it before, but we drove our bus through some pretty remote areas, including Asia. If you're interested you can look through our prep threads |
Thanks very much for posting here and all you have added to TS already. Very useful for people like me. Cheers!
That list of failures seems pretty acceptable to me. I'm planning to have a similar list when I finish this next trip - better preparation is the key I think.
| tootype2crazy wrote: |
If you go type 1, use an aluminum case. Magnesium (especially used) cases just don't have what it takes to push a bus around the world. |
I would be inclined to agree with that.
I wonder if Mega squirt would pass emissions
Thanks for the advice guys
Keep it coming, reading with interest and we're still hunting for the bus _________________ Around The World in a VW - Follow the Docuseries
2011 - 20Something
GTV Samba Member
Posted: Sun Mar 12, 2017 3:38 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
| HastaAlaska wrote: |
I would not agree. A new mag case as the basis for a properly built lower rpm engine (driven and maintained by someone that knows VW's) is more than adequate. Mag cases also run much cooler and are about 15lbs lighter. I would never consider a used case for this application. The problem with VW's isn't the way they were engineered, it's the way they've been abused and repaired over the decades.
But that's just, like, my opinion, man.  _________________ EMPI Power Rules! |
Posted: Mon Mar 13, 2017 12:37 am Post subject: Re: Overlanding a VW Bus Around The World?! |
| GTV wrote: |
But that's just, like, my opinion, man.  |
Where's the hard data that a mag case runs cooler?? Has someone taken the guts out of a mag case and thrown them in an aluminum case and run both around a track at the exact same temperature outside?? That is a huge myth. I worked on hundreds and hundreds of ACVWs at the shop I worked at here in St. Louis for over 10 years and saw countless buses with mag cases that had spread bearing journals and other irreparable damage to the case. If it's a 1600 sure that's ok, if you don't over-rev it. Anything bigger and you're asking for trouble IF you plan on daily driving it, which he is gonna. Type 4 cases are aluminum and never, ever have a problem with the cases unless someone seriously abuses them with no oil and overheating. Porsche was involved with the development of the type 4 engine. Originally VW made the type 4 cases out of mag but then switched to aluminum because the porsche engineers didn't want the weakness of the type 1 engine going in their cars. It's a fact that aluminum is a better material for an engine block, or else all cars today would be made with magnesium engine blocks. The only drawback that an aluminum case has over mag is the weight, but the durability of them is worth that sacrifice. _________________ air-cooled or nothing for me
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2270 Location: Detroit, Michigan
Posted: Mon Mar 13, 2017 6:37 am Post subject: Re: Overlanding a VW Bus Around The World?! |
Megasquirt if fully adjustable, as long as you tune it right, it'll pass emissions no problem. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5874 Location: Wamego, Kansas, USA
Posted: Mon Mar 13, 2017 7:39 am Post subject: Re: Overlanding a VW Bus Around The World?! |
| Spike0180 wrote: |
Megasquirt if fully adjustable, as long as you tune it right, it'll pass emissions no problem. |
Unless you live in a state where you have to show all of the original equipment, no matter how practical it may be to do so. (Looking at you, California.)
I have no problem in theory of emissions requirements. It is obvious that they have gone a very long way toward cleaning up the air. And I like air.
However, it has always astounded me that in some locales, the emissions requirements don't necessarily care as much about the numbers as they do about the equipment.
I would have to imagine that a modern fuel management system such as Mega Squirt would probably allow for a much more efficient engine, but would not be legal in California because it isn't original to the vehicle/engine.
Or, if it can manage to meet the required numbers but doesn't have all the equipment, it'll fail too. Just doesn't make sense to me.
That nonsense did work out in my favor one time, though. Years ago I bought the 72-74 exhaust system off a guy who moved to California. He couldn't register the bus there because it didn't have the exact exhaust system from his '78 anymore. Even though it met the actual exhaust numbers requirement. (He had moved from a different state that only had a tailpipe requirement.)
Tailpipe requirements seem much more reasonable. Who cares what is bolted to the engine if the engine is meeting the tailpipe requirement? _________________ Dave Cook
1973 Wild Westerner
My Thing |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13627 Location: West Coast, USA
Posted: Mon Mar 13, 2017 10:14 am Post subject: Re: Overlanding a VW Bus Around The World?! |
| Can you imagine not having to worry about a distributor? |
Is this a joke? This has to be a joke. _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
Road trip reports and tech blog:
https://www.patreon.com/airschooled |
Posted: Mon Mar 13, 2017 3:05 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
In my earlier post I mentioned I could share the spare parts list we used. So I created a quick shared Google doc. You can view it here:
https://docs.google.com/spreadsheets/d/1fOOftxpHJcytmTHv4McMa9dMfw6iKQ06Pxu9cuJggL8/edit?usp=sharing
Please note this list is specific to our setup, so go ahead and cherry-pick what you think is useful but it should be a good starting point.
