Symptoms Solved and Fixed
Tcash
Tcash is offline
PostPosted: Mon Apr 08, 2013 10:14 pm    Post subject: Symptoms Solved and Fixed Reply with quote
To link to this thread
Code:
[url=http://www.thesamba.com/vw/forum/viewtopic.php?t=551358&start=0&postdays=0&postorder=asc&highlight=]Symptoms Solved and Fixed[/url]
TO SEARCH THIS PAGE
Press "Ctrl"+"F" and enter search term in box located at top right corner
[BRAKES
brake pedal stiffness & warning light Q...
Rear Drum Brakes Locking On (1972 Camper)
Dragging Front Disk Brakes
Replaced master cylinder Now warning light comes on - Solved
Rear brake drum removal
71 bus with front brakes binding
Brake lights out
Front Brakes Sticking 71 Bus
Replace brake servo and pedal still hard as a rock (beware of the previous owner (PO)
71 dash brake warning light. Help
Front Disc Brakes Intermittently Lock Up
1975 Transporter seems to be locking up
71 Westy rear brake question
Help! what have I done?!(brake hose)
Noise while turning right
Hard brakes & white smoke
Large drop in idle when engaging brake booster.(brake booster leaking)
Indicator Switch Problem or Relay?(wire pulled off relay)
Heater on, battery light comes on?
Turn signal issue
Front end knocking sound and wheel binding. *SOLVED*
Feels like my bus is going over bumps (or cracks) in the road
scraping brake drum, retaining ring popped out, pics and videos
missing fluid from the reservoir
Tight front disc brake
Brake Pedal Sticking (Solved)
Had an odd brake issue but solved - Just info
pressed the brakes and the engine stalled
missing brake fluid mystery solved
74 bus brake problem, brakes lock up booster ? fixed?
Sticky Brakes
dragging brakes
bus stuck - one wheel spins one wheel wont.
WhattaDrag. . Diagnosing Brake Release Issues, Colin
Installed New Backing Plates and Drum Rub On Them
BRAKES]
CAMPER
Westy Fridge - won't get cold (1978)
Leaky Westy Faucet Fixed
CAMPER]
[DRIVETRAIN
Some clutch issues (input shaft rusty)
Transmission / Shifting Issue (pilot bearing)
Ping on initial movement
73 Bus wont shift
Tough shifting 77 Bus
Expecting a busted CV joint, but wait . . .
77 vw bus won't shift into gear!
Another rough shifting thread!!!
'71 Westy shifting problems
Shifting Problem - Have to Hold 1st & 3rd
Clutch questions, New clutch disk stuck to flywheel.
Output flange/shaft play(diff. housing worn)
1977 riveria..3rd gear only
Rear end vibration(wheel bearing)
Noise when the clutch was pushed in
1973 bus will not go into gear
Stuck Clutch
Clutch won't disengage after being stored for the winter
clutch issues,not disengaging.with pictures. SOLVED
HELP PLEASE - Trans problem (STUCK IN NEUTRAL) - SOLVED
help I can't shift into reverse
Clutch pedal no pressure! FIXED!
Clutch won't fully release, unsure why
need help with clutch problem.
DRIVETRAIN]
[ELECTRICAL
78 bus starter w/relay No click no nothing (ign swtch)
Distributor shaft popping out
LED Turn Signal Indicators(Green Arrows) not working
No start diagnosis confirmation
75 Bus Type 4 1.8 Engine Twin Carb does not want to start
My bay is overcharging?!?
Starter not cranking ign. in starter position 0v on red/b wire
Smoking light switch!!!! How to make it quit
Turn signal problem -solved
Fuel Tank Replaced, Hooray! Sending unit doesn't work, Booo.
Brake Light Problems
'78 FI westy won't start
Indicators are now flashing rapidly 1978 T2
Horn grounding issues?
Alternator light stays on until I rev the motor slightly
"Won't start thread." - FIXED
what did I do wrong this time? It just cranks and cranks.
1979 Bus Missing/Cutting out and Bucking
Crazy Electrical Problem (ignition off engine continues to run)
An interesting electrical issue (ignition off engine continues to run)
Gen idiot light help
Hi Beams Don't Work After 211953513G Install
weird reverse light problem
72 bus ignition lock cylinder comes out
1968 Baywindow turn signal problem
Headlights stuck on dimmed
turn signal problems
FIXED: replaced Alternator. light still on.
