Tcash Pics
Tcash
Tcash is offline
PostPosted: Wed Mar 23, 2016 7:03 pm    Post subject: Tcash Pics Reply with quote
To link to this thread:
Code:
[url=https://www.thesamba.com/vw/forum/viewtopic.php?t=651002]Tcash Pics[/url]
TO SEARCH THIS PAGE
Press Ctrl+F, Type search into the field Box
Tcash Pics
009 Flat Spot
1970 Fuse Box Conversions
1977 Jurgens Autovilla
38 amp generator install
AC Cut out in engine bay T2
Accelerator Pedal Linkage Faliure
Accelerator Pedal Stop
Add-A-Battery
Air Cleaner ID
Alternator Type 4
Animated VW Engine
Axle Rear Hub nut removal
BA6
BA6 Manuals
Ball Joints
Batteries
Battery Isolator Priority Start
Battery Life Cycle Chart
Bay/Split, South African Brasilia
Bottom End Failures
Brake Job 1968-70 Front (lots of pix)
Brake stop Light Switch 113945515H, 113945515G
Brake Adjustment Rear
Brake Booster All
Brake Caliper ID
Brake Caliper Piston Retaining Plate Install+Installation
Brake Disc Brake Conversions
Brake drum rubbing (Grinding) on backing plate
Brake line ISO flare
Brake Master Cylinder ID (Pics)
Brake Pressure Regulator t2 211 612 501
Brake Rear ID
Brake Reservoir ID (Pics)
Brake Servo (booster) ALL
Brake Servo (booster) breather hose
Brake Servo (booster) Circuit
Brake Servo (booster) ID (Pics)
Brake Servo (booster) master cylinder pushrod adjustment
Brake warning light 113 919 233 B.
Bumper Front & Rear ID
Bus parts manual + manuals
Bus ONLINE Bay Window Parts Manuals
Bus Early Bay Parts Manual
Bus Late Bay Parts Manual
Bus VW Microfiches for Type 2 1968-1979 / ratwell
Bus repair manual+Bus repair manuals
Buyers Guide
Cable End Repair
Camper Cabinet Plans / Diagrams
Campers
Carb Base Numbers
Carb Progressive Center Mount
Carburetor needle and seat cleaning
Carburetor/ Distributor Matchup/ Aircooled.Net
Center Pin
Charging System
Charts, Tables
Circlip two sides
Cleaning+Rodents+Hantavirus
Clutch Action
CLUTCH COVER/BELL HOUSING ID = STARTER ID
Clutch Disc diameter
Clutch problems
Coil Wiring Correct Polarity/ Thanks to SGKent
Correct Size Tool To Remove Axle Bolts Or CV Bolt
Cranks Won't Start
CV Joint All
CV Joint assembly
CV Joint How to Remove Stripped CV Bolt Head
CV Joint Service (Lobro)
CV Schnorr washer replacement Nord-Lock
Cylinder power balance (contribution) test
Diagrams
Distributor Advance Characteristics/ Chilton's
Distributor Advance Curves from Engine Manual
Distributor Lubing
Distributor Specifications
Distributor Stock Advance Curve Diagrams
Distributor T2 Bus Bay window
Door Cab ID
Door Panels Install
Double Relay Article/ Itinerant-Air-Cooled
Double Relay Explained. . . In Color!
Double Relay Test
DRIVABILITY DATA FORM
Electron Flow
Electronic Module Testing
Emergency/Hazard Switch ID
Engine Codes Letters Numbers
Engine Compartment Lid/ Decklid/ Engine Cover/
ID
Engine Noises
Engine pics thread
Engine Tin Installation Awesome Powdercoat
Engine Trans Refresh
Engine Type
Engine Types
Evaporative Emission Control/Charcoal, Carbon Canister
Exhaust System Bay Window ID
Exhaust Tail pipe 211 251 237 A / 211 251 237 B
Exhaust Type I Heat exchanger Heater box T2a Bus ID
Firewall
Frame Body Parts Diagrams and Dimensions
Fresh Air Drain Hose
Front axle beam Grease nipples N 18 515 1, N 18 516, N 18 511 2
Front beams
Front emblem mounting measurements
Front torsion arm bushings
Fuel Injection AFM Fuel pump Points
Fuel Injection Fuel Pressure Testing
Fuel Injection Leak Down Test
Fuel Injector Fuel Hoses
Fuel Injector Info
Fuel Line - Gates Barricade Fuel line hose
Fuel Pump Adjustment
Fuel pump relay wiring
Fuel Pumps
Fuel Sender Testing t2a
Fuel Sender Access Hole
Fuel tank hose connection
Fuel Tank Sending unit access hole Pic
Fuel tank shut off
Fusible Link Test Lead
Gas Tank, thing found
Glass Install
Glossary of Troubleshooting Terms
Greg Lindquist Parts Pictorial (pic heavy)
Hammering tie rod end
Hand Crank
Hazard Switch/ oldvolks
Headlight Dimmer Relay 411941583C+411-941-583C+
Headlight Dimmer Replacement Relay Install/ oldvolks
Headlight Switch/ Dimmer- Rheostat
Headlight switch/ Zip tie, Tie wrap
Heater Cable
Hockey Stick guide and ball
Horn all
Hose removal and installation
How do you read engine Bearing Size?