I also noticed a few people talking about Megasquirt here. I would say it definitely has its upsides for overlanding. Two main advantages for us are that it has full automatic baro adjustment so it adjusts for changes in altitude. (Try running an L-jet car from sea level to 4000 meters without adjustment) And it makes any troubleshooting a whole lot easier, plug in your laptop and immediately see if all your sensors are giving you sensible data. And as a bonus you can make mixture and spark changes as required for driving conditions.
We choose to set it up in parallel to the original L-jet and dizzy setup so in case of issues I can switch back to stock ignition and or fuel within a minute. Basically giving us a redundant spark and fuel system. _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
GTV Samba Member
Posted: Mon Mar 13, 2017 4:00 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
| GTV wrote: |
Where's the hard data that a mag case runs cooler?? Has someone taken the guts out of a mag case and thrown them in an aluminum case and run both around a track at the exact same temperature outside?? That is a huge myth. I worked on hundreds and hundreds of ACVWs at the shop I worked at here in St. Louis for over 10 years and saw countless buses with mag cases that had spread bearing journals and other irreparable damage to the case. If it's a 1600 sure that's ok, if you don't over-rev it. Anything bigger and you're asking for trouble IF you plan on daily driving it, which he is gonna. Type 4 cases are aluminum and never, ever have a problem with the cases unless someone seriously abuses them with no oil and overheating. Porsche was involved with the development of the type 4 engine. Originally VW made the type 4 cases out of mag but then switched to aluminum because the porsche engineers didn't want the weakness of the type 1 engine going in their cars. It's a fact that aluminum is a better material for an engine block, or else all cars today would be made with magnesium engine blocks. The only drawback that an aluminum case has over mag is the weight, but the durability of them is worth that sacrifice. |
It has been observed many times Aluminium absolutely has its advantages over magnesium, but heat dissipation is not one of them. All cars today are water cooled, making heat much easier to control. They also need the strength as most power plants make gobs more hp/liter than they did in the 60's. Apples vs oranges. _________________ EMPI Power Rules! |
richparker Samba Member
Joined: November 24, 2011 Posts: 7761 Location: Durango, CO
Posted: Mon Mar 13, 2017 8:11 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
| GTV wrote: |
| GTV wrote: |
It has been observed many times Aluminium absolutely has its advantages over magnesium, but heat dissipation is not one of them. All cars today are water cooled, making heat much easier to control. They also need the strength as most power plants make gobs more hp/liter than they did in the 60's. Apples vs oranges. |
Lots of data out there on how a aluminum case runs 10-15* hotter then a mag case. If you're building anything big you're gonna add a full flow system, which will keep the temps in control. So it's a moot point, IMO. _________________ __________
β71 Westy build
Adventure thread
β65 Deluxe Build
β71 Double Cab |
GTV Samba Member
Posted: Mon Mar 13, 2017 9:27 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
| richparker wrote: |
Lots of data out there on how a aluminum case runs 10-15* hotter then a mag case. If you're building anything big you're gonna add a full flow system, which will keep the temps in control. So it's a moot point, IMO. |
External oil cooler will do the trick, but a good one (Setrab) with a thermostat will be costly, it adds complexity, more parts to fail or get damaged, more costly oil changes and adds additional weight. If it was mine I'd build a modest mag cased based engine with a type 4 cooler (among other tricks) and call it a day. K.I.S.S.
To each their own. _________________ EMPI Power Rules! |
Posted: Mon Mar 13, 2017 10:01 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
^Yes, building a quality FF system is not cheap. Especially if you use proper hoses and fittings. But, if you're building a bomb proof 2L T1 for a bus, you're gonna need the full flow with Tstat and oil filter.
Ben wants a sick ass T1 to travel the globe, right? Why ask us? He needs to find a builder and go with their expertise. I'd be calling someone like Pat Downs and having an engine built. Yea, it's gonna cost money but that's the world. You want/buy a shitty $3000 engine, your gonna have a shitty time. Spend the money before you go, not while you're going. _________________ __________
β71 Westy build
Adventure thread
β65 Deluxe Build
β71 Double Cab |
Posted: Tue Mar 14, 2017 4:24 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
| MadMax78 wrote: |
| I also noticed a few people talking about Megasquirt here. I would say it definitely has its upsides for overlanding. |
Hey thanks very much for the spare parts list, have saved a copy.
Megasquirt does sound good. Not sure the Australian import people will say about it as it is not stock. Maybe we should run dual system like you and remove the Megasquirt when we get Australia.
Like VWWestyman said - I don't see what the problem with non-stock is, as long as the results are better for everyone.
In response to RichParker's last comment. Engines in North America cost about 10 times what they do south of the border. I just hope that they work 10 times better too. _________________ Around The World in a VW - Follow the Docuseries
2011 - 20Something
Posted: Tue Mar 14, 2017 5:00 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
In response to RichParker's last comment. Engines in North America cost about 10 times what they do south of the border. I just hope that they work 10 times better too. |
I'm sure they do, it's the whole first world thing. All joking aside, you've had a lot of issues with the parts and the engine (s) you've got (bought) in South America. Time to make a change and drop the money on a proper engine built by a proper builder. _________________ __________
β71 Westy build
Adventure thread
β65 Deluxe Build
β71 Double Cab |