Help, no electrical current any where on the bus
73 VW bus turn signal problems (E-switch)
72 bus dash light problem
1972 Bay Electrical issue (starter clicks)
Wire Question (no headlights, side lights work)
Accufire/ A miss and I can't find it?!(magnet fell out of trigger ring)
73 turn signal problems(hazard switch came apart)
turn signal wiring prob(flasher relay)
Gauges are acting up.(ground strap)
'69 pop top camper mobile steering wheel locks randomly!
right side turn idicator not working. 1970 type 2 camper.(dirty contacts in turn switch)
Turn signal issue
Brake Light Problem
FIXED!!! Engine cutting out intermittently
No spark- bad coil?
No crank condition *Solved*
Brake light help 1970 tin top.(solved.)
Wipers are always on at same speed.(intermittent wiper relay)
High beam blows fuse 5
Charging system problems(Brushes)
Gen light issue solved
71 Bus Emergency Short Problem. Help!!
alternator problem
Fuel gauge stuck on full
Timing Scatter on '71 - SOLVED!!
Key on, lights on. Once started, no lights. Help!
Need help with short in rear turn/brake signals ***SOLVED***
After changing point, plugs, wires and all fuel and vac lines it would not start. All I could get was a backfire.
MYSTERY powerloss while driving 1974 bus
turn signals and horn have abandoned me!
tail light wiring
i keep going threw starter
Installing new SVDA problems
voltage Reg test
no power at all to the front of the bus. No lights ,radio nothing
runs very rough all of a sudden
started running really rough
I've somehow lost my turn signals and won the never-sought red light.
How to fry a coil
The Fast Right Turn Signal
One Bright Out - FIXED, JUST A BAD FUSE
No spark problem fixed thanks to a search on Samba!
Bad starter or something else?
Dies...starts...dies...starts
With Timing...won't stay timed (longish)..Fixed it!
Engine Hesitates / Stumbles
Starter won't crank/Temp fix
starts to die at the light sometimes. It's starvation is so severe I can't get abouve 50 MPH
Turn Signals Fixed.It was a bad ground
Battery not charging in my 79 BUS
stuttering while accelerating [Fixed][Ignition Coil]
Battery Boiling/Sulfur Smell
turn signal probelm? problem fixed
gen light on then fixed,replaced brushes
Burnt wire inside distributor solved,hooked pints wire on wrong side of coil
fuel gauge moves when i turn the head light on.
Stuck spark plugs
emergency flasher and left signal is shorting out
Somewhat erratic idle
74 standard randomly dying solved,replaced Accu-Fire with points
Hesitation and Stumbling Under Load solved, dist.
won't start again after warmed up once solved,starter bad cranking to slow
loss of power solved,plug tip unscrewed and plug wire came off
Gutless solved, Dist. cam worn
Turn signal problem solved, po installed single filament bulbs in double filament sockets
Left front turn was not as bright as the right and it flashed too quickly solved,po switched wires on light
Brake Lights and Horn Dead
Help with Voltage Regulator test results
Alternator Light On!
Voltage Drop At Coil
cranked now nothing
Bus Against the Wall
New plug wire won't fit spark plug
gen light wont go off.(wires came undone)
ELECTRICAL]
[ENGINE CARBURETED
Weber Advice Needed Off Idle Stumble
sputters and backfires under acceleration 1600DP PICT34 009
Engine noise in new engine
HELP brand new engine doesn't crank once installed!
Surging when accelerating at low speeds (fixed)
Help! On the road. Low humming vibration coming from rear
Sometimes my carb leaks sometimes it doesn't?
Stalling Coming to a Stop (fuel shut off solenoid loose)
Bus will warm up, but after tHat doesn't idle?? Please help!
69 Fuel pump rebuild
Not idling well(Booster Hose)
Westy with Flat Spot distributor suggestions(Lubed dist.)
'71 bay window starting issues. Help?
stalls while braking
Frustrated over tuning. There must be something obvious?
Solex 35 troubles SOLVED
Rebuilt engine smoking after warming up(valve Adjust)
Flywheel end play too tight
Weird engine noise.
