Official 1960-1961 registry and restoration guide thread.
Page: 1, 2, 3 ... 29, 30, 31  Next
AlteWagen
Troll
AlteWagen is offline
PostPosted: Sat May 14, 2011 2:22 pm    Post subject: Official 1960-1961 registry and restoration guide thread. Reply with quote
Please post your BC info here and any specific build questions/comments.
Thanks TheSamba for making it easier for us to build correct cars and keeping them alive!
AlteWagen
Troll
PostPosted: Sat May 14, 2011 4:35 pm    Post subject: Reply with quote
Purchased in 1991 for $125, has over 300,000 miles with over 6 engines, and 3 transmissions since purchased.
Vin: 29090XX
Feb 1960
European delivery
L 436 Indigo Blue
Special features:
60-61 only 3 finger apron
came with 58-59 plastic visor which looked original to the car even though PR states it should be a padded one. Maybe different for euro spec. was different. Also had a 58-59 style wiring harness that also looked original to the car.
Entered U.S. as gray market so bumper over riders were installed and semaphores were leaded closed.
Sunroof was grafted in due to extensive roof damage (kids used it as a trampoline I guess) and what looks like a ton of hail damage which was repaired by PO with over an inch of bondo.
Still sporting its original black plates issued in 63.
AlteWagen
Troll
PostPosted: Sat May 14, 2011 6:01 pm    Post subject: Reply with quote
1960 only specifics
Black hood crest
One year only 3 finger apron
3 rib pressing in vin plate area
large vin plate with made in western germany at the bottom of the plate (formally small separate tab)
Rubber wire tube conduit for head light wiring (formally steel tube)
Last year for cast chrome dash trim and matching dash grills (small hole)
Last year for no passenger side foot rest
Last year or semaphores (domestic market)
One year only front trans mount
One year only oil dip stick
One year only inner rear apron panel
One year only door handle with vertical key slot
Last year for H rear apron
More related threads:
Turn signal switch
http://www.thesamba.com/vw/forum/viewtopic.php?t=220203
http://www.thesamba.com/vw/forum/viewtopic.php?t=460420
http://www.thesamba.com/vw/forum/viewtopic.php?t=421974
Ceramic green specifics
http://www.thesamba.com/vw/forum/viewtopic.php?t=458324
https://www.thesamba.com/vw/classifieds/pix/3684157.jpg
https://www.thesamba.com/vw/classifieds/pix/3684170.jpg
https://www.thesamba.com/vw/classifieds/pix/3684179.jpg
https://www.thesamba.com/vw/classifieds/pix/3684180.jpg
1961 buyers guide
http://www.thesamba.com/vw/forum/viewtopic.php?t=460792
1960 only door handle
http://www.thesamba.com/vw/forum/viewtopic.php?t=385060
http://www.thesamba.com/vw/forum/viewtopic.php?t=432195
August 1960 engine and other details
http://www.thesamba.com/vw/forum/viewtopic.php?t=449840
Fender ID thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=448426
http://www.thesamba.com/vw/forum/viewtopic.php?t=386056
1960 only trans mount
http://www.thesamba.com/vw/forum/viewtopic.php?t=444274
http://www.thesamba.com/vw/forum/viewtopic.php?t=441083
http://www.thesamba.com/vw/forum/viewtopic.php?t=435986
1960 rear view mirror
http://www.thesamba.com/vw/forum/viewtopic.php?t=438274
1960 front apron
http://www.thesamba.com/vw/forum/viewtopic.php?t=436299
1960-1961 steering wheel and horn
http://www.thesamba.com/vw/forum/viewtopic.php?t=369613
http://www.thesamba.com/vw/forum/viewtopic.php?t=379742
http://www.thesamba.com/vw/forum/viewtopic.php?t=348964
1960 euro specifics
http://www.thesamba.com/vw/forum/viewtopic.php?t=242532
1960 only dipstick
http://www.thesamba.com/vw/forum/viewtopic.php?t=420789
1960 interior
http://www.thesamba.com/vw/forum/viewtopic.php?t=400732
1960 gas tank color
http://www.thesamba.com/vw/forum/viewtopic.php?t=374205
1960 only vin tag
http://www.thesamba.com/vw/forum/viewtopic.php?t=354555
1960-1961 non snowflake tail lights
http://www.thesamba.com/vw/forum/viewtopic.php?t=347614
1960 front sheet metal
http://www.thesamba.com/vw/forum/viewtopic.php?t=344613
Hood props
http://www.thesamba.com/vw/forum/viewtopic.php?t=463676
AlteWagen
Troll
1961 only specifics
http://www.thesamba.com/vw/forum/viewtopic.php?t=173461
1961 hood
http://www.thesamba.com/vw/forum/viewtopic.php?t=250199
potentvw
potentvw is offline
PostPosted: Sat May 14, 2011 8:12 pm    Post subject: Reply with quote
Lots of great info here. I have not looked through everything yet, but in case its not known, early 60's had a 4 rib front apron, same as a 59.