How to Use and Interpret a Vacuum Gauge
Identification ID
Tcash
Ignition High Tension Leaks
Ignition Housing ID
Ignition Switch Removal/ Lock Removal
Ignition switch testing , voltage drop test
Installing Door Panels
Instrument Cluster ID
Jacking Up A Bus
Jalousie (louvered) window rebuild
Kemperink
Keys
Lifter Noise, Engine Knock
Lifters Hydraulic or Solid ?
Light Bulb Chart T2
Loctite Green
Logos or Logo Bus
Lost Title
M-Plate Location
M-Plate decoder
Mirror Exterior mounting nut in door
Middle (center) seat identification
Mirror Outside Rear View Mirror
Mirror Rear View Mirror+Mirrors ID
NEWBIE
Nord-Lock your drive shaft (CV) bolts
NOS parts pictorial
Oil cooler seals
Oil Pressure FAQ
Oil Seal Sizes Dimensions T2
Original Survivor, Bus, Bay, T2
Owner's manual + Owners manual
Paint Codes and Formulas
Paint Spray paint, T2, Aerosol, Rattle Can, Close to factory color
Parts identification ID T2 (lots of pix) FAQ
Pertronix Module Testing
Pilot bearing 111 105 313 A
Piston Pin Offset
Points vs Electronic
Progressive Center Mount Carb
Protractor Craftsman Magnetic Universal
Rear Axle Assembling
Remote starter diagnostic plug
Repair panels
Repair shops and help
Rubber preservation
Rust Repair, Prevention and Manuals
Seat 2/3 Front bench seat
Seat Center (middle) seat identification
Seat Front identification
Seats Front Bucket Seat ID
Shift points
Hockey Stick guide broken and Ball worn out
Shifter Parts ID
Shifters
Shock mount Front torsion arm switch from 68-69 to 70-79
Shock Mount Rear T2
Sliding Door All
Sliding Door, Amskeptic/Ratwell
Sliding door, threshold, sill plate-panek, scuff plate,ID
Sliding Door+Directions+Operating+Operation+Using 68-73
Sliding Window Size
Smoke Tester
Spare Tire Mount/Luggage Compartment ID
Spark Plug Thread Repair
Spark Plug/ Starting with a piece of hose.
Spark Plugs
Splash Pan/ Cover plate under pedal cluster (splash pan)
Spring Plate Angle/Torsion Bar Adjustment (Pics Added)
Starter
Starter id = Which clutch cover/bell housing you have
Starter Jump
Steering Box
Steering Box 1968-72 Replacement (lots of pix)
Steering Box Drop Arm Pullers
Steering box lube
Steering Coupling Disc 211 415 417 (coupler) T2
Steering Play
Stripped Wiper Motor Gear
Swing Lever Shaft Kit, Center Pin, Center Link, Installation
Symptoms Solved and Fixed
T2 Identification ID Tcash
TDC Finding True TDC
Tools/Parts/Materials list
TECH TIPS
Teflon Tape (for gas)
Type I Crankshaft stock pulley early and late
Threaded insert E-Z LOCK/ Thread insert/ Thread repair
Timing
Timing - Finding TDC #1/ Installing Distributor Drive Gear and Dist.
Timing Scale type I (1)
Tom Wilson
Torque Tool
Tourist Delivery
Uhaul auto transport trailer for a VW Bus?