Why can't I get my bus to idle (SOLVED)
Bus starts but won't idle
Under heavy acceleration, it sputters, shudders, coughs and spits
Timing
34 PDSIT-2 gas spitting
Spark plug blew out
Bay hard to start when cold 1979 bay T4 with dual 36 dellorto
Pinging won't stop
Weird stumble --- Blame fuel or fire?!? ** SOLVED!!! **
Aggressive Oil Leak w/ pics SOLVED
I'm at a (power) loss
stranded spark plug blew out
Self-adjusting idle screw - FIXED
My engine will turn over but will not start
69 Baywindow very slow
off idle stumble,fixed accell pump
engine oil was too the brim,gas in oil
cruising along at about 65 mph when all of a sudden my engine started to stutter,plugged filters
oil leaking nonstop from which looks like behind the crank pulley solved,rpl pulley
Leaking Carb Shaft solved,shaft worn rpl carb
losing power going up the gentle grade solved,clogged main jet
Tuned up,ran great for about 6hrs started backfiring threw the carb real bad had to tow home
not firing on cilinder 3 or 4 til i get on the gas solved, intake gasket
1600 Dual-Port won't idle
randomly spits and sputters solved,Make sure you return all your dad's tools?
No fuel to carb, not fuel pump, maybe plunger/rod?, with video
Intermittent, rough idle, cranks won't start
ENGINE CARB]
[ENGINE FUEL INJECTED
High Air Fuel Ratios While Coasting (Decel valve)
'79 F.I. Hard Start when Cold, stumped! FIXED!!!!
1977 Bay Widow Fuel Injection Starts and Idles,stalls Given Gas
1979 2.0 L FI stumble
'79 CA FI bus ran fine then suddenly won't start
76 bus stalled, ran perfectly and then didn't
1979 Westfalia won’t start after sitting for 2 years
76 bus stalled, ran perfectly and then didn't, JUST WENT through my fuel system
Injection help intermittent bucking when cold damp or rain
Bucking 78 2.0L FI
77 bay stopped running?
Scraping sound after rebuild
Low-RPM stumble
Get a good couple blocks, Dies gently.
1979 westfalia P27 Fuel injection issue - SOLVED !!
2.0L FI engine acceleration problem
Bus starts,very high idle, then dies
Big Valve Adjustment
loose power, occasional backfire
81 Crank no start unless I pull brake booster line
79 bus runs great- won't crank back up when still hot?
1977 VW Bus won't start !?
Fuel delivery issue...am I on the right track?
Here's a weird one, can someone help? Replaced hoseNo start.
Stalling when coming to a stop at normal operating Temp.
'78 Westy engine rebuild - Will not stay running (fouled spark plug)
79 Idles/revs fine, but dies when trying to go somewhere (fuel filter)
Hydraulic Lifter Exhaust leak or loose head? FIXED (exhaust leak)
Engine problems on a 79 Westfalia 2L type 4 (AFM)
Starts won't idle(Intake elbow to aux. air regulator hose was leaking)
Hydraulic Valve Sound on Deceleration(heat exch. loose)
Running Rich & Bucking - Verifying Diagnosis?(ECU)
Slow acceleration, Tach needle bouncing(points)
Pushrod/ being cut/ groove in pushrod
78 bus stalling when applying load(TSII)
77 Bus trouble running after storage(hose knocked loose)
Stalling Bus 1978 Federal model -SOLVED!! - (EGR Valve Leak)
Hot Start Issues - FI bus super rich when hot **FIXED**(AFM)
Bus won't stay running!
Stutters, gags, dies, only in 3rd - SOLVED(TSII)
Problem solved, lesson learned(Injectors)
Intermittent Bucking
1977 Westfalia Slow start
Engine turns, valves don't move
Damon's Bus Won't Start (Long) Please Help!
Whats the cause of this variable but consistent miss(vacuum advance can leak)
What the heck is this sound?
FI fuel pump won't shut off & engine won't start(88a on double relay)
Engine won't idle after warmup
engine bucking on acceleration
dies at the lights
stalls when reving in gear
oil pressure pretty much gone
Hesitation, bucking, loss of power spells doom for camping
SOLVED - Normal to kick out black smoke, dies idle? - AFM
Stranded on the highway right now and need help - solved
Intermittent Jerks/Hiccups
Road Trip Help: Horrible Gas Mileage!!!