AlteWagen
Troll
PostPosted: Sat May 14, 2011 10:44 pm    Post subject: Reply with quote
Correct. We are trying to find out the actual vin cut off for this, do you have a early 60 with a four finger apron?
Zekes'Low60
Zekes'Low60 is offline
PostPosted: Sun May 15, 2011 9:26 am    Post subject: Reply with quote
My 60 has the 4 finger apron. Built Dec10, 59
Hard to see.....but it has 4.
Found an old pic when she was fresh out of the barn that show the 4 fingers.
10 December 1959.... L41 VW De Luxe Sedan..."Christine"
62 'Vert basketcase....."Tetnus"
62 Dragcar/ProStreet project....."Muffdiver"
AlteWagen
Troll
PostPosted: Sun May 15, 2011 11:04 am    Post subject: Reply with quote
Thanks.
Wow your gas heater is mounted on the passenger side to boot! Any other accessories? What kind of visors do you have?
Zekes'Low60
PostPosted: Sun May 15, 2011 11:43 am    Post subject: Reply with quote
Padded visors. Has the round VDO gas gauge but missing the sender. Tank got changed out and I guess the sender went with the old one. Crying or Very sad
I had taken the heater out but it leaves an ugly hole so I put it back in.
AlteWagen
Troll
PostPosted: Sun May 15, 2011 12:03 pm    Post subject: Reply with quote
Would you mind posting pics of your gauge, there seem to be different dash grills that were used. One with the slots surrounding the gauge and the other one with straight cut off slots. Do you know if it was a dealer install or factory? BC?
Zekes'Low60
PostPosted: Sun May 15, 2011 12:28 pm    Post subject: Reply with quote
Not sure about the gauge but Im thinking dealer install maybe?????
Steering wheel isnt correct....horn ring hoop isnt broke off....never was one and wheel doesnt have cut out for it.
BC
AlteWagen
Troll
PostPosted: Sun May 15, 2011 12:39 pm    Post subject: Reply with quote
The only way to tell dealer vs. factory is with a BC. Here is my gauge that I pulled off an early 61
My car is a 60 I just couldnt get all the steering wheel parts together so I slapped on a 59 wheel and column I had.
Thanks for the info!
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sun May 15, 2011 12:52 pm    Post subject: Reply with quote
I've owned this beetle for 22 years now. Purchased in Lake Arrowhead for $680. Built 13 January 1961. Delivered to the USA.
It has a three finger front apron
screw terminal wiring
no foot rest
had a plastic plug in the dash for a choke cable now running a 36 hp.
red handled oil dip stick
H rear apron
vertical door handle keyway
1960 type turn signal switch
I believe it is an original sunroof although the birth cert does not indicate this. I base this on my last headlner install. The OG color was Pearl white it was green when I got it.
Roads Scholar
Member# 2059
stale air
stale air is offline
PostPosted: Sun May 15, 2011 1:01 pm    Post subject: Reply with quote
Fyi, according to the plate number is was originally registered out of Hathorne Ca. Cool
AlteWagen
Troll
PostPosted: Sun May 15, 2011 1:34 pm    Post subject: Reply with quote
This is exactly what I am talking about, many "60 only" features on a mid year 61.
Could you please post you vin so I can add it to the registry and we can narrow down the actual cut off for the various listings?
Thanks
tasb
tasb is offline
PostPosted: Sun May 15, 2011 2:56 pm    Post subject: Reply with quote
vin # 3 591 436
honestly some things like door handles, turn signals and dip stick are very easy to change. Others like the lack of a foot well and aprons and wiring would be dificult to change.
Roads Scholar
Member# 2059
AlteWagen
Troll
PostPosted: Sun May 15, 2011 3:06 pm    Post subject: Reply with quote
Do you mean the foot rest? I had to put one in on mine due to the 61 up rubber mat I got at a swap. What I found strange is my 60 already had the slot for the foot rest tab in the firewall stamping.
BTW thanks for the vin
58Dub
58Dub is offline
PostPosted: Sun May 15, 2011 3:21 pm    Post subject: Reply with quote
My 60 has a passenger foot rest. built Jan 60
58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project
Zekes'Low60
PostPosted: Sun May 15, 2011 3:38 pm    Post subject: Reply with quote
Not sure if mine came with a footrest but it has the slot.
janerick3
janerick3 is offline
PostPosted: Sun May 15, 2011 8:47 pm    Post subject: Reply with quote
tasb wrote:
vin # 3 591 436
We owned #3509444 from '66 to '71 and it had all of the '61 features, but still had the 4-tab hood. I'm guessing your car was rolled early in its life and the og '61 hardtop body was swapped out for a '60 ragtop body.
Thanks,
Jan K.
Page 1 of 31