Towing an Automatic
Trans ID
Trans / Gear ratio / Tire Size / Calculators
Trans 003 Automatic rebuild
Trans Final Drive Flange Seal
Trans Front mount
Transmission Hole to Lubricate throw out bearing
Transmission input shaft length
Trans Input shaft Rear main drive Shaft, Clutch shaft, Came coming out
TS2, TSII Relocating Temp. Sensor,
Tune Up
Turn indicators: Wire to blink independently/ telford dorr
Turn signal switch to steering wheel clearance
Type I Crankshaft Pulley ID
Type I Engine Tins
Type I Front tin
Type IV (4) Mechanical fuel pump
Type IV (4) testing FI fuel pump circuit running
Type IV Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A
Type IV degree wheel
Type IV Engine Tin 1972-73-74 Type IV (4) Engine Tin
Type IV Engine Tin 75-78
Type IV (4) engine tin installation
Type IV 4 Exhaust Install
Type IV (4) Exhaust Systems
Type 4 Hex head washer for the fuel pressure testing tap
Type IV (4) drain plug thread repair
Type IV TTS thermo time switch and FI grounds
Type 4 thermostat and flaps
VDO LED Bulb Upgrade
Vacuum gauge
Vacuum Gauge Hooking up the Gauge
Vacuum Gauge | Tuner University
Vacuum Gauge Tuning
Valve Train Failures
Volkswagen Bay Transporter Restoration Manual
Volkswagen Script 311 853 687
Voltage drop test
VW Automatic Script
VW Business Listing
VW Training Films
VW Type 2 / Bus Crash Estimate Guide
VIN, Chassis, Engine number locations
Westfalia Interiors (lots of Pix)
Westfalia Pop Top
What is VW sealing compound D3 - Rennlist Discussion Forums
Wheel Bearing Part Numbers and Sizes
Wheelskins Installation (tech tip)
Wilson Tom
Window Stickers
Windshield Wiper Arm ID
Wiper Motor
Wiring Diagrams - Vintagebus.com
Youtube Videos
copy and paste
en.wikipedia.org/wiki/John_Muir_(engineer)
http://www.dolgyfre.adsl24.co.uk/spooky/barrel/barrel.html
chabanais
chabanais is offline
PostPosted: Wed Mar 23, 2016 10:20 pm    Post subject: Re: Tcash Picks Reply with quote
Wrong John Muir.
"I spud therefore I yam."
jtauxe Premium Member
jtauxe is offline
PostPosted: Thu Mar 24, 2016 6:55 am    Post subject: Re: Tcash Picks Reply with quote
FTFY. Smile
Past that entire string into your browser address window.
Be sure to include the (engineer) part in the URL, or you end up with the naturalist John Muir. Interestingly, Trying to make a URL of this whole string in this forum tool fails. Windoze?
And kudos to Tcash for all his work on making this forum EVEN MORE USEFUL!
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
khalimadeath
khalimadeath is offline
PostPosted: Thu Mar 24, 2016 9:35 am    Post subject: Re: Tcash Picks Reply with quote
Been busy huh Tcash? Nice list!
KentABQ
KentABQ is offline
PostPosted: Mon Jan 04, 2021 4:58 pm    Post subject: Re: Tcash Pics Reply with quote
TCash has been MIA for over two years, and I still miss the guy. Crying or Very sad
Think of the poor new Samba members who have never been on the receiving end of his posts. Or his "Welcome to The Samba" posts.
TCash is good people. I hope he is doing well.
-Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!"
---WildIdea
Bus ownership via emoticons:
Very Happy Shocked Mad Sad Embarassed d'oh! Pray Brick wall Pray Dancing Dancing Dancing ---williamM
SamboSamba22
SamboSamba22 is offline
PostPosted: Wed Jan 04, 2023 6:42 am    Post subject: Re: Tcash Pics Reply with quote
Tim (TCash) was a vital part of this community, with endless engagement, resourcefulness, and an undeniable fact of wanting to help others. He single-handedly impacted my willingness and ability to begin my own VW journey through his help here on the Samba.
So yeah, I’m with you Kent, I hope he’s doing well.
Sam
EDIT: Seems he hasn’t been logged back in since July of 2018. I knew it had been some time. Really hope he’s just enjoying new chapters in life.
The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL]
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Bay Window Bus All times are Mountain Standard Time/Pacific Daylight Savings Time