1979 Bay - Hard Starting
fuel in S boot-solved
1978 Westfalia- Tough to start and rough idle {video}
79 US Westy in UK - Sudden loss of power / accel - SOLVED!
need help staring bus
Cylinders are filling with gas (SOLVED!) Smile
Bus dies as I rev-up in gear
It starts right up every time when dead cold, but after starting and running it for a couple minutes it refuses to start again
stalls,vacuum leak problem solved
78 bus starting problems
did 1/2 a tuneup. (cap, rotor, plugs),hit the key, brrmm... dies, It will stay running as long as I keep my foot mostly pinned to the floor
Sudden severe oil leak -- blown oil gallery plug, now fixed
79 westy 2.0 FI missing at high revs FIXED
Miss
warm start problem
cuts out and sputters
"fixed" my bus and now it won't start *RESOLVED*
Valve adjust...bang, bang FIXED!
Engine low on power
type 4 engine lack of power. I replace the plugs, wires, distributor, and coil.
78 FI hesitates in all gears, especially while warming up
Engine just cuts out every few seconds. Or it'll buck like a ride in a cowboy bar.It idles fine (beautifully in fact)
started to run poorly and hated idling
not starting, have spark and gas,
Backfiring
I've had three separate occasions where my bus bucked/sputtered, fixed 3 different ways
Fuel injection idles low at start up and when warms idles up
my bus wont stay idle on stops help
Stalling when not accelerating after engine warm
Some days you just get lucky, intermittently dies and restarts
ENGINE INJECTED]
EMISSIONS
Stalling Bus 1978 Federal model -SOLVED!! - EGR Valve/ EGR Video
EMISSIONS]
[FUEL
Fuel Gauge issues, moves on start then drops to empty...
Fuel gauge not working
Damn...(fuel pump)
HELP- Stuck in parking garage.(double relay)
Fuel Delivery Issue(pressure reg.)
Backfiring under load and stalling when stopping(clogged fuel tank)
Visible Gas Leak
Rough idle dying at stops on a 1970 vw bus 1600cc
Vaccum leak or carburator problem? 69 Westy
losing power....dying.....then firing up after a wait!
Intermittant idle after highway run - solved
Visible Gas Leak
FUEL]
[GAS HEATER
ba6 pump
GAS HEATER]
[STEERING & SUSPENSION
Vibrations/wobble 2000-2400rpm, 1700 type IV
FREE BEER! Help Identify front end Noise.SOLVED
steering box slop and possible crack(crack ended up being part of the steering flange clamp)
STEERING & SUSPENSION]
[WHAT IS THAT NOISE
What is that noise???
WHAT IS THAT NOISE]
[WON'T CRANK
71 bus. It would not crank.
Won't crank
perplexed, befuddled and in the doghouse
WON'T CRANK]
Wasted youth
Wasted youth is offline
PostPosted: Mon Jul 28, 2014 8:45 pm    Post subject: Reply with quote
Applause Applause
Jeff Geisen
Samba Chaplain
Jeff Geisen is offline
PostPosted: Wed Oct 01, 2014 4:33 am    Post subject: Reply with quote
Thanks for all this, you seem to be out to help. This is a very, very good reference library. Consider me helped out and totally grateful.
I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab
Klaussinator
Klaussinator is offline
PostPosted: Wed Oct 01, 2014 9:35 am    Post subject: Reply with quote
Jeff Geisen wrote:
... This is a very, very good reference library...
Agreed. Why is this not in the stickies?!?
-Klauss
I have taken a vow of poverty. To annoy me, send money!
____________________________________________
the Klaussinator - `73 hardtop Bay custom-built camper
airschooled
Air-Schooled
airschooled is offline
PostPosted: Mon Oct 27, 2014 7:10 pm    Post subject: clicking front end with pedal depressed - drum brakes Reply with quote
Drum front brakes clicking under braking load - solved
The last few days I've had a clicking coming from my front right wheel area under braking after the drums had warmed up. It started with one click per wheel rotation, but today it became two clicks per rotation. Because noises getting worse often mean impending failure, I ripped into the front right drum/wheel bearing assembly. I found light scraping on the backing plate in two spots, where the drum was rubbing. The black paint was scraped down to the primer, but no further. Good paint, I guess- thanks aeromech! I did check the wheel bearing play to be on the loose side of acceptable before I took it apart, and I reassembled it on the snug side of acceptable. I guess I wasn't as thorough last month when I reassembled everything with new grease after new ball joints went in. The clicking noise is gone, even under the hardest braking at the end of a long drive around town. So let this be a lesson- be more careful with front wheel bearing adjustment. I'm not sure if disc brakes would have this same issue, but I imagine they would. Check your work, and enjoy the drive. Cool
Robbie
www.airschooled.com
Road trip reports and tech blog:
panic_fan
panic_fan is offline
PostPosted: Tue Oct 28, 2014 7:46 am    Post subject: Reply with quote
shifting / transmission?
