Montehms 67 Prairie Square
Page: Previous  1, 2, 3 ... 73, 74, 75
bobnorman
Samba Newfoundlander
bobnorman is offline
PostPosted: Tue Feb 20, 2018 6:14 am    Post subject: Re: Montehms 67 Prairie Square Reply with quote
Car is looking great! Congrats on the win...again, well deserved. Speaking of driving in the snow, I ran a 63 bug for a couple years in the 90s... My favorite memories from that time are driving it in the snow. I wish we didn't use so much salt on the roads here, otherwise I think I would (when done) take the square out for a spin in the winter now and then.
Air does not freeze. Air does not boil.
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
Bobnotch
Bobnotch is offline
PostPosted: Tue Feb 20, 2018 9:12 am    Post subject: Re: Montehms 67 Prairie Square Reply with quote
MonT3 wrote:
Thanks for the compliments guys. Not sure the Huls would do me any good but would be nice to stretch out in the back and camp.
This weekend's show was cut short due the storm coming in from Wy. I've never seen older, mature men became really concerned as they had no means (trailer) to get their cars home. I slipped out while the flakes were small and got the car home and went back for my truck. By the time I got back home the flakes larger and steady in their fall. Over all I had a good time. Took 1st place for the second year. Here are a few pics from the show...
Now, back to the engine build.
Sweet!! Congrats on a well deserved win. Applause
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
ALLWAGONS
ALLWAGONS is offline
PostPosted: Tue Feb 20, 2018 9:55 pm    Post subject: Re: Montehms 67 Prairie Square Reply with quote
Nice Mr. MonT3!
andybla
andybla is offline
PostPosted: Wed Feb 21, 2018 8:03 am    Post subject: Re: Montehms 67 Prairie Square Reply with quote
like the wheel covers also Cool
MonT3
MonT3 is offline
PostPosted: Tue Jul 31, 2018 6:09 am    Post subject: Re: Montehms 67 Prairie Square Reply with quote
Cruiser Show in downtown Rapid City...
Custer Gold Discovery Days show and shine...
Rest of my time has been spent working on my engine. Almost there!
MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild
WildIdea
WildIdea is offline
PostPosted: Mon Nov 30, 2020 8:52 pm    Post subject: Re: Montehms 67 Prairie Square Reply with quote
Such an awesome car in person MonT3! It’s nice to finally read up on the backstory of your build journey. Looking forward to the spring cruising.
1977 Sage Green Westy
https://www.thesamba.com/vw/forum/viewtopic.php?t=691987
1965 SWR Walk-Through Standard
1960 211 Panel American Camper Conversion
MonT3
MonT3 is offline
PostPosted: Sun Feb 18, 2024 5:53 pm    Post subject: Re: Montehms 67 Prairie Square Reply with quote
It's been such a long time since I've posted on my squareback... back in June of 2022 I was heading into the hills for a drive. There are certain hills i like to climb at a good speed and I was on one of them. I crested the hill, A large plume of white smoke came from the under the car and immediately took it out of gear and coasted to the side of the road till I was able to turn into the parking area of the Old McDonald animal petting zoo parking lot. I knew I pushed too hard and something gave. I got out and took a look under the car as I could see a trail of oil coming into the parking lot.
Looking under the car, I could see a pool oil and after lifting the lid, I had oil all over the place.
I called a friend to get a rider back to my place where I hitched up my trailer to my truck and went back out to retrieve my car. I was so mad and upset at myself for pushing as hard as I did going up the hill that I was rushing to load the car onto the trailer. In doing so, My driver door took an 9 inch crease from rubbing on the trailer fender. That didn't sit well with me.
I let the car sit in the garage for a few months as I didn't want to mess with it as life takes over and I've been working on my Corvan as well as working on my masters program as well as work. Last year I pulled the engine and looked it over. I had oil leaks from each jug. From the spillage of oil on the tins, I found that oil breather tube had a crack under the egg-shaped bowl and the hose that connects the oil tube failed spewing oil onto the exhaust pipes. Because of the way I had oil all over my lower tins, I decided to forego a compression test and break the engine down to a short block and take a look at the pieces. I'm glad I did as I found the number 3 jug destroyed and the number 4 was right behind it with a hairline fracture. Here's #4 as #3 pic didn't want to upload as I've tried several times to load it. It's worse than #4...
I got a new set of pistons and rings, cleaned and honed the jugs and reassembled that. I also decided on new heads. My buddy Brian of Type-E Motorsports did the machine work for my 94mm jugs and pistons and I re-checked my rocker geometry and began to reassemble to a long block. So that's where I am at the moment. I'll be installing a CB performance Type3 alternator as well as a set of Webers. Hope to get it back on the road this spring. The door will get corrected when I have the ¬¬car driving once again. I hate to see it when I go into the garage as it's never look this bad (to me) but I sure miss driving it.
MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild
VWporscheGT3
VWporscheGT3 is offline
PostPosted: Tue Feb 20, 2024 4:47 pm    Post subject: Re: Montehms 67 Prairie Square Reply with quote
what kind of pistons you putting back in it?
Bobnotch
Bobnotch is offline
PostPosted: Wed Feb 21, 2024 2:08 pm    Post subject: Re: Montehms 67 Prairie Square Reply with quote
Well, hopefully the scratch is just in the clear coat. I only say that, as I see white in the scratch (clear coat), versus blue (paint). Wet it down and see if it changes color, as that'll tell you how deep it is. It still sucks, but something like that can be easily written off as something fell in the garage, or you backed into something you couldn't see, and bumped the car. It's like I told a friend of mine, a falling shovel handle will do more damage than rocks being kicked up because of a construction zone (he had one go thru the glass before, and it whistled, until he replaced the glass). He's also had the glass fall out of a mirror before and chip the paint in 2 places. It went all the way down to the epoxy primer layer (no rust formed there even after 10 years of being outside).
It's good to see you've still got the car (even if it looks like a "barn find." Laughing It won't be long before you get the engine rebuilt and the car driving again.
Tram wrote:
Tram wrote:
squaretobehip
squaretobehip is offline
PostPosted: Wed Feb 21, 2024 4:44 pm    Post subject: Re: Montehms 67 Prairie Square Reply with quote
I think a wash might be a bit therapeutic. Then grab a soft indoor cover for it to keep it from getting that dusty again.
Glad you're still around. You'll fix it.
1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Clatter
Clatter is offline
PostPosted: Sun Mar 31, 2024 9:22 am    Post subject: Re: Montehms 67 Prairie Square Reply with quote
Good on you for being out and driving.
these are then things that happen when you do so.
My car sits in the garage all dusty like that right now as well.
Keep telling myself that the next restoration will be easier than the last one! Laughing
Bus Motor Build
It does not exist!
Page 75 of 75