Rich
Brilliant Blue/Cloud White
1970 Baywindow Bus
http://www.thesamba.com/vw/forum/viewtopic.php?t=291988&highlight=
"Still learnin the way around my VW bay"
Teal Bay Bus
Hoody
Hoody is offline
PostPosted: Sun Mar 08, 2015 11:22 pm    Post subject: Reply with quote
Thank you so much for all of your due diligence and sharing all of your hard work with the rest of the VW community! You truly are a blessing!
Tcash
Tcash is offline
PostPosted: Mon Mar 09, 2015 8:19 am    Post subject: Reply with quote
Thanks Hoody! I needed that.
Tcash
HeathFromTexas
HeathFromTexas is offline
PostPosted: Wed Aug 12, 2015 4:08 am    Post subject: Reply with quote
Why are we bumping this instead of making it a sticky?
1970 T2A
http://www.thesamba.com/vw/forum/viewtopic.php?t=582117
Tcash
Tcash is offline
PostPosted: Wed Aug 12, 2015 8:36 am    Post subject: Reply with quote
In
Tech Tips
Under
LINKS
Diagrams
NOS PARTS PICTORIAL
Youtube Videos
Type 2 Technical Resource Library
Volkswagen Technical Articles
Gowesty Article Library
LINKS
Tcash
mattlockwood
mattlockwood is offline
PostPosted: Thu Mar 17, 2016 8:36 am    Post subject: Re: Symptoms Solved and Fixed Reply with quote
This is quite awesome... thx!
Tcash
Tcash is offline
PostPosted: Tue Sep 27, 2016 6:03 pm    Post subject: Re: Symptoms Solved and Fixed Reply with quote
Bump, see first post.
mark d
mark d is offline
PostPosted: Wed Sep 28, 2016 10:42 am    Post subject: Re: Symptoms Solved and Fixed Reply with quote
sticky ?
1972ish westfalia
"what good are tractors without violins ?" jose figueres
Tcash
Tcash is offline
PostPosted: Wed Jun 14, 2017 4:40 pm    Post subject: Re: Symptoms Solved and Fixed Reply with quote
KentABQ
KentABQ is offline
PostPosted: Thu Jun 15, 2017 7:36 am    Post subject: Re: Symptoms Solved and Fixed Reply with quote
I don't know how I failed to see this thread before. It's the greatest compilation of info I've seen so far! Thanks for putting it all together and bumping it, Tcash! Applause Applause Applause
I cast my vote to stickying this one, too.
-Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!"
---WildIdea
Bus ownership via emoticons:
Very Happy Shocked Mad Sad Embarassed d'oh! Pray Brick wall Pray Dancing Dancing Dancing ---williamM
Tcash
Tcash is offline
PostPosted: Thu Jun 15, 2017 10:04 am    Post subject: Re: Symptoms Solved and Fixed Reply with quote
We hide all the good stuff in the Sticky Topics at the top of the page.
Spike0180
Spike0180 is offline
PostPosted: Thu Jun 15, 2017 10:36 am    Post subject: Re: Symptoms Solved and Fixed Reply with quote
x2
Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic"
Tcash
Tcash is offline
PostPosted: Thu Oct 05, 2017 6:02 pm    Post subject: Re: Symptoms Solved and Fixed Reply with quote
Bump
Whaanga
Whaanga is offline
PostPosted: Sat Oct 07, 2017 1:52 pm    Post subject: Re: Symptoms Solved and Fixed Reply with quote
I agree with Hoody - Tcash, thanks for all you do for us. You have been extremely helpful (and patient) to/with me in my short time as a bus owner apprentice.
As Hoody says, you are a blessing.
Jeff
Late 1973 Bay w/a transplanted 914 Engine
Tcash
Tcash is offline
PostPosted: Fri Jun 15, 2018 6:52 pm    Post subject: Re: Symptoms Solved and Fixed Reply with quote
Bump
